Indeed there is some curve in the signals… I’ll try later to generate one that fits better. However it is still relevant the one from the GNSS.
OTP-2
1 98652U 25074.61859158 .00000000 00000-0 38509-2 0 01
2 98652 97.4396 330.3903 0006612 339.5368 205.3830 15.15414314 03
ikhnos -t ~/satnogs/strf/OTP-2.tle -r 29.0 -f -3 11236062
Thanks. Can we try that one for a bit?
A strong signal from NUSHSAT-1 was received over Taiwan, and 78 packets were uploaded to the SATNOGS server.
Unknown one is ALMUNTHER then?
It looks like that but not 100% sure.
EDIT:
According to the NSSA the satellite is received: https://www.bna.bh/en/National/NSSAconfirmssuccessfulreceptionoffirstsignalfromAlMunthersatellite.aspx
Given that we haven’t received anything in the ITU frequency, which was in radio amateur band without IARU coordination, it makes almost sure that this is AL-MUNTHER.
EDIT 2:
Also, as @PE0SAT noted in the matrix chat channel, the satellite uses ISISPACE COMMS, Al Munther satellite showcases national space technology advancements, which uses BPSK AX.25 G3RUH in other satellite missions
NUSHSAT-1 TLE Update
NUSHSAT-1
1 98628U 25077.36447516 .00000000 00000-0 -15047-3 0 04
2 98628 97.4529 332.6120 0002930 200.7175 213.6842 15.17773467 08
Using SatNOGS Network - Observation 11246834 for ikhnos
Some NUSHSAT-1 TLE improvements
NUSHSAT-1
2 98628 97.4529 332.6333 0002930 200.7175 213.7045 15.17543860 02
Updated TLE for Buccaneer MM
Buccaneer MM
1 98648U 00000A 25077.51518264 .00000000 00000-0 00000-0 0 01
2 98648 97.7394 332.6221 0003006 323.8110 255.1282 14.91214188 06
Updated TLE for OTP-2:
OTP-2
1 98652U 25077.62800071 .00000000 00000-0 38509-2 0 05
2 98652 97.4396 333.4702 0006612 339.5368 56.9862 15.16197261 09
I’ve also added frequency drift on the transmitter. The drift is calculated around -2.5 kHz.
Will they be merged? Or should we add new transmitter to entry of ALMUNTHER?
GNSS based TLE for OTP-2
OTP-2
NUSHSAT-1
1 98628U 25077.36447516 .00000000 00000-0 30011-3 0 01
2 98628 97.4529 332.6353 0002930 200.7175 213.7120 15.17569052 09
I would like to take a better look during the weekend before merge the satellites. Until then we track the frequency at 401.175, so no need to add an extra transmitter.
Thanks @PE0SAT and @macphersonrss both TLE set are now in DB and changed in the future observation in Network.
Draft TLE sets from space-track.org, use with caution:
88320
1 88320U 25077.75205386 +.00007448 +00000+0 +38303-3 0 00058
2 88320 97.4464 333.0229 0003823 316.6547 43.4385 15.16733892000672
88321
1 88321U 25077.75220333 +.00014070 +00000+0 +72074-3 0 00050
2 88321 97.4434 333.0209 0004436 319.4466 40.6436 15.16690630000678
88322
1 88322U 25077.75231823 +.00012027 +00000+0 +61777-3 0 00066
2 88322 97.4459 333.0225 0004234 324.4735 35.6216 15.16634418000677
88323
1 88323U 25077.75244343 +.00006138 +00000+0 +31786-3 0 00050
2 88323 97.4423 333.0201 0004640 323.7447 36.3471 15.16555990000674
88324
1 88324U 25077.75243477 +.00016871 +00000+0 +86551-3 0 00053
2 88324 97.4424 333.0202 0004708 323.5044 36.5867 15.16597181000672
88325
1 88325U 25077.75261702 +.00013422 +00000+0 +69133-3 0 00062
2 88325 97.4466 333.0214 0005360 316.3290 43.7519 15.16506753000679
88326
1 88326U 25077.75275230 +.00008501 +00000+0 +44038-3 0 00052
2 88326 97.4432 333.0200 0005498 324.4363 35.6503 15.16426081000679
88327
1 88327U 25077.68718200 +.00014621 +00000+0 +75787-3 0 00060
2 88327 97.4481 332.9555 0006457 313.8914 46.1785 15.16256284000669
88328
1 88328U 25077.68731297 +.00019231 +00000+0 +99622-3 0 00057
2 88328 97.4380 332.9541 0006530 330.5306 29.5558 15.16217099000660
88329
1 88329U 25077.68749806 +.00011235 +00000+0 +58590-3 0 00047
2 88329 97.4385 332.9549 0006819 328.7904 31.2923 15.16105487000660
88330
1 88330U 25077.68745220 +.00026423 +00000+0 +13676-2 0 00045
2 88330 97.4465 332.9551 0006908 316.5493 43.5195 15.16178685000668
88331
1 88331U 25077.68749207 +.00026550 +00000+0 +13749-2 0 00058
2 88331 97.4466 332.9546 0007088 315.5771 44.4893 15.16158731000667
88332
1 88332U 25077.68750422 +.00022969 +00000+0 +11910-2 0 00036
2 88332 97.4466 332.9548 0007042 315.3124 44.7540 15.16143139000668
88333
1 88333U 25077.68774198 +.00025316 +00000+0 +13155-2 0 00035
2 88333 97.4409 332.9544 0007427 324.8834 35.1909 15.16044359000669
88334
1 88334U 25077.68781174 +.00021638 +00000+0 +11269-2 0 00035
2 88334 97.4379 332.9543 0007572 329.0237 31.0548 15.15998376000660
88302
1 88302U 25077.88177209 +.00027688 +00000+0 +13705-2 0 00106
2 88302 97.4515 333.1543 0002455 237.3032 122.7966 15.17754540000699
88303
1 88303U 25077.68419875 +.00028314 +00000+0 +14054-2 0 00085
2 88303 97.4506 332.9595 0002224 248.4689 111.6307 15.17655050000668
88304
1 88304U 25077.68446019 +.00040242 +00000+0 +19982-2 0 00074
2 88304 97.4382 332.9595 0001131 352.8365 7.2852 15.17559870000666
88305
1 88305U 25077.68456181 +.00025795 +00000+0 +12871-2 0 00083
2 88305 97.4426 332.9590 0001104 305.2528 54.8602 15.17490593000661
88306
1 88306U 25077.61862508 +.00025806 +00000+0 +12881-2 0 00052
2 88306 97.4423 332.8937 0001354 291.8120 68.2970 15.17479320000659
88307
1 88307U 25077.68460567 +.00025423 +00000+0 +12697-2 0 00059
2 88307 97.4425 332.9581 0001438 292.1911 67.9170 15.17462054000668
88308
1 88308U 25077.68471991 +.00021561 +00000+0 +10799-2 0 00064
2 88308 97.4381 332.9578 0001367 332.4671 27.6490 15.17395582000667
88309
1 88309U 25077.68501988 +.00024579 +00000+0 +12343-2 0 00064
2 88309 97.4465 332.9535 0000886 346.6186 13.5023 15.17275261000664
88310
1 88310U 25077.61907112 +.00024306 +00000+0 +12209-2 0 00045
2 88310 97.4402 332.8929 0001947 318.9286 41.1801 15.17269251000657
88311
1 88311U 25077.68504055 +.00034766 +00000+0 +17410-2 0 00053
2 88311 97.4424 332.9621 0002834 342.8953 17.2184 15.17296486000664
88312
1 88312U 25077.68504539 +.00038621 +00000+0 +19335-2 0 00042
2 88312 97.4424 332.9590 0002865 336.7354 23.3749 15.17281188000669
88313
1 88313U 25077.68507872 +.00021071 +00000+0 +10609-2 0 00064
2 88313 97.4416 332.9592 0001646 318.9455 41.1654 15.17217148000661
88314
1 88314U 25077.68517595 +.00010124 +00000+0 +51320-3 0 00061
2 88314 97.4399 332.9566 0002162 316.9300 43.1764 15.17149057000661
88315
1 88315U 25077.75134918 +.00011309 +00000+0 +57420-3 0 00056
2 88315 97.4487 333.0232 0003400 294.4335 65.6543 15.17058479000678
88316
1 88316U 25077.75135367 +.00013838 +00000+0 +70149-3 0 00069
2 88316 97.4436 333.0221 0002930 307.3610 52.7356 15.17066805000679
88317
1 88317U 25077.75168393 +.00012158 +00000+0 +61947-3 0 00076
2 88317 97.4458 333.0223 0003786 305.9013 54.1869 15.16917323000671
88318
1 88318U 25077.75168571 +.00013500 +00000+0 +68736-3 0 00058
2 88318 97.4497 333.0237 0004209 297.8820 62.1987 15.16916403000674
88319
1 88319U 25077.75184030 +.00015918 +00000+0 +81099-3 0 00059
2 88319 97.4468 333.0228 0004117 307.2676 52.8181 15.16856939000675
88367
1 88367U 25077.80628780 +.00015599 +00000+0 +15095-2 0 00038
2 88367 97.7381 332.9050 0004382 89.8461 270.3261 14.92834112000651
88368
1 88368U 25077.80628811 +.00013930 +00000+0 +13490-2 0 00049
2 88368 97.7381 332.9050 0004381 89.5826 270.5895 14.92831816000656
88369
1 88369U 25043.79301564 +.00009207 +00000+0 +46173-3 0 00467
2 88369 97.4431 125.9990 0004531 235.7220 124.3585 15.17545646004391
88370
1 88370U 25043.79399278 +.00007973 +00000+0 +40156-3 0 00450
2 88370 97.4435 125.9975 0004733 230.3607 129.7209 15.17438848004391
88371
1 88371U 25043.00487109 +.00005104 +00000+0 +25999-3 0 00504
2 88371 97.4379 125.1937 0003661 245.3500 114.7353 15.17220862061916
88372
1 88372U 25043.00573970 +.00020478 +00000+0 +10306-2 0 00424
2 88372 97.4399 125.1997 0004071 239.6398 120.4434 15.17233791061911
88373
1 88373U 25043.00242066 +.00008084 +00000+0 +40691-3 0 00446
2 88373 97.4349 125.1860 0004234 250.2301 109.8476 15.17460066061914
88374
1 88374U 25043.00509011 +.00004143 +00000+0 +21149-3 0 00486
2 88374 97.4405 125.2031 0004424 238.1860 121.8943 15.17257314061918
88375
1 88375U 25043.00619092 +.00006003 +00000+0 +30573-3 0 00453
2 88375 97.4378 125.1920 0004005 242.5636 117.5190 15.17156236061916
88376
1 88376U 25043.00386590 +.00013571 +00000+0 +68990-3 0 00382
2 88376 97.2090 125.0017 0004707 166.3732 193.7630 15.16960193061910
88377
1 88377U 25043.00352950 +.00012375 +00000+0 +62007-3 0 00380
2 88377 97.4478 125.2332 0005305 228.7675 131.3102 15.17496147061915
88378
1 88378U 25043.00510636 +.00009485 +00000+0 +47851-3 0 00476
2 88378 97.4431 125.2134 0004841 235.7316 124.3460 15.17327109004275
88379
1 88379U 25043.00801115 +.00004375 +00000+0 +22475-3 0 00458
2 88379 97.4360 125.1831 0004576 245.2782 114.7976 15.16999907004273
88380
1 88380U 25043.00008731 +.00022211 +00000+0 +10969-2 0 00467
2 88380 97.4351 125.1925 0005147 251.3182 108.7493 15.17873576061911
88381
1 88381U 25043.00245715 +.00010083 +00000+0 +50582-3 0 00452
2 88381 97.4431 125.2163 0005076 233.7941 126.2823 15.17507826061918
88382
1 88382U 25043.00580368 +.00008440 +00000+0 +42702-3 0 00469
2 88382 97.4354 125.1821 0004227 258.0600 102.0159 15.17263791061916
88383
1 88383U 25043.00598430 +.00008297 +00000+0 +42010-3 0 00450
2 88383 97.4427 125.2119 0005142 245.0736 114.9963 15.17240907061911
88384
1 88384U 25043.00181937 +.00010070 +00000+0 +50389-3 0 00484
2 88384 97.4352 125.1876 0004783 257.0389 103.0310 15.17599295061917
88385
1 88385U 25043.00703772 +.00007260 +00000+0 +36835-3 0 00456
2 88385 97.4320 125.1690 0004716 257.0423 103.0284 15.17214638061917
88386
1 88386U 25043.00696243 +.00009323 +00000+0 +47161-3 0 00480
2 88386 97.4419 125.2057 0005295 234.0136 126.0607 15.17236132061911
88387
1 88387U 25043.00693391 +.00008085 +00000+0 +40984-3 0 00448
2 88387 97.4316 125.1682 0005302 254.4891 105.5757 15.17204417061913
88388
1 88388U 25043.00856361 +.00008547 +00000+0 +43441-3 0 00430
2 88388 97.4361 125.1833 0005085 245.1516 114.9189 15.17096709004273
88389
1 88389U 25043.01039006 +.00004608 +00000+0 +23734-3 0 00438
2 88389 97.4382 125.1878 0005224 242.1888 117.8816 15.16874228004278
88390
1 88390U 25043.92433044 +.00030878 +00000+0 +15183-2 0 00234
2 88390 97.4550 126.1523 0002554 153.5752 206.5612 15.17963806004400
88391
1 88391U 25042.99474835 +.00016278 +00000+0 +79658-3 0 00218
2 88391 97.4395 125.2162 0001272 251.1823 108.9273 15.18269269004240
88392
1 88392U 25043.00462917 +.00029391 +00000+0 +14575-2 0 00216
2 88392 97.4376 125.1943 0007237 227.8182 132.2437 15.17658055004247
88393
1 88393U 25043.00410734 +.00034307 +00000+0 +16938-2 0 00125
2 88393 97.4224 125.1529 0003300 143.7049 216.4409 15.17793986004242
88394
1 88394U 25043.00785884 +.00019883 +00000+0 +10019-2 0 00235
2 88394 97.4227 125.1490 0003970 144.9117 215.2379 15.17195667004240
88395
1 88395U 25043.00291782 +.00034834 +00000+0 +17141-2 0 00196
2 88395 97.4223 125.1540 0002947 140.6913 219.4535 15.17908559004245
88396
1 88396U 25032.45774111 +.00012082 +00000+0 +68094-3 0 00012
2 88396 97.4399 114.8185 0012069 196.3868 163.6975 15.13278458002625
88397
1 88397U 25041.48614379 +.00034899 +00000+0 +17308-2 0 00106
2 88397 97.4564 123.7491 0002585 152.9406 207.1963 15.17634697061684
88398
1 88398U 24242.63730200 +.00005022 +00000+0 +49921-3 0 00189
2 88398 97.7482 317.9175 0006965 120.9306 239.2598 14.92115414001905
88399
1 88399U 24242.63590898 +.00011011 +00000+0 +10763-2 0 00183
2 88399 97.7441 317.9124 0006719 110.0608 250.1335 14.92511785001909
88400
1 88400U 25009V 25063.78989920 +.00009084 +00000+0 +69243-3 0 00071
2 88400 97.4956 145.2730 0010789 225.6377 134.3965 15.02214363007400
88401
1 88401U 25077.69378641 +.00000210 +00000+0 +10950-3 0 00155
2 88401 88.9886 347.9839 0064694 98.4870 262.3653 14.09521533010920
88402
1 88402U 25077.82558936 +.00001018 +00000+0 +71574-3 0 00165
2 88402 88.9908 347.9855 0012989 187.3820 172.7168 13.97391662010937
88403
1 88403U 25077.89744316 +.00000875 +00000+0 +61405-3 0 00175
2 88403 88.9908 347.9776 0012878 187.7210 172.3771 13.97343682010940
88404
1 88404U 25077.82630753 +.00001099 +00000+0 +77541-3 0 00186
2 88404 88.9908 347.9858 0013749 191.5879 168.4983 13.97198501010932
88405
1 88405U 25077.82668198 +.00001234 +00000+0 +87474-3 0 00199
2 88405 88.9908 347.9856 0013054 191.6316 168.4562 13.97056513010936
88406
1 88406U 25077.82659345 +.00000971 +00000+0 +68643-3 0 00211
2 88406 88.9904 347.9853 0013312 191.3966 168.6912 13.97015068010936
88407
1 88407U 25077.89787616 +.00001093 +00000+0 +77047-3 0 00182
2 88407 88.9907 347.9777 0013553 191.4737 168.6134 13.97249626010945
88408
1 88408U 25077.82637471 +.00001031 +00000+0 +72697-3 0 00176
2 88408 88.9908 347.9857 0013508 192.0994 167.9861 13.97208832010930
88409
1 88409U 25077.89847834 +.00001038 +00000+0 +73552-3 0 00167
2 88409 88.9909 347.9778 0013350 191.5725 168.5147 13.96960201010944
88410
1 88410U 25077.82596078 +.00001053 +00000+0 +74112-3 0 00196
2 88410 88.9909 347.9856 0013219 191.1098 168.9790 13.97353086010920
88411
1 88411U 25077.82665008 +.00001094 +00000+0 +77304-3 0 00165
2 88411 88.9908 347.9856 0013238 191.8629 168.2238 13.97120777010938
88412
1 88412U 25077.89774306 +.00000480 +00000+0 +33320-3 0 00174
2 88412 88.9908 347.9776 0013503 190.9164 169.1723 13.97281222010942
88413
1 88413U 25077.82704783 -.00000834 +00000+0 -61749-3 0 00148
2 88413 88.9911 347.9872 0013491 192.1594 167.9259 13.96169990010936
88414
1 88414U 25077.82646916 +.00000948 +00000+0 +66762-3 0 00146
2 88414 88.9912 347.9862 0013468 190.6161 169.4734 13.97193119010930
88415
1 88415U 25077.68339704 +.00000822 +00000+0 +57850-3 0 00144
2 88415 88.9910 348.0015 0013409 192.7952 167.2887 13.97134117010913
88416
1 88416U 25077.89800419 +.00001018 +00000+0 +71740-3 0 00157
2 88416 88.9908 347.9777 0013369 190.6556 169.4340 13.97225359010946
88417
1 88417U 25077.89825682 +.00000489 +00000+0 +34008-3 0 00132
2 88417 88.9910 347.9777 0013522 190.4616 169.6282 13.97150413010941
88418
1 88418U 25077.89811213 +.00000853 +00000+0 +59977-3 0 00135
2 88418 88.9908 347.9776 0013563 192.1054 167.9799 13.97201996010945
88419
1 88419U 25077.82793735 +.00000662 +00000+0 +46742-3 0 00131
2 88419 88.9909 347.9857 0013142 190.2189 169.8723 13.96765791010932
88420
1 88420U 25043.06273222 +.00009325 +00000+0 +90434-3 0 00352
2 88420 97.7427 125.1662 0001733 334.8548 25.2586 14.92887343004227
88421
1 88421U 25043.06216062 +.00009856 +00000+0 +95459-3 0 00353
2 88421 97.7491 125.1764 0001693 62.5658 297.5734 14.92922863004220
88422
1 88422U 25042.99431196 +.00007549 +00000+0 +73271-3 0 00379
2 88422 97.7444 125.1058 0001745 358.1127 2.0086 14.92920453004219
88423
1 88423U 25042.99583366 +.00005626 +00000+0 +55100-3 0 00361
2 88423 97.7447 125.1041 0001823 19.0679 341.0609 14.92671311004210
88424
1 88424U 25043.06376252 +.00001757 +00000+0 +17633-3 0 00411
2 88424 97.7477 125.1726 0002506 53.7166 306.4284 14.92577333004199
88425
1 88425U 25043.06875059 +.00028195 +00000+0 +13966-2 0 00151
2 88425 97.4533 125.3003 0002465 139.0221 221.1198 15.17726206061928
88426
1 88426U 25042.99830803 +.00004557 +00000+0 +22779-3 0 00127
2 88426 97.3639 125.0292 0002551 251.6343 108.4614 15.17930743061916
88427
1 88427U 25043.91795767 +.00046650 +00000+0 +22285-2 0 00143
2 88427 97.4545 126.1593 0001729 175.4343 184.6908 15.18870649004401
88428
1 88428U 24348.66226883 +.00001166 +00000+0 +48957-3 0 00172
2 88428 88.9940 79.1723 0015981 183.9260 176.1811 14.25236777049532
88429
1 88429U 24348.66204060 +.00001145 +00000+0 +48127-3 0 00183
2 88429 88.9940 79.1723 0015117 181.7809 178.3332 14.25151899049532
88430
1 88430U 24348.66078687 +.00001179 +00000+0 +49539-3 0 00195
2 88430 88.9941 79.1722 0015633 184.8948 175.2095 14.25183511049533
88431
1 88431U 24348.65949140 +.00001239 +00000+0 +51021-3 0 00181
2 88431 88.9940 79.1720 0015295 184.2049 175.9018 14.26264400049531
88432
1 88432U 24348.65961651 +.00001061 +00000+0 +43870-3 0 00189
2 88432 88.9940 79.1719 0015431 185.5088 174.5938 14.25941619049538
88433
1 88433U 24347.95751602 +.00000772 +00000+0 +31367-3 0 00169
2 88433 88.9937 79.2528 0014888 187.7966 172.2999 14.26600770049441
88434
1 88434U 24348.65891560 +.00001269 +00000+0 +51933-3 0 00372
2 88434 88.9940 79.1718 0015289 185.0867 175.0174 14.26604147018177
88435
1 88435U 24348.65883965 +.00001195 +00000+0 +48821-3 0 00171
2 88435 88.9939 79.1717 0015128 185.9368 174.1649 14.26649510049547
88436
1 88436U 24348.65884349 +.00001184 +00000+0 +48362-3 0 00188
2 88436 88.9940 79.1718 0015138 185.6696 174.4329 14.26648792049542
88437
1 88437U 24348.65882736 +.00001178 +00000+0 +48140-3 0 00184
2 88437 88.9939 79.1719 0015134 185.8185 174.2835 14.26651567049547
88438
1 88438U 24348.65882059 +.00001190 +00000+0 +48643-3 0 00174
2 88438 88.9939 79.1718 0015124 186.0034 174.0981 14.26652724049548
88439
1 88439U 24348.65877473 +.00001216 +00000+0 +49695-3 0 00176
2 88439 88.9939 79.1718 0015066 185.5560 174.5469 14.26660707049548
88440
1 88440U 24348.65869458 +.00001211 +00000+0 +49464-3 0 00250
2 88440 88.9940 79.1717 0015012 185.5987 174.5041 14.26674255018146
88441
1 88441U 24348.65866462 +.00001223 +00000+0 +49953-3 0 00237
2 88441 88.9940 79.1717 0014994 185.7046 174.3979 14.26679451018166
88442
1 88442U 24348.65865225 +.00001206 +00000+0 +49258-3 0 00288
2 88442 88.9940 79.1717 0014980 185.7884 174.3139 14.26681376018169
88443
1 88443U 24348.65863537 +.00001195 +00000+0 +48808-3 0 00336
2 88443 88.9939 79.1717 0014967 185.8591 174.2430 14.26684086018185
88444
1 88444U 24348.65861251 +.00001192 +00000+0 +48669-3 0 00206
2 88444 88.9939 79.1717 0014954 185.9277 174.1742 14.26687975018190
88445
1 88445U 24348.65859987 +.00001174 +00000+0 +47949-3 0 00200
2 88445 88.9939 79.1717 0014953 186.0324 174.0692 14.26689850049534
88446
1 88446U 24226.90086393 +.00002787 +00000+0 +11459-2 0 00158
2 88446 88.9958 350.3083 0014875 188.8157 171.2778 14.26698956001093
EDIT: I fixed the TLEs by fixing typo in epoch and also adding missing checksums. Also I’ve noticed that some of the epochs are before the launch, which probably means that these objects don’t belong to this launch.
TLE update for Buccaneer MM
Buccaneer MM
1 98648U 00000A 25078.58914826 .00000000 00000-0 00000-0 0 03
2 98648 97.7394 333.5992 0003006 323.8110 256.9581 14.91194950 06
OTP-2
2 98652 97.4396 332.7194 0006612 339.5368 56.8940 15.16208050 01
I’ve also updated the transmitter in DB with the drifted frequency to be 400.4965 MHz.
EDIT:
Object 88328, from this list, looks like to fit fairly enough OTP-2
Updated TLE for JINJUSAT-1B
JINJUSAT-1B
1 98650U 14900A 25078.68132508 .00000000 00000-0 -15058-3 0 03
2 98650 97.4529 332.7487 0002930 200.7175 206.3250 15.17530862 02
About TEVEL2-x, the two TLE in previous post for each group (1-6 and 7-9) seems to work fair enough for these overlapped signals.
