Hi Fredy,
Please can you check the tle for SaganSat0 I’ve tried loading it to Orbitron but it would not display.
Looking at the tle I think this should be a 0 and not a 4 as when changing it to 0 it then works in Orbitron.
Hi Fredy,
Confirmed.
Even if line 1 has a correct checksum according to vCalc using “4____08” at the end, also Gpredict won’t display SaganSat0.
Change it to “0____04” and it will work.
You are right, I’m copying Sakura TLE for SaganSat0 and it looks like that I have a copy paste error somewhere. I’ve fixed it in the post above and in the next minutes it will be fixed in both DB and Network.
Thanks for letting me know!
No problem, happy to help.
Hi EU1SAT,
Thank you for all your work. Could I ask what TLE you are using? Satnogs TLE? We are trying to verify what TLE is the most accurate to use.
Thank you for sharing this Beacons, we will add them to our database. Where would we be able to get the data? Thank you
Regards, Tristan
Binar
I used TLE from SatNOGS DB with manual correction, but the shift is already more +3000 Hz ![]()
Thank you, would you be uploading the data to satnogs?
Data I uploaded to SatNOGS DB
https://db.satnogs.org/satellite/FACZ-7987-8249-5385-5279#data
https://db.satnogs.org/satellite/EHBA-7491-4486-7496-1223#data
https://db.satnogs.org/satellite/WJHX-1326-6381-8250-7903#data
To download the data you need to log in
Ok, maybe the server took a bit to update. I could not find the data but after some refreshing it appeared. I am still waiting on binar 3. Thank you again. ![]()
Hi, the zip file seems to contain a .exe file. was this the intention? is there a chance you could upload the bytes in some other format such as text?
Hi EU1SAT, Thank you for that. Maybe I was looking in the wrong place it seems. Thanks again for tracking and demodulating. Very helpful.
New TLE sets for all the satellites:
Sakura
1 99196U 24245.60000000 .00000000 00000-0 -13037-2 0 07
2 99196 51.6396 296.6709 0010444 166.2144 167.1605 15.50344221 05
SaganSat0
1 98810U 24245.60000000 .00000000 00000-0 36833-3 0 08
2 98810 51.6391 297.1174 0013796 308.0894 24.6305 15.50465888 02
CosmoGirl-Sat
1 98811U 24245.60000000 .00000000 00000-0 36833-3 0 09
2 98811 51.6391 297.1174 0013796 308.0894 24.6305 15.50465888 03
Binar-2
1 98808U 24245.60000000 .00000000 00000-0 42798-3 0 02
2 98808 51.6396 303.6180 0011246 168.3207 160.9049 15.49395767 02
Binar-3
1 98807U 24245.60000000 .00000000 00000-0 42798-3 0 01
2 98807 51.6396 296.1891 0006846 72.1491 260.6782 15.50567383 02
Binar-4
1 98806U 24245.60000000 .00000000 00000-0 42798-3 0 00
2 98806 51.6396 296.1143 0011288 165.4224 166.7037 15.50720933 08
Notes:
One more fitted TLE set:
Binar-2
1 98808U 24246.30000000 .00000000 00000-0 42798-3 0 00
2 98808 51.6396 291.6328 0010903 173.4478 110.4524 15.50836004 02
TLE updates by @PE0SAT:
SAKURA
1 99196U 24246.12858796 .00000000 00000-0 -13037-2 0 08
2 99196 51.6396 293.9107 0010149 170.7688 235.5523 15.50884512 03
COSMOGIRL-SAT
1 98811U 24246.12858796 .00000000 00000-0 36833-3 0 00
2 98811 51.6390 294.5218 0013796 45.7903 359.3552 15.49654886 06
Thank you for all the observations and TLE determination for Binar-2, 3, and 4! It has been incredibly helpful so far!
Judging from the successful passes, there have been many observations of Binar-2, 3, and 4, but no data demodulated. Wondering if there is anything we can do to make that possible?
New TLE sets,
SAKURA
1 99196U 24247.60000000 .00000000 00000-0 -13413-2 0 07
2 99196 51.6396 286.6451 0004930 39.5832 306.6295 15.50804785 08
SaganSat0
1 98810U 24247.60000000 .00000000 00000-0 14977-2 0 04
2 98810 51.6391 287.0482 0010937 314.0972 30.6587 15.50744369 03
CosmoGirl-Sat
1 98811U 24247.60000000 .00000000 00000-0 14977-2 0 05
2 98811 51.6391 287.0482 0010937 314.0972 30.6587 15.50744369 04
Binar-2
1 98808U 24247.60000000 .00000000 00000-0 42798-3 0 04
2 98808 51.6396 286.3901 0010903 57.4705 289.2045 15.51188206 02
Binar-3
1 98807U 24247.60000000 .00000000 00000-0 42798-3 0 03
2 98807 51.6396 286.7291 0006594 77.5539 268.9667 15.51094991 07
Binar-4
1 98806U 24247.60000000 .00000000 00000-0 59519-3 0 01
2 98806 51.6396 286.9926 0002540 89.2899 255.4768 15.50959053 00
Notes:
Below are the possible reasons for not demodulating:
Given that there are some observations that show a good SNR on waterfall, probably is the second reason. Maybe @surligas @PE0SAT or @SA2KNG that are more familiar with demodulators scripts can help us to figure it out.
