I am currently in the process of building a 435 mhz turnstile based upon the plans of I6IBE.
I have however run into some problems with the construction and specifically the distance between the active elements and the reflector.
I am trying to make this out of 32mm pvc pipe and i want all cable arrangements to stay inside the pipe and be terminated with a N connector at the bottom.
Using I6IBE measurements with a 13.8cm distance the reflector will end smack bang exactly where the balun/phasing line is, giving me next to no room for mounting the reflectors through the PVC pipe.
How important is 13.8cm which is 1/5th (?) the wavelength of the desired 435.500 mhz center frequency.
Any good reason why you cant use 1/4 wave at 17.2cm or even a 1/2 wave at 34.4cm?
Jomjom79
