Vertical with broadband UHF LNA
New non tuned vertical with a broadband UHF optimized LNA working nice to capture most satellites and decoding them.
I am investigating to see what is minimal needed to decode satellites and if you need very fancy antenna.
Any feedback welcome
Dear Jacques,
good job with the new antenna,
can you give me more information about this antenna? Reference antenna? home made?
thanks you
73’s
olivier F6OBT
Thanks, it was basically just a wire, old car antenna (not tuned) mounted next to roof. This is not your optimal antenna, but idea was to show with how simple setup you can start
