TMicrosat-1 Ode to Joy
Received in north Laos, 401.025 MHz, using 12-element yagi (fixed AZ/EL angle), RTL v4 SDR, SDR++
What type antenna are you using?
I used an 11-element yagi, but the signal was strong, so a yagi with less gain should also work ok.
