I’m running the latest git version of satnogs-client on a PC using OpenSUSE Leap 42.3. The data files created by the observer are in /tmp/.satnogs/data. They have not been uploaded, and I believe that the reason can be found in these lines from the log:
2018-05-11 21:07:17,357 - apscheduler.executors.default - ERROR - Job “post_data (trigger: interval[0:02:00], next run at: 2018-05-11 19:09:17 UTC)” raised an exception
File “/usr/lib/python3.4/site-packages/apscheduler/executors/base.py”, line 125, in run_job
retval = job.func(*job.args, **job.kwargs)
File “/usr/local/src/satnogs-client/satnogsclient/scheduler/tasks.py”, line 92, in post_data
for fil in os.walk(settings.SATNOGS_OUTPUT_PATH).next()[2]:
AttributeError: ‘generator’ object has no attribute ‘next’
I have explicitely defined the environment variable SATNOGS_OUTPUT_PATH to point to /tmp/.satnogs/data.
this idiom for directory traversal seems to work with python3:
for root, dirs, files in os.walk(settings.SATNOGS_OUTPUT_PATH):
for fil in files:
or better, but without walk, the following idiom does not recurse through subdirs
as it was the case before:
for file in os.listdir("."):
if os.path.isfile(file):
This stresses a question, for which I so far have been unable to find an answer to: Which version of Python is satnogs-client actually written for? version 2 or version 3?
The installation instructions talks about setting up a virtual environment, but did not specify what should go into this environment. I couldn’t find the program ‘mkvirtualenv’ but managed somehow anyway to get something set up. That environment is a Python 3 environment, whereas OpenSUSE still sticks to Python2.
I guess its better I expand a bit on how I got the virtual environment working
I installed virtualenvwrapper with pip. Then I executed this command:
source $(which virtualenvwrapper.sh)
and could now execute
‘mkvirtualenv satnogs-client -a’ and ‘workon satnogs-client’.
I guess I should alway do this before I work on the satnogs-client files?
Please don’t ask me how I found this out. I’m very bad at keeping logs.
I have made the error in tasks.py disappear. I used your first suggestion, so the relevant lines now read
for fil in files:
file_path = os.path.join(*[settings.SATNOGS_OUTPUT_PATH, fil])
print("Looking at: ", fil)
if (fil.startswith(‘receiving_satnogs’) or
fil.startswith(‘receiving_waterfall’) or
fil.startswith(‘receiving_data’) or
os.stat(file_path).st_size == 0):
continue`
(you will probably have to imagine the indentation)
However, nothing is uploaded yet. The files creating during a pass (the ‘receiving…’ files) are still left in /tmp/.satnogs/data.
But the ‘continue’ lines in the code also tells me that these files are being ignored. Some other process must the create the files that do get uploaded. The question of course is ‘which?’ So the search continues.
Anyway, you helped me get rid of the error and thank you for that.
You will notice that I have put a print line into the code. I did this because I can’t get my head around satnog-client’s logging system. I’ll raise that question in a separate thread.
Filenames must have a correct naming to be uploaded to the network, for example:
-rw-rw-r-- 1 satnogs satnogs 4337800 mai 13 22:47 receiving_waterfall_134755_2018-05-13T20-45-38.dat
-rw-rw-r-- 1 satnogs satnogs 3792896 mai 13 22:47 receiving_satnogs_134755_2018-05-13T20-45-38.out
and the ident number must correspond to a registered one, I think.
When something went wrong, some steps may have been missed.
It is better to start again after the correction. Is it your case?
May be you can come back to your data after everything has come back under control.
And I almost forgot, have you started satnogs-network?
If the 0 branch is the dev, Why are tags on the 0 branch?
There has recently been a call to install version 0.6.1 and it is on
the 0 branch (dev) and not on master.
Which branch is considered stable enough for prod then?
I have at present these files in /tmp/.satnogs/data:
-rw-r--r-- 1 bent users 250871808 maj 13 20:24 receiving_satnogs_134569_2018-05-13T14-30-50.out
-rw-r--r-- 1 bent users 155648 maj 14 20:23 receiving_satnogs_135326_2018-05-14T14-06-47.out
-rw-r--r-- 1 bent users 147456 maj 14 20:27 receiving_satnogs_135327_2018-05-14T14-25-46.out
-rw-r--r-- 1 bent users 452775300 maj 13 20:24 receiving_waterfall_134569_2018-05-13T14-30-50.dat
-rw-r--r-- 1 bent users 50782600 maj 14 20:29 receiving_waterfall_135326_2018-05-14T14-06-47.dat
-rw-r--r-- 1 bent users 56157700 maj 14 20:29 receiving_waterfall_135327_2018-05-14T14-25-46.dat
The ones for observations 135326 and 135327 are recorded after I updated tasks.py. They correspond to the ‘needs vetting’ observations on my ground station’s page
I thought that satnogs-network is what I connect to when I schedule observations etc. Should I have a local copy of that running alongside my client?
I have checked about satnogs-network. I am not sure if it is needed at this point.
After completion of the observation the “receiving_” prefix is dropped.
The post method is waiting these files begin with
satnogs, waterfall or data to send them on the network.
If there have been no more commits, master branch is ok, because it is the same as 0.6.1, otherwise do a
$ git checkout 0.6.1
Don’t forget to update gr-satnogs to v1.3
@oz6bl: I cannot find the point why you are trying to manipulate the code - is it because you want to use python3 or is it just because “it’s not working” for you?
