Transporter-15 Rideshare: VSFB SLC-4E : 28 November 2025 - 18:44:30 UTC
MICE-1
1 98518U 25276Z   25345.50761227  .00000000  00000-0  85911-3 0 00002
2 98518  97.4491  57.2978 0004401 288.2412 177.0173 15.17054724 01824
Added in DB, thanks!
Hello again,
We have a new TLE for TMICROSAT-1:
TMICROSAT-1
1 98515U 25276Y   25347.12519372 +.00009703 +00000+0 +47621-3 0 00218
2 98515  97.4377  58.8963 0002080  99.7173 260.4296 15.18293117002180
Could you please help us to update it in the SatNOGS DB? Thank you so much!
Does anyone have a link to a doc describing the telemetry format from HUNITY ?
The smogcli repo does have a hunity_packets utility and looking through the source code, I can get some details, however (1) would still be good to have some actual doc. and (2) a lot of packets are not decoded by this utility. If packet start with 0xAA then they are processed, but I see a lot of packets starting wiht 0xCC and 0x66 that are valid (same CRC check and also I can see the right sequence number) but that utility does nothing with them.
( cc @therman89 )
Updated TLE for Foresail-1p, not fully accurate but better than the current one:
Foresail-1p
1 98467U 25000XX  25348.34721814  .00000000  00000-0  34877-4 0    09
2 98467  97.4424  59.4325 0003820  61.6496  69.1897 15.12995798    05
Hello,
We have a new TLE for T.MicroSat-1:
TMICROSAT-1
1 98515U 25276Y   25349.16824254 +.00004758 +00000+0 +23517-3 0 00237
2 98515  97.4378  60.9052 0001960  97.8803 262.2654 15.18318538002496
Could you please help us to update it in the SatNOGS DB? Thank you once again:)
Updated TLE for Foresail-1p, still not fully accurate, we will need more observations:
Foresail-1p
1 98467U 25000XX  25349.47094345  .00000000  00000-0  34399-4 0    05
2 98467  97.4424  60.8430 0003820  61.6496  81.0898 15.16988121    08
An updated more accurate TLE set for Foresail-1p:
Foresail-1p
1 98467U 25000XX  25350.20165767  .00000000  00000-0  30660-4 0    02
2 98467  97.4424  61.8953 0003820  61.6496 106.6592 15.14705462    07
foresail1p_350_v1.dat (630 Bytes)
sites.txt (12.1 KB)
FORESAIL-1P TLE
FORESAIL-1P
1 98467U 25000XX  25350.52391434  .00000000  00000-0  30660-4 0    09
2 98467  97.4424  63.3895 0003820  61.6496  65.6950 15.16410351    03
# 20251215.40-20251216.52, 49 measurements, 0.329 kHz rms
Hi all,
Sorry there was an error in the previous TLE for Black-Kite-1. Here is the updated one:
BLACK-KITE-1
1 98527U 14900A   25350.87784702 +.00007563 +00000-0 +71981-3 0    06
2 98527  97.4470  62.5624 0005079 312.6247 296.0374 15.17094934    09
Could this be uploaded instead to Satnogs Observation? Thank you all again so much!
Hello,
TMICROSAT-1
1 98515U 25276Y   25351.14535895 +.00005707 +00000+0 +28120-3 0 00250
2 98515  97.4380  62.8494 0001999  95.8095 264.3367 15.18340932002793
Hi all,
We managed to get full contact for BLACK-KITE-1 during an entire pass using analyst object 88127. Here it is modified for Satnogs ID.
BLACK-KITE-1
1 98527U 14900A   25351.16222408 +.00008965 +00000+0 +45631-3 0  0020
2 98527  97.4472  62.8474 0004826 266.0351  94.0331 15.17035036 00270
Could this be used instead for upcoming observations? Thank you!
Hello again,
TMICROSAT-1
1 98515U 25276Y   25352.13390562 +.00005355 +00000+0  26396-3 0 00274
2 98515  97.4380  63.8217 0002028  94.4339 265.7127 15.18352060002948
Could you please help us to update it in the SatNOGS DB? Thank you for your support!
space-track.org published 112 TLE for this launch (from 115 initially deployed, reminder that we expect at least 8 more satellites from the ION deployers), still in TBA (To Be Assigned) status, so we will wait for assignment before starting identification:
0 TBA - TO BE ASSIGNED
1 66666U 25276A   25352.16396933  .00002285  00000-0  18696-3 0  9999
2 66666  97.6577  64.0310 0003529 208.8559 151.2470 15.00316866  2900
1 66667U 25276B   25350.95595407  .00002734  00000-0  13949-3 0  9997
2 66667  97.4431  62.6577 0001764 248.3583 111.7463 15.17561117  2768
1 66668U 25276C   25351.76003801  .00017677  00000-0  89648-3 0  9991
2 66668  97.4291  63.3861 0007866 286.9005  73.1365 15.16976169  2884
1 66669U 25276D   25351.69272328  .00018867  00000-0  95268-3 0  9993
2 66669  97.4298  63.3265 0007805 291.2125  68.8275 15.17114392  2878
1 66670U 25276E   25352.15473501  .00017751  00000-0  89824-3 0  9995
2 66670  97.4320  63.7822 0007519 290.6203  69.4224 15.17054118  2949
1 66671U 25276F   25352.15242084  .00009971  00000-0  50735-3 0  9990
2 66671  97.4439  63.8116 0005125 272.6709  87.3938 15.17013631  2946
1 66672U 25276G   25352.15580959  .00003589  00000-0  18718-3 0  9991
2 66672  97.4412  63.8010 0005403 271.2980  88.7634 15.16580217  2942
1 66673U 25276H   25352.15343325  .00014079  00000-0  71437-3 0  9999
2 66673  97.4378  63.7958 0006101 288.8939  71.1633 15.17017874  2948
1 66674U 25276J   25352.74818130  .00003452  00000-0  17956-3 0  9995
2 66674  97.4387  64.3803 0004985 273.0795  86.9868 15.16702866  3035
1 66675U 25276K   25352.74680461  .00008876  00000-0  45301-3 0  9990
2 66675  97.4420  64.3862 0005585 278.0957  81.9643 15.16934851  3038
1 66676U 25276L   25352.15422640  .00005501  00000-0  28376-3 0  9994
2 66676  97.4405  63.8014 0004842 278.3689  81.6995 15.16739684  2948
1 66677U 25276M   25352.14844480  .00011198  00000-0  56362-3 0  9999
2 66677  97.4400  63.8069 0003964 286.6356  73.4442 15.17368084  2940
1 66678U 25276N   25352.15375401  .00005692  00000-0  29304-3 0  9991
2 66678  97.4439  63.8099 0004869 270.6300  89.4375 15.16792399  2944
1 66679U 25276P   25352.15455429  .00003233  00000-0  16863-3 0  9996
2 66679  97.4379  63.7955 0004626 279.7525  80.3186 15.16652049  2945
1 66680U 25276Q   25352.68127125  .00002404  00000-0  12580-3 0  9996
2 66680  97.4420  64.3250 0004858 266.1447  93.9231 15.16775108  3022
1 66681U 25276R   25352.74372800  .00013617  00000-0  68530-3 0  9990
2 66681  97.4349  64.3764 0005021 293.3677  66.7028 15.17319715  3035
1 66682U 25276S   25352.74525024  .00008422  00000-0  42852-3 0  9996
2 66682  97.4473  64.4031 0004776 258.2079 101.8619 15.17063086  3038
1 66683U 25276T   25352.15210977  .00006788  00000-0  34714-3 0  9991
2 66683  97.4465  63.8178 0004620 262.7928  97.2781 15.16958791  2948
1 66684U 25276U   25352.14983106  .00010646  00000-0  53837-3 0  9997
2 66684  97.4490  63.8272 0004421 261.2980  98.7753 15.17214477  2945
1 66685U 25276V   25352.74248161  .00011596  00000-0  58357-3 0  9996
2 66685  97.4434  64.3984 0004042 282.9653  77.1129 15.17362870  3036
1 66686U 25276W   25352.74494463  .00002345  00000-0  12221-3 0  9997
2 66686  97.4469  64.4041 0004134 263.6448  96.4315 15.16950372  3030
1 66687U 25276X   25352.74944544  .00007004  00000-0  36132-3 0  9992
2 66687  97.4402  64.3789 0008202  67.9695 292.2409 15.16623317  3031
1 66688U 25276Y   25352.74423155  .00005176  00000-0  26503-3 0  9992
2 66688  97.4446  64.3997 0003634 268.0011  92.0806 15.17029942  3033
1 66689U 25276Z   25352.80721005  .00002301  00000-0  11923-3 0  9992
2 66689  97.4427  64.4657 0001397 294.5577  65.5510 15.17177931  3042
1 66690U 25276AA  25352.15059630  .00004849  00000-0  24867-3 0  9990
2 66690  97.4410  63.8075 0003569 271.4775  88.6049 15.17009213  2948
1 66691U 25276AB  25352.14927533  .00008397  00000-0  42549-3 0  9995
2 66691  97.4435  63.8150 0003708 272.1129  87.9679 15.17213352  2948
1 66692U 25276AC  25352.14653611  .00005556  00000-0  28172-3 0  9999
2 66692  97.4435  63.8224 0001886 298.0550  62.0493 15.17348070  2945
1 66693U 25276AD  25352.14713996  .00011956  00000-0  59941-3 0  9992
2 66693  97.4387  63.8053 0003378 297.6825  62.4066 15.17490576  2949
1 66694U 25276AE  25352.14528391  .00006971  00000-0  35110-3 0  9999
2 66694  97.4431  63.8198 0001436 292.0507  68.0574 15.17491302  2943
1 66695U 25276AF  25352.13689261  .00008314  00000-0  40998-3 0  9996
2 66695  97.4414  63.8268 0001052 152.3697 207.7593 15.18174994  2944
1 66696U 25276AG  25352.14727924  .00007452  00000-0  37667-3 0  9998
2 66696  97.4402  63.8094 0002577 293.7336  66.3627 15.17343231  2940
1 66697U 25276AH  25352.73100163  .00006558  00000-0  32485-3 0  9993
2 66697  97.4406  64.4060 0000920 158.5426 201.5847 15.18099865  3033
1 66698U 25276AJ  25352.74146776  .00006289  00000-0  31901-3 0  9998
2 66698  97.4404  64.3925 0002761 280.6770  79.4152 15.17279574  3032
1 66699U 25276AK  25352.14784013  .00007597  00000-0  38427-3 0  9998
2 66699  97.4420  63.8131 0003071 281.0974  78.9914 15.17309221  2942
1 66700U 25276AL  25352.59869353  .00007366  00000-0  36390-3 0  9992
2 66700  97.4437  64.2854 0001286 172.5789 187.5465 15.18150294  3016
1 66701U 25276AM  25352.14785251  .00007488  00000-0  37893-3 0  9992
2 66701  97.4440  63.8179 0003075 280.5231  79.5656 15.17299423  2946
1 66702U 25276AN  25352.67529053  .00007287  00000-0  36859-3 0  9995
2 66702  97.4417  64.3296 0002969 285.0854  75.0051 15.17324796  3021
1 66703U 25276AP  25352.67390704  .00002662  00000-0  13691-3 0  9996
2 66703  97.4420  64.3330 0000891 279.7714  80.3419 15.17304975  3026
1 66704U 25276AQ  25352.13836454  .00005874  00000-0  29194-3 0  9998
2 66704  97.4401  63.8177 0001463 186.9906 173.1308 15.18024025  2941
1 66705U 25276AR  25352.73129110  .00005472  00000-0  27177-3 0  9992
2 66705  97.4392  64.4018 0000896 168.4264 191.6990 15.18080204  3037
1 66706U 25276AS  25352.14602047  .00004708  00000-0  23866-3 0  9995
2 66706  97.4462  63.8245 0002845 277.7473  82.3438 15.17430033  2943
1 66707U 25276AT  25352.74268931  .00004697  00000-0  23996-3 0  9993
2 66707  97.4441  64.4004 0003560 273.4915  86.5912 15.17162823  3033
1 66708U 25276AU  25352.73019119  .00004581  00000-0  22783-3 0  9990
2 66708  97.4397  64.4062 0000949 124.5361 235.5963 15.18117321  3033
1 66709U 25276AV  25352.13983680  .00004764  00000-0  23853-3 0  9990
2 66709  97.4448  63.8342 0002369 228.9469 131.1561 15.17860699  2947
1 66710U 25276AW  25352.67343161  .00004570  00000-0  23172-3 0  9994
2 66710  97.4404  64.3266 0001245 321.3363  38.7781 15.17443009  3023
1 66711U 25276AX  25352.14609422  .00005379  00000-0  27225-3 0  9993
2 66711  97.4446  63.8257 0002443 293.4669  66.6307 15.17427372  2942
1 66712U 25276AY  25352.14003907  .00005022  00000-0  25129-3 0  9996
2 66712  97.4436  63.8328 0002412 239.5681 120.5315 15.17861023  2946
1 66713U 25276AZ  25352.74221939  .00005024  00000-0  25593-3 0  9997
2 66713  97.4410  64.3930 0003389 274.2695  85.8152 15.17225127  3031
1 66714U 25276BA  25351.94714829  .00012964  00000-0  64610-3 0  9998
2 66714  97.4438  63.6304 0002284 302.8957  57.2057 15.17681017  2918
1 66715U 25276BB  25352.79761171  .00004349  00000-0  21701-3 0  9997
2 66715  97.4406  64.4671 0001577 200.8600 159.2570 15.18031044  3358
1 66716U 25276BC  25352.72993207  .00004814  00000-0  23912-3 0  9991
2 66716  97.4441  64.4173 0001408 151.6569 208.4742 15.18140297  3039
1 66717U 25276BD  25352.72837232  .00004851  00000-0  23987-3 0  9990
2 66717  97.4428  64.4160 0001298 138.4754 221.6579 15.18294922  2283
1 66718U 25276BE  25352.67762131  .00004485  00000-0  22995-3 0  9991
2 66718  97.4436  64.3338 0003128 290.2725  69.8172 15.17061507  3022
1 66719U 25276BF  25352.67624122  .00004468  00000-0  22836-3 0  9994
2 66719  97.4452  64.3399 0003159 273.0141  87.0731 15.17171885  3027
1 66720U 25276BG  25352.73160840  .00004832  00000-0  24087-3 0  9990
2 66720  97.4457  64.4217 0002345 207.0111 153.1002 15.18012144  3034
1 66721U 25276BH  25351.75377222  .00004646  00000-0  23788-3 0  9996
2 66721  97.4398  63.4152 0002651 311.0697  49.0307 15.17086968  2888
1 66722U 25276BJ  25352.79515310  .00004408  00000-0  21893-3 0  9995
2 66722  97.4401  64.4715 0002031 165.7757 194.3535 15.18183319  2339
1 66723U 25276BK  25352.72879255  .00005547  00000-0  27419-3 0  9995
2 66723  97.4439  64.4190 0002480 184.7212 175.3999 15.18241218  2283
1 66724U 25276BL  25352.79432048  .00006726  00000-0  33110-3 0  9993
2 66724  97.4404  64.4721 0002149 180.9215 179.2016 15.18305467  2290
1 66725U 25276BM  25352.80537334  .00004818  00000-0  24409-3 0  9991
2 66725  97.4391  64.4531 0001708 316.4206  43.6892 15.17443688  3048
1 66726U 25276BN  25352.74228838  .00004752  00000-0  24262-3 0  9995
2 66726  97.4456  64.4048 0003295 263.6258  96.4601 15.17180017  3034
1 66727U 25276BP  25352.14735740  .00004720  00000-0  24029-3 0  9991
2 66727  97.4453  63.8259 0002835 287.6160  72.4763 15.17280922  2944
1 66728U 25276BQ  25352.13601643  .00004820  00000-0  23925-3 0  9990
2 66728  97.4413  63.8273 0001477 119.5623 240.5758 15.18160784  2222
1 66729U 25276BR  25352.74358273  .00004593  00000-0  23509-3 0  9991
2 66729  97.4409  64.3907 0003603 280.7965  79.2863 15.17106884  3035
1 66730U 25276BS  25352.73098838  .00004426  00000-0  22077-3 0  9994
2 66730  97.4387  64.4018 0000987 128.5514 231.5809 15.18034774  3039
1 66731U 25276BT  25352.74323447  .00004384  00000-0  22464-3 0  9996
2 66731  97.4398  64.3880 0003271 283.9106  76.1763 15.17094564  3034
1 66732U 25276BU  25352.74137403  .00004412  00000-0  22517-3 0  9993
2 66732  97.4386  64.3861 0002191 305.1177  54.9851 15.17234148  3032
1 66733U 25276BV  25352.67646775  .00005137  00000-0  26186-3 0  9994
2 66733  97.4449  64.3397 0003225 285.2215  74.8662 15.17196723  3023
1 66734U 25276BW  25352.67624483  .00004323  00000-0  22113-3 0  9999
2 66734  97.4384  64.3208 0002581 296.4776  63.6193 15.17164352  3021
1 66735U 25276BX  25352.74265985  .00005134  00000-0  26186-3 0  9991
2 66735  97.4444  64.4010 0003559 280.5701  79.5132 15.17176368  3039
1 66736U 25276BY  25352.79482263  .00005520  00000-0  27293-3 0  9996
2 66736  97.4443  64.4843 0002243 171.4555 188.6718 15.18230946  3044
1 66737U 25276BZ  25352.73024071  .00004556  00000-0  22671-3 0  9993
2 66737  97.4453  64.4218 0002159 182.0962 178.0264 15.18103443  2283
1 66738U 25276CA  25352.13567927  .00004689  00000-0  23264-3 0  9996
2 66738  97.4421  63.8291 0002051 160.8686 199.2625 15.18192918  2237
1 66739U 25276CB  25352.73222100  .00004399  00000-0  21999-3 0  9995
2 66739  97.4464  64.4219 0002042 200.0570 160.0584 15.17945249  3032
1 66740U 25276CC  25352.73621696  .00005396  00000-0  27134-3 0  9995
2 66740  97.4427  64.4099 0001969 261.4220  98.6791 15.17655131  3033
1 66741U 25276CD  25352.14345163  .00002528  00000-0  12942-3 0  9998
2 66741  97.4423  63.8182 0001274 224.7833 135.3298 15.17511695  2943
1 66742U 25276CE  25352.73564793  .00004214  00000-0  21261-3 0  9994
2 66742  97.4418  64.4004 0001290 209.8000 150.3160 15.17657186  3038
1 66743U 25276CF  25352.80462444  .00005067  00000-0  25643-3 0  9998
2 66743  97.4418  64.4609 0000461 283.5588  76.5595 15.17459860  3040
1 66744U 25276CG  25352.80562372  .00002190  00000-0  11327-3 0  9998
2 66744  97.4427  64.4685 0001369 273.7543  86.3534 15.17297431  3041
1 66745U 25276CH  25352.14493979  .00002939  00000-0  15035-3 0  9993
2 66745  97.4425  63.8169 0000889 243.2573 116.8570 15.17410402  2943
1 66746U 25276CJ  25352.14493979  .00002939  00000-0  15035-3 0  9994
2 66746  97.4425  63.8169 0000889 243.2573 116.8570 15.17410402  2944
1 66747U 25276CK  25352.67133887  .00003144  00000-0  16020-3 0  9996
2 66747  97.4425  64.3375 0001083 233.0576 127.0559 15.17507633  3021
1 66748U 25276CL  25352.79694153  .00015740  00000-0  76842-3 0  9991
2 66748  97.4419  64.4737 0001721 240.1093 119.9970 15.18358790  3048
1 66749U 25276CM  25352.14064368  .00005482  00000-0  27432-3 0  9993
2 66749  97.4417  63.8194 0001444 211.9767 148.1380 15.17815590  2945
1 66750U 25276CN  25352.73132396  .00003863  00000-0  19335-3 0  9991
2 66750  97.4455  64.4188 0001736 162.6964 197.4329 15.17990475  3031
1 66751U 25276CP  25352.47043646  .00004308  00000-0  21662-3 0  9993
2 66751  97.4429  64.1505 0002032 229.2129 130.8929 15.17764579  2991
1 66752U 25276CQ  25352.67071700  .00003113  00000-0  15834-3 0  9995
2 66752  97.4420  64.3418 0001754 263.6526  96.4508 15.17568942  3022
1 66753U 25276CR  25352.67385124  .00003357  00000-0  17159-3 0  9996
2 66753  97.4422  64.3337 0001301 307.3356  52.7759 15.17346207  3021
1 66754U 25276CS  25352.14006777  .00003391  00000-0  17102-3 0  9999
2 66754  97.4422  63.8228 0001899 215.4458 144.6650 15.17810529  2943
1 66755U 25276CT  25352.14355122  .00003185  00000-0  16186-3 0  9993
2 66755  97.4423  63.8174 0000843 273.6945  86.4192 15.17583130  2949
1 66756U 25276CU  25352.73258843  .00004203  00000-0  21061-3 0  9991
2 66756  97.4428  64.4106 0001157 168.6621 191.4639 15.17899998  3036
1 66757U 25276CV  25352.73151377  .00005062  00000-0  25213-3 0  9993
2 66757  97.4438  64.4146 0001338 165.4279 194.6994 15.18013359  3036
1 66758U 25276CW  25352.73126242  .00004937  00000-0  24597-3 0  9991
2 66758  97.4410  64.4069 0000946 145.1819 214.9477 15.18023334  3036
1 66759U 25276CX  25352.72998394  .00005866  00000-0  29047-3 0  9993
2 66759  97.4397  64.4047 0001430 145.9662 214.1664 15.18152514  3033
1 66760U 25276CY  25352.72956302  .00004429  00000-0  22025-3 0  9991
2 66760  97.4411  64.4105 0001453 116.5497 243.5886 15.18141979  3037
1 66761U 25276CZ  25352.72776742  .00007895  00000-0  38706-3 0  9993
2 66761  97.4414  64.4126 0001445 127.1394 232.9972 15.18393626  3035
1 66762U 25276DA  25352.74042754  .00003079  00000-0  15800-3 0  9995
2 66762  97.4422  64.3982 0001022 297.2478  62.8651 15.17267332  3034
1 66763U 25276DB  25352.80469781  .00003038  00000-0  15539-3 0  9990
2 66763  97.4426  64.4689 0001389 269.0615  91.0459 15.17395002  3047
1 66764U 25276DC  25352.73508948  .00002602  00000-0  13254-3 0  9990
2 66764  97.4418  64.4035 0001710 216.1259 143.9859 15.17660786  3033
1 66765U 25276DD  25352.59331747  .00008956  00000-0  43557-3 0  9993
2 66765  97.4437  64.2922 0001742 123.0920 237.0482 15.18636313  3019
1 66766U 25276DE  25352.59522482  .00004989  00000-0  24612-3 0  9995
2 66766  97.4378  64.2752 0002022  93.5241 266.6224 15.18356756  3016
1 66767U 25276DF  25352.79349432  .00003849  00000-0  19119-3 0  9990
2 66767  97.4383  64.4708 0002094  93.6556 266.4918 15.18263021  3048
1 66768U 25276DG  25352.59422971  .00006146  00000-0  30157-3 0  9997
2 66768  97.4372  64.2757 0002305  83.4171 276.7325 15.18455872  3014
1 66769U 25276DH  25352.66072781  .00004427  00000-0  21877-3 0  9995
2 66769  97.4432  64.3540 0002516 113.2312 246.9187 15.18359608  3022
1 66770U 25276DJ  25352.72627920  .00002395  00000-0  11989-3 0  9990
2 66770  97.4461  64.4273 0002911 131.8967 228.2516 15.18363309  3034
1 66771U 25276DK  25352.59423128  .00004613  00000-0  22746-3 0  9998
2 66771  97.4458  64.2959 0002781 122.9099 237.2403 15.18416364  3015
1 66772U 25276DL  25352.79016915  .00006383  00000-0  31162-3 0  9991
2 66772  97.4451  64.4903 0002875 109.6474 250.5071 15.18617668  3045
1 66773U 25276DM  25352.59326444  .00004164  00000-0  20529-3 0  9991
2 66773  97.4444  64.2940 0003001 109.4952 250.6606 15.18479103  3010
1 66774U 25276DN  25352.79060059  .00005128  00000-0  25163-3 0  9991
2 66774  97.4431  64.4858 0002912 106.7080 253.4474 15.18528823  3040
1 66775U 25276DP  25352.65822387  .00005053  00000-0  24756-3 0  9991
2 66775  97.4356  64.3396 0002972  76.6070 283.5495 15.18593623  3028
1 66776U 25276DQ  25352.59208037  .00006221  00000-0  30370-3 0  9992
2 66776  97.4394  64.2839 0002937  91.8228 268.3343 15.18626781  3011
1 66777U 25276DR  25352.59037940  .00008908  00000-0  43078-3 0  9999
2 66777  97.4484  64.3070 0003332 121.4253 238.7307 15.18830638  3017
At the moment the best fit for PHI-1 is 66775
From a quick check on the teams that are active in this thread we have:
T.MicroSat-1 - 66766
HUNITY - 66670
Black Kite-1 - 66682
PHASMA-LAMARR - 66673
PHASMA-DIRAC - 66681
More detailed analysis will follow.
Important note: While some of the objects above fit uniquely, we have set them in DB to be followed until we have the TLE sets from space-track.org assigned, and can move to identification process. Before the final assignment TLE sets may be swapped/changed, so we avoid in this stage any identification.
Updated TLE for Foresail-1p, not very accurate but better than the current:
Foresail-1p
1 98467U 25000XX  25353.27764653  .00000000  00000-0  30660-4 0    01
2 98467  97.4424  63.8816 0003820  61.6496 329.5236 15.17781723    05
The TLE sets from space-track.org are now assigned, so we can start the process of identification. Here are the latest TLE, still for 112 objects:
0 FORMOSAT-8A
1 66666U 25276A   25354.16478853  .00003267  00000-0  26516-3 0  9994
2 66666  97.6583  66.0010 0003663 201.3958 158.7113 15.00328968  3202
0 PELICAN-5
1 66667U 25276B   25354.18685704  .00005090  00000-0  25668-3 0  9995
2 66667  97.4425  65.8331 0001872 226.8725 133.2352 15.17582581  3252
0 OBJECT C
1 66668U 25276C   25354.06866483  .00013770  00000-0  69791-3 0  9997
2 66668  97.4291  65.6486 0007712 277.9285  82.1073 15.17054823  3233
0 OBJECT D
1 66669U 25276D   25354.13124433  .06545393  00000-0  21715+0 0  9995
2 66669  97.4323  65.7247 0048308 228.3761 131.3335 15.25643349  3246
0 OBJECT E
1 66670U 25276E   25354.13346200  .00014724  00000-0  74455-3 0  9991
2 66670  97.4311  65.7217 0007109 281.8615  78.1821 15.17123967  3246
0 OBJECT F
1 66671U 25276F   25354.13122465  .00008130  00000-0  41393-3 0  9996
2 66671  97.4435  65.7550 0004986 263.6140  96.4526 15.17050575  3244
0 OBJECT G
1 66672U 25276G   25354.13519330  .00006229  00000-0  32209-3 0  9991
2 66672  97.4407  65.7433 0005339 262.1715  97.8912 15.16599881  3240
0 OBJECT H
1 66673U 25276H   25354.13222500  .00007861  00000-0  40026-3 0  9991
2 66673  97.4375  65.7377 0005760 280.6788  79.3797 15.17059036  3245
0 OBJECT J
1 66674U 25276J   25354.19961475  .00004981  00000-0  25742-3 0  9997
2 66674  97.4383  65.8041 0004944 266.7808  93.2859 15.16715913  3252
0 OBJECT K
1 66675U 25276K   25354.06608416  .00007889  00000-0  40289-3 0  9990
2 66675  97.4401  65.6801 0004966 271.4608  88.6057 15.16956079  3237
0 OBJECT L
1 66676U 25276L   25354.13339825  .00006482  00000-0  33349-3 0  9991
2 66676  97.4395  65.7443 0004752 269.1170  90.9518 15.16763440  3241
0 OBJECT M
1 66677U 25276M   25353.59923131  .00009158  00000-0  46126-3 0  9990
2 66677  97.4397  65.2316 0003817 279.7196  80.3606 15.17398982  3162
0 OBJECT N
1 66678U 25276N   25354.13285301  .00006930  00000-0  35575-3 0  9993
2 66678  97.4430  65.7532 0004804 260.9697  99.0992 15.16819496  3242
0 OBJECT P
1 66679U 25276P   25354.13384573  .00005840  00000-0  30165-3 0  9994
2 66679  97.4373  65.7374 0004546 269.6392  90.4321 15.16669793  3248
0 OBJECT Q
1 66680U 25276Q   25354.13262666  .00005212  00000-0  26859-3 0  9992
2 66680  97.4424  65.7502 0004629 258.9467 101.1246 15.16796846  3242
0 OBJECT R
1 66681U 25276R   25354.06266821  .00010892  00000-0  54857-3 0  9991
2 66681  97.4347  65.6707 0004886 287.8227  72.2474 15.17350131  3237
0 OBJECT S
1 66682U 25276S   25354.13037602  .00007284  00000-0  37092-3 0  9996
2 66682  97.4468  65.7643 0004740 251.0315 109.0405 15.17084078  3240
0 OBJECT T
1 66683U 25276T   25354.19696365  .00004696  00000-0  24112-3 0  9993
2 66683  97.4462  65.8270 0004612 253.4472 106.6255 15.16976032  3256
0 OBJECT U
1 66684U 25276U   25354.06242215  .00008698  00000-0  44013-3 0  9999
2 66684  97.4485  65.7072 0004334 252.8538 107.2221 15.17251438  3233
0 OBJECT V
1 66685U 25276V   25353.59977146  .00009795  00000-0  49331-3 0  9992
2 66685  97.4431  65.2408 0003974 278.7845  81.2938 15.17380939  3167
0 OBJECT W
1 66686U 25276W   25354.13016721  .00005235  00000-0  26846-3 0  9998
2 66686  97.4465  65.7648 0004001 256.2752 103.8036 15.16972854  3247
0 OBJECT X
1 66687U 25276X   25354.13498226  .00008354  00000-0  43002-3 0  9991
2 66687  97.4399  65.7392 0008517  63.9348 296.2760 15.16636652  3244
0 OBJECT Y
1 66688U 25276Y   25354.12939051  .00005025  00000-0  25729-3 0  9995
2 66688  97.4444  65.7602 0003570 261.0045  99.0785 15.17044694  3245
0 OBJECT Z
1 66689U 25276Z   25353.59865495  .00001956  00000-0  10187-3 0  9997
2 66689  97.4426  65.2430 0001369 288.6889  71.4196 15.17181025  3166
0 OBJECT AA
1 66690U 25276AA  25354.06345821  .00007285  00000-0  37156-3 0  9994
2 66690  97.4408  65.6855 0003269 265.4105  94.6755 15.17032749  3232
0 OBJECT AB
1 66691U 25276AB  25353.99592095  .00007283  00000-0  36926-3 0  9995
2 66691  97.4430  65.6290 0003619 262.8846  97.1976 15.17242522  3227
0 OBJECT AC
1 66692U 25276AC  25353.59734987  .00004326  00000-0  22003-3 0  9996
2 66692  97.4431  65.2479 0001801 289.3043  70.7996 15.17362366  3169
0 OBJECT AD
1 66693U 25276AD  25354.19125637  .00009215  00000-0  46232-3 0  9992
2 66693  97.4384  65.8128 0003199 288.2588  71.8298 15.17534825  3256
0 YAM-9
1 66694U 25276AE  25354.18941213  .00006733  00000-0  33901-3 0  9999
2 66694  97.4422  65.8285 0001283 279.5897  80.5192 15.17519057  3252
0 IRIDE FM1
1 66695U 25276AF  25354.18009808  .00006963  00000-0  34364-3 0  9994
2 66695  97.4411  65.8363 0001198 150.3537 209.7765 15.18205896  3255
0 IRIDE FM2
1 66696U 25276AG  25354.19160557  .00006481  00000-0  32781-3 0  9991
2 66696  97.4400  65.8172 0002421 282.6641  77.4322 15.17371677  3256
0 IRIDE FM3
1 66697U 25276AH  25354.04927014  .00006515  00000-0  32257-3 0  9991
2 66697  97.4400  65.7023 0001040 156.8649 203.2632 15.18117890  3234
0 IRIDE FM4
1 66698U 25276AJ  25354.00002315  .00024334  00000-0  12220-2 0  9992
2 66698  97.4405  65.6290 0002515 274.0309 116.1356 15.17274955  1305
0 IRIDE FM5
1 66699U 25276AK  25354.00002315  .00025543  00000-0  12806-2 0  9996
2 66699  97.4418  65.6331 0002841 271.8047 119.1421 15.17324467  1302
0 IRIDE FM6
1 66700U 25276AL  25354.18056274  .00006264  00000-0  30981-3 0  9995
2 66700  97.4432  65.8416 0001428 168.2010 191.9258 15.18170250  3258
0 IRIDE FM7
1 66701U 25276AM  25354.00002315  .00025486  00000-0  12780-2 0  9997
2 66701  97.4436  65.6381 0002723 270.8752 119.9532 15.17317409  1301
0 IRIDE FM8
1 66702U 25276AN  25354.19207269  .00007363  00000-0  37220-3 0  9994
2 66702  97.4411  65.8195 0002715 279.0557  81.0370 15.17346445  3252
0 PELICAN-6
1 66703U 25276AP  25354.19071377  .00005248  00000-0  26653-3 0  9992
2 66703  97.4413  65.8230 0000848 268.3882  91.7255 15.17319935  3256
0 FLOCK 4H 1
1 66704U 25276AQ  25354.18178078  .00006411  00000-0  31813-3 0  9995
2 66704  97.4387  65.8260 0001801 180.8130 179.3101 15.18047831  3251
0 FLOCK 4H 2
1 66705U 25276AR  25354.18140666  .00006514  00000-0  32269-3 0  9998
2 66705  97.4388  65.8268 0001045 165.2555 194.8709 15.18098431  3257
0 FLOCK 4H 3
1 66706U 25276AS  25354.19023683  .00005966  00000-0  30133-3 0  9997
2 66706  97.4450  65.8354 0002801 263.5985  96.4930 15.17450644  3254
0 FLOCK 4H 4
1 66707U 25276AT  25354.12772808  .00005671  00000-0  28886-3 0  9996
2 66707  97.4444  65.7616 0003442 264.7560  95.3281 15.17177155  3241
0 FLOCK 4H 5
1 66708U 25276AU  25354.18027272  .00009709  00000-0  47866-3 0  9996
2 66708  97.4403  65.8315 0001220 112.8536 247.2827 15.18136230  3257
0 FLOCK 4H 6
1 66709U 25276AV  25354.18347490  .00006176  00000-0  30801-3 0  9990
2 66709  97.4442  65.8440 0002418 217.5997 142.5068 15.17881570  3251
0 FLOCK 4H 7
1 66710U 25276AW  25354.19015813 -.00019300  00000-0 -96692-3 0  9999
2 66710  97.4395  65.8158 0000697 331.4229  28.6966 15.17358095  3259
0 FLOCK 4H 8
1 66711U 25276AX  25354.19031336  .00006754  00000-0  34068-3 0  9994
2 66711  97.4443  65.8344 0002243 289.4935  70.6056 15.17451665  3250
0 FLOCK 4H 9
1 66712U 25276AY  25354.18367495  .00006296  00000-0  31392-3 0  9990
2 66712  97.4429  65.8414 0002551 228.2593 131.8423 15.17883301  3250
0 FLOCK 4H 10
1 66713U 25276AZ  25353.91668981 -.00022293  00000-0 -11211-2 0  9999
2 66713  97.4410  65.5475 0003151 267.4930  23.4990 15.17251401  1301
0 FLOCK 4H 11
1 66714U 25276BA  25354.18879850  .00010433  00000-0  51993-3 0  9992
2 66714  97.4406  65.8334 0001531 295.5956  64.5120 15.17740462  3251
0 FLOCK 4H 12
1 66715U 25276BB  25354.18185935  .00006084  00000-0  30210-3 0  9993
2 66715  97.4400  65.8280 0001652 193.0074 167.1117 15.18046022  3565
0 FLOCK 4H 13
1 66716U 25276BC  25354.17999176  .00004862  00000-0  24135-3 0  9994
2 66716  97.4438  65.8438 0001520 149.0109 211.1215 15.18153955  3255
0 FLOCK 4H 14
1 66717U 25276BD  25354.17828378  .00005098  00000-0  25180-3 0  9993
2 66717  97.4425  65.8424 0001441 137.0818 223.0529 15.18309696  2505
0 FLOCK 4H 15
1 66718U 25276BE  25354.06275288  .00004427  00000-0  22690-3 0  9996
2 66718  97.4434  65.6942 0003054 283.5024  76.5869 15.17073597  3233
0 FLOCK 4H 16
1 66719U 25276BF  25354.00002315  .00024517  00000-0  12346-2 0  9998
2 66719  97.4452  65.6410 0002878 265.1446 120.6373 15.17176766  2659
0 FLOCK 4H 17
1 66720U 25276BG  25354.18178953  .00005998  00000-0  29798-3 0  9993
2 66720  97.4453  65.8481 0002474 200.8658 159.2476 15.18028916  3258
0 FLOCK 4H 18
1 66721U 25276BH  25354.12823457  .00007846  00000-0  39893-3 0  9995
2 66721  97.4403  65.7450 0002429 309.7615  50.3404 15.17116605  3244
0 FLOCK 4H 19
1 66722U 25276BJ  25354.17926110  .00007342  00000-0  36219-3 0  9991
2 66722  97.4397  65.8326 0002140 159.3322 200.7999 15.18200139  2543
0 2025-276BK
1 66723U 25276BK  25354.17875477  .00005297  00000-0  26187-3 0  9991
2 66723  97.4434  65.8454 0002596 179.8681 180.2554 15.18256797  2504
0 FLOCK 4H 21
1 66724U 25276BL  25354.17831862  .00004461  00000-0  22071-3 0  9992
2 66724  97.4400  65.8332 0002332 176.4825 183.6426 15.18317621  2503
0 FLOCK 4H 22
1 66725U 25276BM  25354.00002315  .00026256  00000-0  13118-2 0  9995
2 66725  97.4388  65.6273 0001501 316.1404  85.9729 15.17442614  1491
0 FLOCK 4H 23
1 66726U 25276BN  25354.12731118  .00006021  00000-0  30628-3 0  9993
2 66726  97.4452  65.7655 0003365 256.6929 103.3930 15.17195657  3245
0 FLOCK 4H 24
1 66727U 25276BP  25354.19177481  .00005557  00000-0  28211-3 0  9996
2 66727  97.4452  65.8347 0002771 276.6003  83.4915 15.17300807  3257
0 FLOCK 4H 25
1 66728U 25276BQ  25354.17924954  .00007349  00000-0  36271-3 0  9996
2 66728  97.4407  65.8366 0001632 111.6925 248.4483 15.18186383  2530
0 FLOCK 4H 26
1 66729U 25276BR  25354.06271463  .00006391  00000-0  32555-3 0  9992
2 66729  97.4405  65.6857 0003642 273.2903  86.7914 15.17123736  3238
0 FLOCK 4H 27
1 66730U 25276BS  25354.18114813  .00005532  00000-0  27494-3 0  9994
2 66730  97.4387  65.8267 0001052 127.9653 232.1676 15.18049887  3255
0 FLOCK 4H 28
1 66731U 25276BT  25354.12833502  .00005612  00000-0  28643-3 0  9998
2 66731  97.4390  65.7479 0003226 277.1965  82.8901 15.17110062  3246
0 FLOCK 4H 29
1 66732U 25276BU  25354.19228539  .00012574  00000-0  63408-3 0  9997
2 66732  97.4513  65.8133 0002503 244.0915 116.0060 15.17274230  3252
0 FLOCK 4H 30
1 66733U 25276BV  25354.12734969  .00413861  00000-0  19368-1 0  9998
2 66733  97.4445  65.7654 0005951 238.2181 121.8473 15.17773353  3245
0 FLOCK 4H 31
1 66734U 25276BW  25354.12723655  .00007944  00000-0  40317-3 0  9990
2 66734  97.4404  65.7446 0002494 291.7917  68.3051 15.17180172  3248
0 FLOCK 4H 32
1 66735U 25276BX  25354.00002315  .00025327  00000-0  12750-2 0  9995
2 66735  97.4441  65.6376 0003264 273.6646 109.5980 15.17179707  2650
0 FLOCK 4H 33
1 66736U 25276BY  25354.17888770  .00006215  00000-0  30675-3 0  9993
2 66736  97.4438  65.8458 0002379 165.6799 194.4502 15.18246372  3259
0 FLOCK 4H 34
1 66737U 25276BZ  25354.18033527  .00004517  00000-0  22468-3 0  9991
2 66737  97.4450  65.8484 0002290 176.3551 183.7700 15.18117302  2508
0 FLOCK 4H 35
1 66738U 25276CA  25354.17887022  .00006624  00000-0  32700-3 0  9999
2 66738  97.4414  65.8381 0002102 149.7087 210.4268 15.18213939  2549
0 FLOCK 4H 36
1 66739U 25276CB  25354.18246605  .00004814  00000-0  24034-3 0  9997
2 66739  97.4461  65.8486 0002168 192.7906 167.3274 15.17959724  3252
0 OBJECT CC
1 66740U 25276CC  25354.18673779  .00005235  00000-0  26319-3 0  9991
2 66740  97.4423  65.8355 0001960 252.4875 107.6144 15.17671270  3255
0 OBJECT CD
1 66741U 25276CD  25354.18775594 -.00130377  00000-0 -67002-2 0  9991
2 66741  97.4420  65.8267 0001313 149.7198 210.4111 15.17097812  3254
0 OBJECT CE
1 66742U 25276CE  25354.18616850  .00005746  00000-0  28856-3 0  9995
2 66742  97.4415  65.8259 0001418 202.2894 157.8278 15.17673287  3258
0 OBJECT CF
1 66743U 25276CF  25353.66186270  .00004194  00000-0  21278-3 0  9993
2 66743  97.4415  65.3031 0000433 269.9787  90.1397 15.17467426  3177
0 OBJECT CG
1 66744U 25276CG  25354.19054174  .00004771  00000-0  24270-3 0  9996
2 66744  97.4425  65.8290 0001300 264.2083  95.9003 15.17308878  3253
0 OBJECT CH
0 OBJECT CJ
1 66746U 25276CJ  25353.20003709  .00002728  00000-0  13980-3 0  9993
2 66746  97.4422  64.8535 0000963 234.0891 126.0254 15.17416472  3107
0 W-SERIES 5
1 66747U 25276CK  25354.18794236  .00004988  00000-0  25200-3 0  9992
2 66747  97.4423  65.8279 0001125 221.1820 138.9329 15.17521943  3256
0 OBJECT CL
1 66748U 25276CL  25354.18087764  .00012020  00000-0  58725-3 0  9998
2 66748  97.4417  65.8354 0001829 233.0535 127.0532 15.18396095  3254
0 OBJECT CM
1 66749U 25276CM  25354.18433994  .00004880  00000-0  24446-3 0  9997
2 66749  97.4411  65.8282 0001613 199.8853 160.2318 15.17836732  3259
0 OBJECT CN
1 66750U 25276CN  25354.18152704  .00003797  00000-0  19005-3 0  9997
2 66750  97.4451  65.8455 0001893 157.8879 202.2437 15.18002319  3255
0 ICEYE-X58
1 66751U 25276CP  25354.18456662  .00005546  00000-0  27776-3 0  9996
2 66751  97.4424  65.8356 0002093 218.1442 141.9644 15.17780146  3255
0 ICEYE-X59
1 66752U 25276CQ  25354.18725853  .00005381  00000-0  27111-3 0  9998
2 66752  97.4418  65.8321 0001727 254.7950 105.3093 15.17584846  3255
0 ICEYE-X60
1 66753U 25276CR  25354.00002315  .00023708  00000-0  11886-2 0  9995
2 66753  97.4422  65.6370 0001085 301.9192  97.7451 15.17342416  4396
0 ICEYE-X61
1 66754U 25276CS  25354.18377660  .00003088  00000-0  15596-3 0  9995
2 66754  97.4416  65.8319 0002007 204.1782 155.9358 15.17823742  3252
0 ICEYE-X62
1 66755U 25276CT  25354.18756470  .00005033  00000-0  25371-3 0  9990
2 66755  97.4418  65.8260 0000799 254.1336 105.9810 15.17601075  3257
0 OBJECT CU
1 66756U 25276CU  25354.18287733  .00003916  00000-0  19641-3 0  9993
2 66756  97.4425  65.8366 0001323 162.4410 197.6870 15.17912677  3258
0 OBJECT CV
1 66757U 25276CV  25354.18169352  .00005957  00000-0  29600-3 0  9993
2 66757  97.4434  65.8405 0001422 161.6910 198.4375 15.18030102  3253
0 OBJECT CW
1 66758U 25276CW  25354.18143264  .00008153  00000-0  40361-3 0  9996
2 66758  97.4421  65.8332 0001315 117.8258 242.3110 15.18046274  3251
0 OBJECT CX
1 66759U 25276CX  25353.58683118  .00005044  00000-0  25020-3 0  9998
2 66759  97.4394  65.2472 0001493 144.8645 215.2688 15.18161392  3165
0 OBJECT CY
1 66760U 25276CY  25354.17962096  .00006360  00000-0  31464-3 0  9992
2 66760  97.4409  65.8363 0001603 112.1646 247.9758 15.18157301  3256
0 OBJECT CZ
1 66761U 25276CZ  25354.11168028  .00007402  00000-0  36289-3 0  9998
2 66761  97.4407  65.7740 0001491 126.7583 233.3788 15.18415140  3248
0 HYDROGNSS-1
1 66762U 25276DA  25354.19135359 -.00061470  00000-0 -31239-2 0  9994
2 66762  97.4418  65.8233 0002521 306.2069  53.8931 15.17137750  3251
0 HYDROGNSS-2
1 66763U 25276DB  25354.18955760 -.00082583  00000-0 -41962-2 0  9992
2 66763  97.4430  65.8296 0001099 138.4182 221.7136 15.17256655  3254
0 OBJECT DC
1 66764U 25276DC  25354.18560888  .00002909  00000-0  14778-3 0  9994
2 66764  97.4416  65.8291 0001790 206.6425 153.4717 15.17669781  3254
0 OBJECT DD
1 66765U 25276DD  25354.10878719  .00008073  00000-0  39266-3 0  9999
2 66765  97.4432  65.7842 0001776 122.5076 237.6330 15.18662089  3246
0 OBJECT DE
1 66766U 25276DE  25353.97917458  .00006311  00000-0  31029-3 0  9990
2 66766  97.4373  65.6361 0001970  92.5840 267.5619 15.18373426  3221
0 OBJECT DF
1 66767U 25276DF  25353.65028106  .00003009  00000-0  15018-3 0  9990
2 66767  97.4382  65.3133 0002061  92.7355 267.4115 15.18267281  3176
0 OBJECT DG
1 66768U 25276DG  25354.04397399  .00061993  00000-0  29808-2 0  9995
2 66768  97.4314  65.7063 0002862  71.9700 288.1846 15.18556463  3231
0 OBJECT DH
1 66769U 25276DH  25354.17648035  .00004559  00000-0  22511-3 0  9996
2 66769  97.4428  65.8455 0002594 110.9123 249.2389 15.18373095  3259
0 OBJECT DJ
1 66770U 25276DJ  25353.64891162  .00002121  00000-0  10651-3 0  9995
2 66770  97.4459  65.3356 0002954 130.1383 230.0110 15.18367258  3177
0 OBJECT DK
1 66771U 25276DK  25354.17582588  .00010696  00000-0  52237-3 0  9996
2 66771  97.4468  65.8526 0002975 118.6079 241.5455 15.18436711  3257
0 OBJECT DL
1 66772U 25276DL  25353.64675389  .00005467  00000-0  26731-3 0  9990
2 66772  97.4448  65.3337 0002887 108.2208 251.9340 15.18627675  3172
0 OBJECT DM
1 66773U 25276DM  25353.64761928  .00003690  00000-0  18223-3 0  9999
2 66773  97.4442  65.3318 0003023 107.5089 252.6476 15.18487387  3170
0 OBJECT DN
1 66774U 25276DN  25354.10849899  .00006591  00000-0  32231-3 0  9994
2 66774  97.4431  65.7829 0002943 104.9766 255.1794 15.18545611  3247
0 OBJECT DP
1 66775U 25276DP  25353.58071492  .00004375  00000-0  21476-3 0  9999
2 66775  97.4354  65.2468 0002942  74.8411 285.3148 15.18601756  3169
0 OBJECT DQ
1 66776U 25276DQ  25354.17345396  .00005809  00000-0  28368-3 0  9993
2 66776  97.4391  65.8398 0002893  89.3978 270.7587 15.18645533  3259
0 OBJECT DR
1 66777U 25276DR  25354.17153817  .00007581  00000-0  36690-3 0  9995
2 66777  97.4479  65.8650 0003340 118.6100 241.5471 15.18855004  3253
Based upon the beacons, HCT-2 is close to two objects:
66671
66683
I don’t have an STRF observation to back it, only from Ikhnos it seems to be closer to 66671. Can you update the TLE to it?
Foresail-1p
1 98467U 25000XX  25356.39739402  .00000000  00000-0  30137-3 0    09
2 98467  97.4424  68.0720 0003820  61.6496  71.9400 15.16595523    07
sites.txt (12.2 KB)
foresail1p_356_v1.dat (1.7 KB)
Object CE, 66742, possibly MERCURY ONE (M1) on 2220.0 MHz:
