This morning I’ve had a great pass with lots of data on file transfers being sent. Also The TLS issue has now been fixed thanks to @dl7ndr
Hi!
The “UMKA from Space” program is scheduled to broadcast children’s drawings from August 16, 22:22 UTC to August 18, 18:45 UTC.
Format - SSTV Robot36
Intervals - 2 min.
Frequency - 437.625 MHz
SSTV broadcast may be rescheduled or interrupted if necessary without prior notice! (temperature increase, battery discharge, etc.)
!!! intervals increased to 250 sec
Jomjom79
This morning I saw two transmissions, the first was at low elev with poor signal and the second was at max pass elev of 86.3 degrees
2024-08-17 09:34 UTC
2024-08-17 09:38 UTC
Ill come back in 10hrs from now for the next high elev pass as the next passes are only 12-13 degrees
2024-08-17 09:33 UTC
2024-08-17 09:37 UTC
11:09 UTC. 20 degree elevation while passing over Iceland.
Jomjom79
Do you use any filter to get these razor-sharp images?
2024-08-17 18:49 UTC
2024-08-17 18:53 UTC
2024-08-17 20:24 UTC
2024-08-17 20.29 UTC
20:28 UTC
Jomjom79
By the looks of the text it is probably AI enhanced.
That’s right ![]()
can you share the original images? I’m interested in seeing how much of a difference the AI enhancement has made.
2024-08-18 09.30 UTC
18/8/24 09.29UTC
Jomjom79
2024-08-18 09:25 UTC
2024-08-18 09:29 UTC
UmKA-1 over Brazil at 2024-08-18 11:20UTC
73’s de PU4ELT
based on the quality of all these images I think I need to buy a new antenna, and add a preamp
