Today @azisi made a timelapse video of a v3 SatNOGS assembly.
I think it might help people that are trying to assemble a v3 SatNOGS rotator.
Especially if you adjust the player speed at 0.25
Here in his latest docs, I’ve noticed the split aluminum tubing… why was that chosen to connect the arms to the rotator? Why not use nesting pipe with two more of the long bolts/nuts (like a cotter pin, but just reuse the same parts to reduce complexity) to secure the three pieces of pipe together? That’d reduce the weight, simplify assembly steps (no longer cutting notches out of tubing), and reduce the number of different parts.
Tubing with half cutout on the edges, is a typical way of connecting pipes-masts together. Many other rotators (radio amateur ones) do the same thing and it provides flexibility with different diameters and ease of assembly.
Check out how the connection turns out to be at the end:
