Hi, I just noticed that https://wiki.satnogs.org/ does give a certificate warning when connection via IPv6. And if I ignore the error I do net get the wiki but the community site is showing. However connecting via IPv4 does work fine and I can reach the wiki without certificate warning.
I suspect this to be a configuration problem on the web server. I guess you want to have a closer look at this.
Thanks, it’s working here now. Yesterday I had problems with the community site, but it’s probably because you were working on the configuration. Now everything seems to work fine
