I’ve added support for NOAA at https://r2cloud.ru. And was able to decode occasionally some signals. Here sample command:
curl https://network-dev.satnogs.org/media/data_payloads/satnogs_2932_2017-05-19T06-01-26.ogg | curl -T - -X POST -H “Content-Type: audio/ogg” -H “Authorization: xxx” https://r2cloud.ru/v1/noaa/2932 -v
Once server decode signal result could be retrieved using the following command:
curl -X GET -H “Authorization: xxx” https://r2cloud.ru/v1/noaa/2932 -v
Output:
“id”:“2932”,
“data”:[
“gain”:6.2,
“a”:{
“type”:“2 (near infrared)”,
“image”:“http://img.r2cloud.ru/noaa/07025638-868e-42ea-8774-236d9984cdc6/a.jpg”
“b”:{
“type”:“4 (thermal infrared)”,
“image”:“http://img.r2cloud.ru/noaa/07025638-868e-42ea-8774-236d9984cdc6/b.jpg”
“status”:“SUCCESS”
The problem is not all NOAA observations could be decoded. wxtoimg complains about volume too high. Was it made explicitly on satnogs client or gain setting should be changed for APT?
