What size fuse should we be using on the v2 controller?
Are the CTS / DTR pins required to be connected? I plan on hooking up a raspberry pi 3, and I think you have to do some modifications to enable CTS/DTR
What’s the power requirements for this board? I see a drawing on the wiki that shows 16 to 60 volts (36 - 48 watts) is that correct?
Off topic, what all free analog /digital pins are available on the Arduino Mini? I’m thinking about playing around with external led displays or compass modules.
