For the first 6h I’ve scheduled observations for both satellites. Given that CuPID transmits after command from its ground station, it has less observations scheduled than CUTE.
EDIT: Have in mind that this TLE set is an estimation, to station owners please don’t schedule far away in the future until we have a more accurate TLE set.
Arika Egan here of the CUTE science team. CUTE will begin beaconing approximately 35 minutes after deployment from its dispenser.
Regarding CuPID, we met with them at the launch from VSFB and they’ve told us that their spacecraft is, unfortunately, not configured to beacon.
Thanks for the TLE also–we will share what we have about as soon as we get something from GSFC/Parsons. And thanks doubly for scheduling hella observations for CUTE! Our own operators are standing by to try to make contact at the first passes; we can let you know when we get our first telemetry.
Given the on time launch, the deployment time and the 35min delay… this means that beaconing of CUTE will start around 21:06 UTC. There are several scheduled observations at that time, so good chance to receive the first beacons.
About CuPID, thanks for confirming our findings that transmits only after commands, we will schedule it only over US. What is interesting is that they will have GFSK at 38k4 rate which is unusual for UHF frequency, wondering if this will be their default rate for downlink or they will start with a lower one and increase it through commands.
About the TLE set, as soon as we have a more accurate one, it will help a lot to have better observations. Good luck with your mission!
East Coast U.S. pass in an hour based on the prelim TLE, but only modest elevation for me. Others will likely have a better chance, but I’ll be watching regardless!
Based on report from JA0CAW, I was tracking 3 minutes earlier than prelim TLE posted above.
That was not enough - more like 6 minutes would have been closer. Between low elevation & incorrect antenna pointing, I was just barely able to make out the packets (‘if’ blips seen were from CUTE). Hope for better when the elevation is higher & TLE’s have been identified. Best of luck to everyone!
As this TLE set describes an object that it is far away from the previous one, I’ve removed all the future observations of CUTE and I’ve re-scheduled them.
EDIT: Also see this comment from myself from the other thread:
By the way, we just had a pass in the past ~30 minutes over Boulder, CO, and we tried using the most recent TLE that Goddard gave us, only to find that the current SatNOGS TLE outperformed it by about 5dB of extra signal
In good news–we managed to get two commands in! Both were to increase the beacon rate to 4 seconds. Note that these are automatically overridden after about 5 minutes by an internal macro, so the next observations obtained by SatNOGS ground stations will see beacons at 16 second intervals again.
Hi Nick, I am surprised that our tle works much better than the Nasa one. We based it first on a tle we believe is Landsat 9, updated that with the STRF measurements I did. This worked quite good. But @cgbsat suggested and helped to make a tle from scratch. Also @fredy was checking the intermediate tles to the observation that where already in the network. In the end we settled on our tle based on 4 passes which looked like:
As the TLE are in TBA status, we should wait to identify CUTE. But for now in DB and Network CUTE will follow OBJECT D(49263).
With the assumption that CuPID was deployed at the same time with CUTE (@aregan or @nsdecicco could you confirm that?) and the the other objects are not close, I’ve changed CuPID to follow OBJECT E(49264).
According to Jonathan McDowell, there where two other cube sats. Cesium Sat 1 and 2 (Cesium Space, Austin, TX).
Yes, that is correct. But these are commercial missions that I don’t believe beacon on amateur bands. My understanding is that these are meant to be test bed missions for Cesium’s Nightingale 1 Ka band radio.
IIRC I believe the order of deployment was:
One of the Cesium sats
CuPID
The other Cesium sat
CUTE
(But I could be mis-remembering.)
I am not sure how much time elapsed between each deployment.
We’re configured to track NORADID 49263 as CUTE now as well. We have a pass in about 8 hours but plan to receive only. We’ll command again at ~2021-09-29 16:38:00 UTC.
Emil here from the CuPID team. We are still working on establishing first contact with our satellite. We think our current challenge is just knowing where our satellite is. We have a few TLEs but none of them successful. CuPID is set at 400.5MHz and 38.4 downlink. These settings were decided upon years ago for some reason I am not aware of. We don’t beacon because of our frequency and license.
Thank you for looking for us up there. Once we establish contact we will certainly let this awesome community know!
