According to the known frequencies that should be ALAINSAT-1. I’m going to change to follow this object in DB.
These should be the Centauri satellites. Can you check them against the new TLE sets?
EDIT: the first one should be Centauri 8 and the second one Centauri 7.
That should be Balkan-1
I agree. Followed during this last pass using satpc32 without any problem. I’ve just moved to 436.885 Mhz at the beginning of the pass
Many thanks Jan
It’s playing a melody at 6:37 (:
Yeap! This is a kind of default for endurosat communication board.
Space-Track identifications (WIP)
| NORAD | SatNOGS DB Suggestion |
| 62610 | SatNOGS DB - EDISON IOD |
| 62612 | SatNOGS DB - GESAT GEN1 |
| 62713 | https://db.satnogs.org/satellite/ZLYR-0017-3141-0563-6718#suggestions |
| 62714 | SatNOGS DB - Centauri 8 |
| 62708 | SatNOGS DB - Centauri 7 |
| 62623 | SatNOGS DB - OTTER |
| 62627 | RAY 1.0 |
| 62632 | SIGI |
| 62648 | LIME |
| 62662 | PIONEER-02 |
| 62671 | SKYBEE-AO1 |
| 62701 | FIREFLY-1 |
| 62704 | FIREFLY-2 |
| 62710 | FIREFLY-3 |
Does anyone know which number the PARUS-T1 is?
No, sorry it seems it isn’t active so unable to match a possible ID
Hi Fredy,
Yes, these are the updated TLEs of AlainSat-1:
0 OBJECT AE
1 62637U 25009AE 25048.79258959 .00012537 00000-0 61591-3 0 9996
2 62637 97.4414 130.9378 0003184 179.7652 180.3584 15.18188708 5156
and the NORAD ID is 62637
Also, the modulation is at 4800 instead of 9600.
fyi: n2yo is now listing NORAD ID 62713 as SATGUS
Is there any information available on SATGUS ?
Frequency, modulation mission info ?
