Tutorial: Comparing 2 TLE for Noobs : COSMOS 2612 vs ICEYE-X36
inspired from this post
as noobs, i try to calculate this two satellites using swiss knife for satellites enthusiast sattools by @cgbsat
first we update our catalog tle
tleupdate
then open the catalog.txt and search both satellites :
1 68762U 26083H   26292.31448618  .00002307  00000-0  15841-3 0  9998
2 68762  97.8540  72.8115 0003973 302.2888  57.7953 15.07013899 27885
1 59103U 24043F   26292.31404130  .00003675  00000-0  24428-3 0  9992
2 59103  97.8540  72.8120 0004445 255.4996 104.5739 15.07830592143849
save as join.txt
as seen, both tle have different epoch time. so we should make it same. we should adjust and make both tle have same epoch, in this example i set the epoch = 2026-10-19T07:35:00
propagate -c join.txt -t 2026-10-19T07:35:00 > join-propagate.txt
result :
1 68762U 26083H   26292.31597222  .00000000  00000-0  15841-3 0    05
2 68762  97.8540  72.8130 0000000 359.3474   8.7920 15.07014639    02
1 59103U 24043F   26292.31597222  .00000000  00000-0  24428-3 0    09
2 59103  97.8540  72.8140 0000000  71.4904 299.0542 15.07833408    00
then open with skymap
skymap -c join-propagate.txt
press h for help
press > to make the satellite track more length
press . to fast forward the time
press l to change the interval
press c and click to move the cursor
press + / - for zoom
result :
as seen on above screenshot we see the satellites on sky at 2026-10-19T07:35:00 UTC
now press i , to see the current offset.
press i and click on screen many time, until you see both satellites offset , result :
Age: 0.0 d
x:   +2152.6083 km; vx: +0.66470 km/s
y:   +6512.4257 km; vy: -1.32314 km/s
z:    +957.1207 km; vz: +7.44293 km/s
r:   13290.28 km; v:  -0.025 km/s
l: -69.84; b:   7.94; h:     547.29 km
R.A.:  04:56:28.53  Decl.:  08:18:13.4
R.A.:  04:55:01.11  Decl.:  08:15:44.8 (J2000)
Azi.: 99.3 Alt.: -87.4
Phase: 49.42
Magnitude: 15.00
Angular velocity: 0.0325 (deg/s)
Age: 0.0 d
x:   +2175.3286 km; vx: +0.56512 km/s
y:   +6453.6728 km; vy: -1.62209 km/s
z:   +1240.9949 km; vz: +7.39350 km/s
r:   13284.69 km; v:  -0.179 km/s
l: -70.17; b:  10.33; h:     544.44 km
R.A.:  04:55:48.72  Decl.:  09:32:47.8
R.A.:  04:54:20.54  Decl.:  09:30:17.7 (J2000)
Azi.: 73.4 Alt.: -87.1
Phase: 49.13
Magnitude: 15.00
now to measure the offset in kilometre, i attach in this post the offset.py, python script to calculate the offset
offset.py.txt (1.8 KB)
run the offset.py, and paste all above offset data
./offset.py
result:
Extracted positions:
Position 1: [2152.6083 6512.4257  957.1207]
Position 2: [2175.3286 6453.6728 1240.9949]
Offsets:
Position 1 → Position 2
Difference vector: [ 22.7203 -58.7529 283.8742] km
Offset: 290.77942966472 km
so both satellites apart around 290.78 km (2026-10-19T07:35:00 UTC)
fast forward to 20261019T14:15:00 UTC
Offsets:
Difference vector: [ -97.8949 -365.7449   92.113 ] km
Offset: 389.6633779187107 km
and both satellites apart around 389.66 km (2026-10-19T14:15:00 UTC)
join.txt (279 Bytes)
join-propagate.txt (280 Bytes)
Why is this step necessary?
Sidenote, looking at the Celestrak data page we can see COSMOS-2612 raised its orbit by ~2km between 2026-10-18 12:25 and 23:34 UTC. So I guess the RPO is over (for now).
yes.
based on space-track tle, the closest tle occured at 2026-10-18T07:38 UTC = 6.11 KM
1 59103U 24043F   26291.31860976  .00003914  00000-0  25995-3 0  9991
2 59103  97.8542  71.7953 0004429 260.0318 100.0410 15.07823629143698
1 68762U 26083H   26291.31861747  .00002270  00000-0  15278-3 0  9992
2 68762  97.8541  71.7953 0004465 259.9972 100.0752 15.07776700 27733
Age: -0.0 d
x:   +2111.5225 km; vx: +1.10897 km/s
y:   +6584.3238 km; vy: +0.05965 km/s
z:    -371.3960 km; vz: +7.50691 km/s
r:   13223.23 km; v:   0.675 km/s
l: -69.09; b:  -3.07; h:     546.44 km
R.A.:  04:57:03.42  Decl.:  02:33:39.9
R.A.:  04:55:39.49  Decl.:  02:31:12.7 (J2000)
Azi.: 160.0 Alt.: -83.4
Phase: 51.30
Magnitude: 15.00
1 59103U 24043F   26291.31875000  .00000000  00000-0  25995-3 0    01
2 59103  97.8542  71.7954 0000000  30.0142 330.8232 15.07824244    06
Age: -0.0 d
x:   +2112.3716 km; vx: +1.10695 km/s
y:   +6584.2320 km; vy: +0.05327 km/s
z:    -365.3406 km; vz: +7.50734 km/s
r:   13223.64 km; v:   0.672 km/s
l: -69.10; b:  -3.02; h:     546.29 km
R.A.:  04:57:02.54  Decl.:  02:35:14.2
R.A.:  04:55:38.60  Decl.:  02:32:46.9 (J2000)
Azi.: 159.9 Alt.: -83.5
Phase: 51.29
Magnitude: 15.00
Position 1: [2111.5225 6584.3238 -371.396 ]
Position 2: [2112.3716 6584.232  -365.3406]
Offsets:
Difference vector: [ 0.8491 -0.0918  6.0554] km
Offset: 6.115330507012692 km
and if we use this TLE, the closest between both satellites occured at 2026-10-18T00:23:50 UTC = 0.141 km = 141 metre
Age: -0.3 d
x:   -1801.8179 km; vx: -1.69643 km/s
y:   -6322.3495 km; vy: -1.96996 km/s
z:   +2165.4544 km; vz: -7.13189 km/s
r:   10779.09 km; v:  -1.122 km/s
l: -138.38; b:  18.23; h:     543.41 km
R.A.:  19:19:56.20  Decl.:  16:52:04.4
R.A.:  19:18:44.00  Decl.:  16:49:02.2 (J2000)
Azi.: 73.6 Alt.: -52.4
Phase: 89.92
Magnitude: 11.16
Angular velocity: 0.0391 (deg/s)
Age: -0.3 d
x:   -1801.7808 km; vx: -1.69646 km/s
y:   -6322.2213 km; vy: -1.96997 km/s
z:   +2165.4080 km; vz: -7.13196 km/s
r:   10778.98 km; v:  -1.122 km/s
l: -138.38; b:  18.23; h:     543.27 km
R.A.:  19:19:56.31  Decl.:  16:52:04.1
R.A.:  19:18:44.10  Decl.:  16:49:01.9 (J2000)
Phase: 89.92
Magnitude: 11.16
Position 1: [-1801.8179 -6322.3495  2165.4544]
Position 2: [-1801.7808 -6322.2213  2165.408 ]
Offsets:
Difference vector: [ 0.0371  0.1282 -0.0464] km
Offset: 0.1412961782924233 km
I created a Jupyter notebook for evaluating the latest TLE at any given time and calculating the separation. With that I get a minimum distance of 39m at 2026-10-18 06:33:20. This is far below the accuracy of SGP4, so don’t take that as a real value. Also at that point the COSMOS-2612 TLE was >12h old, it’s very possible it had already maneuvered away by then.
See the full notebook here.
Btw since you already use a Python script, I think you can skip the propagate/skymap steps and just propagate the TLEs directly from Python. With the skyfield library that’s about 10–20 lines of code.
