Vega-C: Inaugural launch Flight VV21(MEO orbit) - 2022-07-13 13:13 UTC
Did anyone else get an error in the flow graph files when loaded into Gnu_radio (windows versio, d/l from the S5lab website)? I had to add “int(…)” around the value for tx_sps in the Repeat Interpolation block (thank you to K4KDR for this info!).
I have not had any successful decodes or (as far as I can tell) digipeats this weekend. Is anyone using the gnuradio-rigctrl-software tnc-gui S5labs describes in their digipeater page? Are you using USB or FM downlink, and any frequency offset? My stock IC9700 + SatPC32 suggests 435310.555 (or close) as center freq, have tried on-center and offset 1600Hz. TIA, 73 de KS1G
Congratulations to K8DP for getting the first digipeat via GreenCube (1200 baud mode)!
https://twitter.com/kd8cao/status/1586922634628956161
And now we have the first complete contact via GreenCube - thanks to K8DP for being at the other end!
FYI, was surprised how easily I was heard by the satellite at that altitude using only 20w to a Wimo X-Quad (RHCP).
https://twitter.com/scott23192/status/1586979990050164737
Here is the latest TLE set for GREENCUBE calculated by @PE0SAT:
GREENCUBE
1 53106U          23032.60000000  .00000000  00000-0  00000-0 0    04
2 53106  70.1702   6.8427 0008914 347.3292 274.0137  6.42558032    02
EDIT: Due to a typo I did, the initial TLE set was calculated for the wrong epoch. I’ve updated the above TLE set with the right epoch.
TLE for TRISAT-R by @PE0SAT
TRISAT-R
1 53108U          24087.41666667  .00000000  00000-0  00000-0 0    03
2 53108  70.1723 218.4492 0013148 124.7464  62.5563  6.42152367    07
