UPMSat-2 object 46276
Hi
I have a question regarding on how to identify a closest object transmitting at the same frequency when passes over a GS.
Observation #7054703 and #7096731 show an object transmitting a wideband signal very close to de UPMSat-2.
So, is there an easy way to check which object have a similar path? Or any software tool to do this calculations?
That is all.
Thanks in advance.
Rafael
This is the usual process:
  1. Find all the satellites that transmit on similar frequency in SatNOGS DB. This can be done in the transmitters page. Here is a list of satellites that transmit ±65.1KHz:
40320, 41603, 43907, 39431, 40968, 39435, 39439, 39440, 32788, 43156, 39446, 43677, 43679, 43681, 39463, 39087, 52148, 41783, 40377, 27844, 38340, 46276, 43721, 47945, 40012, 40014, 37841, 33493, 41558, 52950, 53463, 49017, 33499, 47964, 28895, 47458, 40931, 43880, 38761, 38763, 39153, 53107, 41460, 49396, 46839, 40056, 39417, 41339, 41340
  1. Then you can find the TLE sets at the time of the observations. I usually use space-track.org, for example for the 7096731:
0 CUTE-1
1 27844U 03031E   23029.56233204  .00000384  00000-0  19112-3 0  9995
2 27844  98.6797  38.8504 0010158 161.5721 198.5827 14.22606325 16029
0 CUBESAT XI 5
1 28895U 05043F   23030.34212309  .00001548  00000-0  29785-3 0  9998
2 28895  98.1313 163.7058 0017024 144.0193 216.2160 14.64925289920857
0 AAUSAT CUBESAT 2
1 32788U 08021F   23030.19983001  .00006999  00000-0  56407-3 0  9996
2 32788  97.5538  13.1262 0010315  87.3390 272.9014 15.00171779802498
0 PRISM (HITOMI)
1 33493U 09002B   23030.47165659  .00006536  00000-0  49276-3 0  9995
2 33493  98.2521  35.6943 0018990 141.4774 218.7808 15.02696116763047
0 KKS-1 (KISEKI)
1 33499U 09002H   23030.17776825  .00001334  00000-0  19915-3 0  9999
2 33499  98.1910 280.6391 0007981 317.1359  42.9227 14.76491868754120
0 SRMSAT
1 37841U 11058D   23029.95252694  .00000462  00000-0  10893-3 0  9992
2 37841  19.9732 325.7595 0011708 312.6948 114.3499 14.10823168583261
0 HORYU 2
1 38340U 12025D   23029.89104652  .00002203  00000-0  31645-3 0  9998
2 38340  98.1779 116.5717 0010458 217.8427 142.2048 14.77474699565665
0 AAUSAT3
1 39087U 13009B   23030.03086562  .00001188  00000-0  41936-3 0  9992
2 39087  98.3836 228.7675 0012094 314.7228  45.2933 14.36461644520109
0 CUBEBUG 1
1 39153U 13018D   23030.23373639  .00002290  00000-0  29077-3 0  9999
2 39153  98.0248 145.7366 0015379 232.3474 127.6344 14.82597036527428
0 ZACUBE
1 39417U 13066B   23030.17276471  .00003725  00000-0  44638-3 0  9998
2 39417  97.6674 356.9619 0057063  22.8526 337.5208 14.83498031496727
0 BRITE-PL
1 39431U 13066R   23030.24935611  .00001013  00000-0  22450-3 0  9996
2 39431  97.6800 228.5702 0199542 245.5491 112.4774 14.47617601485378
0 WREN
1 39435U 13066V   14099.35188471  .00002386  00000-0  27506-3 0  9992
2 39435  97.7868 174.0379 0056077 109.7041 251.0236 14.85489138 20584
0 FIRST-MOVE
1 39439U 13066Z   23030.39669613  .00007673  00000-0  84339-3 0  9998
2 39439  97.6650   0.3080 0060352  15.1041 345.1959 14.86558239496828
0 CUBEBUG 2
1 39440U 13066AA  23030.40871482  .00002323  00000-0  31233-3 0  9993
2 39440  97.7565 343.9208 0078893 114.5306 246.4155 14.78029506494999
0 UWE-3
1 39446U 13066AG  23030.44119882  .00002942  00000-0  37441-3 0  9996
2 39446  97.7172 350.2214 0068922  69.6035 291.2563 14.80635897494628
0 FIREBIRD A
1 39463U 13072B   23029.79107080  .00024670  00000-0  10454-2 0  9991
2 39463 120.4342 323.4998 0144257 191.5758 168.1975 15.14139769185232
0 UNISAT 6
1 40012U 14033C   23030.40295215  .00002474  00000-0  35897-3 0  9996
2 40012  97.6621 211.3946 0057148 142.5348 217.9867 14.75755755463440
0 BUGSAT 1
1 40014U 14033E   23029.96457730  .00005176  00000-0  44046-3 0  9997
2 40014  98.1459  42.8289 0029978   9.8256 350.3542 14.97945046470030
0 NLS 7.2/CANX 5
1 40056U 14034D   23030.43630518  .00001281  00000-0  19424-3 0  9990
2 40056  98.3765 200.2016 0014116   0.5664 359.5558 14.75920334462224
0 FIREBIRD 3
1 40377U 15003B   23030.32420296  .00047945  00000-0  10042-2 0  9994
2 40377  99.0774 312.2978 0075232 332.8089  26.9221 15.42233469443218
0 LAPAN A2
1 40931U 15052B   23030.01487247  .00001475  00000-0  11532-3 0  9993
2 40931   5.9949 352.6646 0012468 137.1238 223.0073 14.77006129396892
0 CHUBUSAT 3
1 41339U 16012C   23030.22424389  .00004319  00000-0  31055-3 0  9996
2 41339  31.0126  15.8990 0012991 252.7887 107.1180 15.02528691381603
0 HORYU 4
1 41340U 16012D   23030.26612850  .00005802  00000-0  38901-3 0  9999
2 41340  31.0057 348.8476 0012783 298.2176  61.7170 15.05321517381909
0 AAUSAT 4
1 41460U 16025E   23030.09289453  .00057616  00000-0  15828-2 0  9998
2 41460  98.1753 227.2000 0096081 183.7015 297.2421 15.32421486372467
0 NUSAT 2
1 41558U 16033C   23030.45427860  .00035748  00000-0  75470-3 0  9993
2 41558  97.4124 141.7315 0008381 271.7830 152.5148 15.45081299372587
0 LAPAN A3
1 41603U 16040E   23030.48035600  .00002765  00000-0  12556-3 0  9991
2 41603  97.1825  62.3697 0014791  82.4412  57.9625 15.21482145366545
0 PRATHAM
1 41783U 16059A   23030.08057375  .00000638  00000-0  13060-3 0  9997
2 41783  97.8874  67.2401 0033393 175.3654 184.7865 14.63624813338775
0 ZHOU ENLAI
1 43156U 18008B   23030.37885889  .00016097  00000-0  75607-3 0  9991
2 43156  97.3268  86.5872 0013348  75.8141  52.7049 15.19614667277602
0 TEN-KOH
1 43677U 18084G   23030.38053175  .00002484  00000-0  25079-3 0  9992
2 43677  97.9896 168.0379 0014490 242.2894 117.6854 14.91946187231503
0 STARS-AO
1 43679U 18084J   23030.35254537  .00004288  00000-0  39757-3 0  9998
2 43679  98.0011 174.4065 0007424 260.4420  99.5961 14.94989501231827
0 AUTCUBE 2
1 43681U 18084K   23030.07961830  .00003644  00000-0  34660-3 0  9994
2 43681  97.9971 172.4040 0007819 255.4316 104.6037 14.94073927231671
0 FACSAT-1
1 43721U 18096C   23030.49561058  .00069092  00000-0  11692-2 0  9994
2 43721  97.3292 116.6468 0010349 309.0347 181.4500 15.51278061232952
0 UWE-4
1 43880U 18111E   23029.71322607  .00004293  00000-0  34972-3 0  9995
2 43880  97.6567 297.1127 0011765 285.7123  74.2803 14.99972163223598
0 ZACUBE-2
1 43907U 18111AH  23030.37418618  .00019411  00000-0  61248-3 0  9991
2 43907  97.1603 273.8023 0017709 357.5260 118.6827 15.32740242227989
0 UPMSAT-2
1 46276U 20061E   23029.70090925  .00005763  00000-0  26661-3 0  9997
2 46276  97.3661 100.3230 0002719  93.8395 266.3151 15.20520521133222
0 OBJECT N
1 46839U 20079N   23030.17710943  .00098471  00000-0  11548-2 0  9998
2 46839  97.1687 106.1368 0004288 223.9123 220.2325 15.61171020125333
0 IDEASSAT
1 47458U 21006AX  23030.10330125  .00009110  00000-0  44337-3 0  9995
2 47458  97.4137  89.6690 0009354 203.4993 156.5815 15.18568486111613
0 UNISAT 7
1 47945U 21022P   23029.71159379  .00004241  00000-0  26823-3 0  9999
2 47945  97.5108 289.8463 0019281  83.7481 276.5943 15.09394014102020
0 SMOG-1
1 47964U 21022AJ  23029.67944038  .00013438  00000-0  72972-3 0  9993
2 47964  97.5132 291.7278 0019095  79.1079 281.2301 15.14488321101064
0 IT-SPINS
1 49017U 21013G   23030.18448075  .00016870  00000-0  53509-3 0  9990
2 49017  51.5977  30.5464 0007024 163.9873 196.1331 15.32774772 88475
0 TEIKYOSAT-4 (OORURI)
1 49396U 21102B   23029.88570828  .00001682  00000-0  13445-3 0  9996
2 49396  97.5411  86.0456 0013654 207.1934 152.8577 15.01487754 67015
0 KITSUNE
1 52148U 98067TK  23030.13833510  .00155386  00000-0  81066-3 0  9994
2 52148  51.6315 268.7673 0002055 161.8854 334.0593 15.79898007 48695
0 CTIM
1 52950U 22074G   23030.39337601  .00032382  00000-0  10799-2 0  9992
2 52950  45.0057  42.2306 0007647  51.4076 308.7471 15.30556861 32407
0 OBJECT C
1 53107U 22080C   22364.14200119 -.00000003  00000-0  00000-0 0  9997
2 53107  70.1674  18.5562 0013489 216.1674 143.8074  6.42110599 10793
0 FUTABA
1 53463U 98067UC  23030.05996526  .00353583  00000-0  12117-2 0  9992
2 53463  51.6271 276.7495 0005081 172.1249 187.9836 15.88194797 26699
  1. Finally with the TLE list you can use ikhnos and find which of these TLE sets fit the other signal. Have in mind that for fitting exactly at the signal you need to adjust the frequency offset parameter.
Ok, I see.
Thank you for full details!
Rafael
Found the satellite: UNISAT-7.
Thanks to the help from IDR/UPM team engineer, Juan Bermejo found the the object with in turn the help of ikhnos program.
That satellite it is declined for transmission on amateur satellite service UHF band acording to IARU, but still transmitting.
Rafael,
EA4BPN
