Hello,
I installed the last satnogs buster image on my raspberry.
I did an update using satnogs-setup, then I applied the same configuration of stretch image.
My station doesn’t upload neither waterfall or audio to servers, but its satus is “Online” on the dashboard and the client version now shows 1.4.
My rtlsdr is working properly and rtl_test doesn’t show any issue.
I already searched on the forum for similar problems, but I still can’t fix the problem.
Any help will be appreciated.
Here below my support log:
“versions”: {
“satnogs-client”: “1.4”,
“satnogs-client-ansible”: “202012042053”,
“satnogs-flowgraphs”: “1.2.2-1”,
“gr-satnogs”: “2.1.2.1-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.2.0-2”,
“satnogs-config”: “0.11”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2020-12-11T09:21:04.817745+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “raspberrySatnogs”,
“release”: “5.4.79-v7+”,
“version”: “#1373 SMP Mon Nov 23 13:22:33 GMT 2020”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 969768960,
“available”: 834207744,
“percent”: 14.0,
“used”: 61972480,
“free”: 343154688,
“active”: 252190720,
“inactive”: 219721728,
“buffers”: 82755584,
“cached”: 481886208,
“shared”: 6483968,
“slab”: 138764288
“disk”: {
“total”: 15377764352,
“used”: 3752955904,
“free”: 10946605056,
“percent”: 25.5
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_rf_gain”: “49.2”,
“satnogs_soapy_rx_device”: “rtlsdr”,
“satnogs_station_elev”: “30”,
“satnogs_station_id”: “377”,
“satnogs_station_lat”: “41.248”,
“satnogs_station_lon”: “16.421”
Thanks in advance,
Alfredo IZ7BOJ
