Wxtomig better results on APT audio files
I know it’s off topic.
My plan is to implement wxtoimg to the whole APT thing. When I do this manualy
sudo sox satnogs_138516_2018-05-18T08-58-55.ogg output.wav rate 11025 && sudo wxtoimg -e HVCT output.wav noaaHVCT.png
I get way better results:
The pictures of gr-APT-script are half rounded etc. p. p.:
https://network.satnogs.org/observations/138516/
I hope I can do it automaticaly…
The “roundedness” is a known issue and is being worked on. At some point it worked without “roundedness”, see for example this observation.
It is of course possible to run wxtoimg instead. I have been doing that on my station almost a year now, but it did require code changes that I now have to maintain when satnogs software is updated.
Hey Alex.
My plan was to hook the wxtoimg thingy into
def rename_ogg_file(self):
if os.path.isfile(self.observation_raw_file):
os.rename(self.observation_raw_file,
self.observation_ogg_file)
logger.info('Rename encoded file for uploading finished')
of observer.py…
yes, it’s no problem to do that, but you will have to keep your changes up to date when satnogs-client is updated.
May be you have some unwanted feature in your dev:
My fault. Wrong name to right pic,
hello csete,i got you aptdec project on github yesterday,but it can’t work now,the output show there are no initsnd/initalsa/endsample interface, my env is ubuntu 18,do you got any suggesetion for me ,thanks.
