Unknown satellite on 436.700 in 2k4 AX100
Please identify this satellite.
2024-08-10 13.4xutc with beacons in 10 seconds interval.
3 beacons, decodable in both versions (0.05b and 0.09b) of UZ7HO’s High-Speed SoundModem for 1KUNS-PF.
436.700 2k4 AX100 2024-08-10 13.4xutc in 10sec interval.wav.zip (313.0 KB)
It’s not zipped, just remove the suffix (.zip).
I’m guessing 43768 - AISTECHSAT-2
but frequency maybe doesn’t match.
Thanks for you reply.
Version 0.09b of the SoundModem won’t decode Aistechsat-2 and apart from a different frequency, it additionally doesn’t send in 2k4.
So, it has to be another satellite.
What does the frames contain ?
Using version 0.09b it’s:
[priority:2 src:3 src_port:39 dest:8 dest_port:31 len:120 FEC_err:0 RS_err:5]
86 87 E7 01 4D 49 4D 41 4E 08 9C C0 8E 00 64 00 3A BD 1B E4 7C 00 00 00 00 1A BD 3A 00 B4 19 06 3C 01 0C 29 1A 00 39 00 80 F2 33 30 00 52 02 61 24 B8 12 25 2D A7 00 BD 00 12 00 FF FF 66 00 00 00 00 00 FF FF 66 00 00 00 00 00 EF 0C 25 05 1E 13 75 24 4A 00 D7 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AA BC 1D 00 A2 3B 01 67 59 25 D6
[priority:2 src:3 src_port:50 dest:8 dest_port:31 len:120 FEC_err:0 RS_err:8]
86 87 F2 01 4D 49 4D 41 4E 08 9C C0 A0 00 64 00 3A BD 75 E4 7D 00 00 00 00 74 BD 3A 00 B4 19 06 3C 01 0C 2A 1A 00 39 00 80 34 33 CF FF 5D 02 FC 1F F8 11 DB 27 2B 00 C8 00 43 00 00 00 64 00 FF FF FF FF 00 00 64 00 FF FF FF FF EE 0C 34 05 43 11 EF 20 27 00 9C 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AA BC 1D 00 A2 3B 01 34 16 7F 40
[priority:2 src:3 src_port:56 dest:8 dest_port:31 len:120 FEC_err:0 RS_err:9]
86 87 F8 01 4D 49 4D 41 4E 08 9C C0 A3 00 64 00 3A BD 87 E4 7C 00 00 00 00 86 BD 3A 00 B4 19 06 3C 01 0C 2A 1A 00 39 00 80 37 33 CC FF 5E 02 C6 1D 16 12 23 22 AF 00 9C 00 1A 00 FF FF 65 00 FF FF 00 00 FF FF 65 00 FF FF 00 00 EC 0C 39 05 52 12 02 1E 28 00 AB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AA BC 1D 00 A2 3B 01 49 E1 B8 E6
oh, it’s MIMAN!
M I M A N
https://db.satnogs.org/satellite/52900
200 kHz above its frequency and not 4k8 as mentioned, but in 2k4.
MIMAN is 2k4 according to satyaml
You are right, and the 5 times I’ve received and decoded it back in 2022 it was also 2k4. But it’s still mentioned as 4k8 on db.satnogs.org.
I’ll submit a new transmitter.
The last reception with data was 2024-07-20 in 2k4.
TX approved
