If this is not the log output you want , please tell me which one.
Tim Boyle haigboyle@gmail.com
10:03 AM (2 minutes ago)
to me
DEBUG satnogsclient.scheduler.tasks Observer args: {‘observation_id’: 11311864, ‘tle’: {‘tle0’: ‘0 GOES 18’, ‘tle1’: ‘1 51850U 22021A 25087.20770810 .00000093 00000-0 00000+0 0 9994’, ‘tle2’: ‘2 51850 0.0227 319.6391 0000261 118.2309 45.7707 1.00271810 11335’}, ‘observation_end’: datetime.datetime(2025, 3, 28, 15, 2, tzinfo=tzlocal()), ‘frequency’: 1679900000, ‘mode’: ‘FM’, ‘baud’: None}
DEBUG satnogsclient.scheduler.tasks Spawning observer worker.
INFO satnogsclient.observer.observer Begin observation 11311864 …
DEBUG satnogsclient.observer.observer Start rotctrl thread.
DEBUG satnogsclient.observer.observer TLE: {‘tle0’: ‘0 GOES 18’, ‘tle1’: ‘1 51850U 22021A 25087.20770810 .00000093 00000-0 00000+0 0 9994’, ‘tle2’: ‘2 51850 0.0227 319.6391 0000261 118.2309 45.7707 1.00271810 11335’}
DEBUG satnogsclient.observer.observer Observation end: 2025-03-28 15:02:00+00:00
DEBUG satnogsclient.observer.worker Tracking initiated
Exception in thread Thread-6:
File “/usr/lib/python3.9/threading.py”, line 954, in _bootstrap_inner
DEBUG satnogsclient.observer.observer Start rigctrl thread.
DEBUG satnogsclient.observer.observer Rig Frequency 1679900000
rig_init: rig does not have rx_range!!
network_open: hoststr=127.0.0.1, portstr=4532
connect to 127.0.0.1:4532 failed, (trying next interface): Network error 111: Connection refused
network_open: failed to connect to 127.0.0.1:4532
DEBUG satnogsclient.observer.orbital Observer data: {‘lon’: -89.5, ‘lat’: 45.581, ‘elev’: 483}
DEBUG satnogsclient.observer.orbital Satellite data: {‘tle0’: ‘0 GOES 18’, ‘tle1’: ‘1 51850U 22021A 25087.20770810 .00000093 00000-0 00000+0 0 9994’, ‘tle2’: ‘2 51850 0.0227 319.6391 0000261 118.2309 45.7707 1.00271810 11335’}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153010830283165, ‘ok’: True}
DEBUG satnogsclient.observer.worker Initial frequency: 1679900000
DEBUG satnogsclient.observer.worker Rigctld msg: 1679900000
rig_get_vfo: no rig and/or vfo? rig=0xf0a00680, vfo=0xf13fe230
self.run()
File “/usr/lib/python3.9/threading.py”, line 892, in run
self._target(*self._args, **self._kwargs)
File “/usr/local/lib/python3.9/dist-packages/satnogsclient/observer/worker.py”, line 119, in _communicate_tracking_info
rotator = Rotator(settings.SATNOGS_ROT_MODEL, settings.SATNOGS_ROT_BAUD,
File “/usr/local/lib/python3.9/dist-packages/satnogsclient/rotator.py”, line 23, in init
self.rot_name = getattr(Hamlib, model)
AttributeError: module ‘Hamlib’ has no attribute ‘202’
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031530603766441345, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153109923005104, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031531594693660736, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153209388256073, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031532589346170425, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153308480978012, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153359889984131, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031534094363451004, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.0315345898270607, ‘ok’: True}
INFO satnogsclient.observer.observer Start gnuradio thread.
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153509274125099, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153558820486069, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153608366847038, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153658285737038, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153708204627037, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031537577509880066, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153807669878006, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110583901405334, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031538572162389755, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03153906762599945, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031539566814899445, ‘ok’: True}
[INFO] Opening Generic RTL2832U OEM :: 42939399…
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03154006227850914, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031540557742118835, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03154105693101883, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031541552394628525, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03154204785823822, ‘ok’: True}
[R82XX] PLL not locked!
[INFO] Using format CF32.
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.031542543321847916, ‘ok’: True}
[ERROR] ./lib/tcp_rigctl_msg_source_impl.cc:147: Could not connect at rigctl server 127.0.0.1
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03154304251074791, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.0315435416996479, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.0315440371632576, ‘ok’: True}
DEBUG satnogsclient.observer.orbital Calculated data: {‘alt’: 0.35110586881637573, ‘az’: 4.133316993713379, ‘rng’: 39543064.0, ‘rng_vlct’: -0.03154453635215759, ‘ok’: True}
DEBUG satnogsclient.observer.observer Tracking stopped.
DEBUG satnogsclient.observer.worker Tracking stopped.
INFO satnogsclient.observer.observer Observation 11311864 finished.
DEBUG satnogsclient.observer.observer Rename encoded file for uploading finished
DEBUG satnogsclient.observer.observer Creating waterfall plot.
DEBUG satnogsclient.waterfall Reading waterfall file
ERROR satnogsclient.observer.observer Waterfall data array is invalid
