Hello to the list,
i am new on this list and hoping posting in the correct place.
I am a new linux amateur user,
I have installed in the Ubuntu the Gpredict with the command:
sudo apt-get install gpredict
when i went to select the satellite to track,i have noticed that all the satellites does not show the transponder when i go to select the radio tab:
Click on “edit” at the top of the application, and then select “update transponder data”. It will grab all the current transponder settings from the satnogs database.
–Roy
K3RLD
[edit] I think you have to close all the secondary windows (antenna and radio control, etc.) before updating.
