Mercury-1 is mentioned, so I downloaded the ITU freq list.
The downlinks on 2265 & 8200 MHz look like normal data bandwidths, but I sure am curious about that 244 Khz signal on 2220 MHz… curious to see something that narrow on S-Band.
“If” this satellite goes up on Transporter-15 and “if” they actually use the 2220 MHz downlink, it’ll be very interesting to see what the signals looks like (and if it’s anything we can decode, etc.)
Mice-1 is outside the Amateur spectrum (401.5 MHz), but depending on the modulation & payload it might be interesting. Some S-Band downlinks listed also.
Thanks in advance if anyone sees info about WISeSat-5/6/7 that are mentioned as possible payloads on Transporter-15.
There is a history of LoRa comms during the development of this family of sats and since FOSSA Systems are apparently still involved, you have to wonder if they will continue to use 401.7 MHz or if these new versions will be found somewhere else.
