Hello,
After a re install of my SatNogs system (same Raspi, but new install), I have an issue with the station:
It stays on ‘…waiting for waterfall’, “waiting for audio” and “waiting for data”… With the previous install I never had this issue.
When logging with journalctl , I see this error when an observation starts:
Aug 04 22:00:14 raspberrypi satnogs-client[17127]: [INFO] Using format CF32.
Aug 04 22:00:14 raspberrypi satnogs-client[17127]: Could not find port: freq in:
Aug 04 22:00:14 raspberrypi satnogs-client[17127]: freq
Aug 04 22:00:14 raspberrypi satnogs-client[17127]: system
Aug 04 22:00:14 raspberrypi satnogs-client[17127]: 2
Aug 04 22:00:14 raspberrypi satnogs-client[17127]: Traceback (most recent call last):
See my logging file of an observation of NOAA19:
*Aug 04 21:15:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:16:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:16:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Post data started
Aug 04 21:17:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:18:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:19:05 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Spawning observer worker.
Aug 04 21:19:05 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Start rotctrl thread.
Aug 04 21:19:05 raspberrypi satnogs-client[12477]: satnogsclient.observer.worker - INFO - Tracking initiated
Aug 04 21:19:05 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Start rigctrl thread.
Aug 04 21:19:06 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Start gnuradio thread.
Aug 04 21:19:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:19:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Post data started
Aug 04 21:19:17 raspberrypi satnogs-client[12477]: Found Rafael Micro R820T tuner
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: Found Rafael Micro R820T tuner
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: [R82XX] PLL not locked!
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: [INFO] Using format CF32.
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: Could not find port: freq in:
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: system
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: freq
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: 4
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: Traceback (most recent call last):
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: File “/usr/bin/satnogs_cw_decoder.py”, line 459, in
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: main()
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: File “/usr/bin/satnogs_cw_decoder.py”, line 444, in main
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bfo_freq=options.bfo_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path, wpm=options.wpm)
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: File “/usr/bin/satnogs_cw_decoder.py”, line 129, in init
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: self.satnogs_doppler_compensation_0 = satnogs.doppler_compensation(samp_rate_rx, rx_freq, lo_offset, audio_samp_rate, 1, 0)
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: File “/usr/lib/python3/dist-packages/satnogs/doppler_compensation.py”, line 147, in init
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: self.doppler, “freq”)
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: File “/usr/lib/python3/dist-packages/gnuradio/gr/hier_block2.py”, line 60, in wrapped
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: func(self, src.to_basic_block(), srcport, dst.to_basic_block(), dstport)
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: File “/usr/lib/python3/dist-packages/gnuradio/gr/hier_block2.py”, line 132, in msg_connect
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: self.primitive_msg_connect(*args)
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: File “/usr/lib/python3/dist-packages/gnuradio/gr/runtime_swig.py”, line 3665, in primitive_msg_connect
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: return _runtime_swig.hier_block2_sptr_primitive_msg_connect(self, *args)
Aug 04 21:19:18 raspberrypi satnogs-client[12477]: RuntimeError: invalid msg port in connect() or disconnect()
Aug 04 21:19:21 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Tracking stopped.
Aug 04 21:19:21 raspberrypi satnogs-client[12477]: satnogsclient.observer.worker - INFO - Tracking stopped.
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: satnogsclient.observer.worker - INFO - Tracking stopped.
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Observation Finished
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Executing post-observation script.
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Rename encoded file for uploading finished
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: satnogsclient.observer.observer - INFO - Creating waterfall plot.
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: satnogsclient.observer.waterfall - INFO - Read waterfall file
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: apscheduler.executors.default - ERROR - Job “spawn_observer (trigger: date[2020-08-04 20:19:05 UTC], next run at: 2020-08-04 20:19:05 UTC)” raised an exception
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: Traceback (most recent call last):
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: File “/usr/lib/python3/dist-packages/apscheduler/executors/base.py”, line 125, in run_job
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: retval = job.func(*job.args, **job.kwargs)
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py”, line 55, in spawn_observer
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: observer.observe()
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/observer.py”, line 165, in observe
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: self.plot_waterfall()
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/observer.py”, line 267, in plot_waterfall
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: waterfall_png=self.observation_waterfall_png)
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/waterfall.py”, line 39, in plot_waterfall
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: waterfall = read_waterfall(waterfall_file)
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/waterfall.py”, line 22, in read_waterfall
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: ‘timestamp’: np.fromfile(wf_file, dtype=’|S32’, count=1)[0],
Aug 04 21:19:23 raspberrypi satnogs-client[12477]: IndexError: index 0 is out of bounds for axis 0 with size 0
Aug 04 21:20:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:21:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:22:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:22:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Post data started
Aug 04 21:22:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 2649365
Aug 04 21:22:11 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Upload successful.
Aug 04 21:23:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Aug 04 21:24:10 raspberrypi satnogs-client[12477]: satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Support log:
“versions”: {
“satnogs-client”: “1.3.4”,
“satnogs-client-ansible”: “202007160921”,
“satnogs-flowgraphs”: “1.2.2-1”,
“gr-satnogs”: “2.1.2.1-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.0.0-6”,
“satnogs-config”: “0.10.2”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2020-08-04T20:39:19.178894+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “4.19.97-v7+”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 971059200,
“available”: 777916416,
“percent”: 19.9,
“used”: 116137984,
“free”: 413261824,
“active”: 295108608,
“inactive”: 179388416,
“buffers”: 65302528,
“cached”: 376356864,
“shared”: 12521472,
“slab”: 65208320
“disk”: {
“total”: 7568015360,
“used”: 3310313472,
“free”: 3902746624,
“percent”: 45.9
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_log_level”: “INFO”,
“satnogs_rf_gain”: “32.8”,
“satnogs_station_elev”: “20”,
“satnogs_station_id”: “479”,
“satnogs_station_lat”: “50.931117”,
“satnogs_station_lon”: “3.0923”
Somebody who has an idea what is going wrong here?
Best 73’s, ON4API
