Hello,
Anyone using an Ettus USRP2 with SatNOGS. I see the concerns with wide IP bandwidths
and PI 3 MIPS/FLOPs.
Thank you. Using a RTL-SDR.com but would sure like to use the UBX noise figure. HI
73,
Guy W6MSU
Station 754
Hello,
73,
Guy W6MSU
Station 754
Based off https://gitlab.com/librespacefoundation/satnogs/gr-satnogs/blob/master/python/hw_settings.py
I think the USRP2 is supported.
https://photos.app.goo.gl/MFDbr2fiRR6HCK3AA
Thank you. I’ll have to give it a try.
73,
Guy W6MSU
Station 754
Yes, the ettus devices can sample low enough that the rpi usb is not an issue (I run a b200 mini on my station most of the time)
cheers!
that said - I’ll be interested in your results with the rtl-sdr.com dongle vs b200 - so far for our work in vhf/uhf I’ve found no noticeable difference. (that will likely change when we tackle higher bands)
Thank you. Now there’s a thought. Plug in a B100 (USB2.0) and see if UHD wants to play.
The USRP2/N200 with the UBX daughter board is less than 1 dB noise figure, and real shielding.
TU 73,
Guy - W6MSU
Station 754
From the datasheet, it looks like the B200 mini has an NF <8dB. How much worse can the R820T be?
