Use gr-satnogs standalone
I am trying to use the gr-satnogs GNU flowcharts in a standalone way.
Most of the blocks are red (in error). I thing it is due to some variables are not
configured / missing. I got a lot of errors like this:
Param - Value(value):
Value “satnogs.fm_demod_settings[rx_sdr_device][‘audio_gain’]” cannot be evaluated:
‘module’ object has no attribute ‘fm_demod_settings’
Any idea about how to solve it? Is there anything I should configure before opening the flowchart
in GRC.
I am looking for a FSK9600 generic demodulator. As input I am planning to use a file (ogg, wav).
Regards,
Alberto
Did you build and install the package as explained in the readme?
Yes, I did.
I have opened the file directly. I mean I have not selected any block on the right side.
I hope it helps.
Regards,
Alberto
Ok, just wanted to check that you did the basic build & install steps. I am not familiar with the gr-satnogs package so I can not tell if additional configuration is required. Hopefully someone with more knowledge can help.
Open a python console and type:
import satnogs
Does python successfully imports the module?
Yes, it works.
No errors.
Alberto
So maybe is the GRC. Can you post the output of Help->Parser errors ?
I have already solved the issue. The problem was the installation path of the gr-satnogs in my Linux Mint. So, I copy the libgr-satnogs.so library to the expected path (/usr/local/lib) and all errors are gone now.
Many thanks,
Alberto
