Upload process/job
Hurray an ogg file is in the tmp space :smile:
but for some reason there is no upload to the repository. so i ask which py is doing this job and do i have to setup an supervisor definition for that?
asking for some ideas where to look at, br Robert
Congrats!!
The uploads are attempted every 15 minutes so it may be a matter of time. Is the ogg file in the โ€œcompleteโ€ directory? What is the filename and what was the URL of the observation?
Check your log for a traceback if it is failing to upload.
This used to be a known bug in the past but it should be fixed now for most of the cases. Make sure you are using the latest version (0.2.4) for the client.
For the reference, this is the task that handles file uploading:
