Two requests in one post
First: Could the BIRDS-1 constellation be added to the DB? This is a series of cubesats transmitting in sequence on 437.375 MHz (FM). See here for (some) information: http://birds.ele.kyutech.ac.jp/amateur.html
A bit of digging suggests the constellation NORAD IDs are #42820 through #42824, though im not sure they know which number is which sat. It may be best to just pick the ‘middle’ one (42822) and see how we go.
Second: Could a ‘BPSK9k6’ modulation field be added to the DB? I’m working on a flowgraph for LilacSat-1, which needs to be output at a 12 kHz IF (as opposed to the current 1.5 kHz IF for BPSK1k2).
Thanks,
Mark VK5QI
