hi all,
wanted to give my client a clean over and started with a fresh installation of 2022-09-10-raspbian-satnogs-lite. doing the first config and update i run in this error:
Download UHD images…
- localhost failed | msg: non-zero return code | stderr: [INFO] Using base URL: files.ettus.com:/binaries/cache/*
[INFO] Images destination: /usr/share/uhd/images
[INFO] No inventory file found at /usr/share/uhd/images/inventory.json. Creating an empty one.
[ERROR] Downloader raised an unhandled exception: URL does not exist: https://files.ettus.com/binaries/cache/x3xx/fpga-9ba275de0b/x3xx_x310_fpga_default-g9ba275de.zip
You can run this again with the ‘–verbose’ flag to see more information
If the problem persists, please email the output to: support@ettus.com
The issue is persistant even after raspian update/upgrade.
The file does exist and i can download it via wget… strange…
Someone any idea how to get around this issue since i use just rtldongle for reception?
br Robert, 73 de oe6rke
