With satnogs-client-ansible-202001181213, satnogs-client-1.0+18.g74d8eec, gr-satnogs-1.5.1+127+gd6e66880-1:
Jan 25 13:24:56 rpi3bp systemd[1]: satnogs-client.service: Succeeded.
Jan 25 13:24:56 rpi3bp systemd[1]: Stopped SatNOGS client.
Jan 25 13:24:56 rpi3bp systemd[1]: Started SatNOGS client.
Jan 25 14:10:05 rpi3bp satnogs-client[15875]: Found 1 device(s):
Jan 25 14:10:05 rpi3bp satnogs-client[15875]: 0: Realtek, RTL2838UHIDIR, SN: 00000001
Jan 25 14:10:05 rpi3bp satnogs-client[15875]: Using device 0: Generic RTL2832U OEM
Jan 25 14:10:05 rpi3bp satnogs-client[15875]: Found Rafael Micro R820T tuner
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: 2020-01-25 14:10:06,519 - apscheduler.executors.default - ERROR - Job "spawn_observer (trigger: date[2020-01-25 14:10:05 UTC], next run at: 2020-01-25 14:10:05 UTC)" raised an exception
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: Traceback (most recent call last):
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: File "/usr/lib/python2.7/dist-packages/apscheduler/executors/base.py", line 125, in run_job
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: retval = job.func(*job.args, **job.kwargs)
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py", line 74, in spawn_observer
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: observer.observe()
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/observer.py", line 144, in observe
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: self.observation_decoded_data)
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/upsat/gnuradio_handler.py", line 53, in exec_gnuradio
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: script_name, '--soapy-rx-device=' + device, '--samp-rate-rx=' + str(samp_rate),
Jan 25 14:10:06 rpi3bp satnogs-client[15875]: TypeError: cannot concatenate 'str' and 'NoneType' objects
Would anyone be able to help me understand and correct this error?
Andreas / VA2WBT
