Update SatNOGS Client
Hi!
My GS#810, I have been working on the update SatNOGS Client but, I don’t know if it was successful because initially it had the tag version ‘2017102100’. At the end I get the following message:
Checking the latest versions:
Finally when I want to schedule an observation, I only get:
¡Thanks for help me!
Hi @diazelkyn from the latest observations of your station in Network it seems that it is updated and is working fine. However it seems that something is wrong with your reception, for example this NOAA observation should had some signal, as NOAA are very loud.
I would suggest check again your station, maybe a broken cable or a non-well attached antenna could cause the issue of not receiving. If everything is well, try to experiment with different gains, you can also check this guide https://wiki.satnogs.org/Omnidirectional_Station_How_To#Setting_the_gain.
