[TLE update request] 98197 BEE-1012, UELYSys & SD-1SAT
Hi @bali @fredy!
I am Yonghoon Chung from the BEE-1012 operations team at Yonsei University.
Could you please update BEE-1012 (98197)’s TLE to OBJECT F (2026-229F, A0960)? Our ground station has been receiving BEE-1012 beacons on passes predicted for this object since Oct 11, and the SD-1 SATs team also identified BEE-1012 as OBJECT F in the KSLV-2 launch thread. The TLE currently in the DB is the pre-launch one, which is now about 5.5 minutes ahead of the satellite, so most SatNOGS observations miss it.
Latest from space-track.org:
0 OBJECT F
1 A0960U 26229F   26287.20234653  .00002127  00000-0  18716-3 0  9994
2 A0960  97.6977  23.2575 0010572  68.1733 292.0613 14.97525079  1079
With the temporary NORAD ID used in the DB:
0 BEE-1012
1 98197U 26229F   26287.20234653  .00002127  00000-0  18716-3 0  9993
2 98197  97.6977  23.2575 0010572  68.1733 292.0613 14.97525079  1078
Thank you!
TLE is now in DB and Network, please keep me updated with similar posts, as I’m busy these days to finish the support of NORAD IDs >99999 in DB and Network and not able to make analysis.
Thank you for updating BEE-1012. Could you please also update UEL-Y-Sys (98198) to OBJECT E (2026-229E, A0959)? Our shared ground station receives UEL-Y-Sys on passes predicted from this object.
0 OBJECT E
1 A0959U 26229E   26287.47011265  .00002402  00000-0  21122-3 0  9994
2 A0959  97.6976  23.5202 0010230  69.9918 290.2405 14.97429959  1115
0 UEL-Y-Sys
1 98198U 26229E   26287.47011265  .00002402  00000-0  21122-3 0  9996
2 98198  97.6976  23.5202 0010230  69.9918 290.2405 14.97429959  1117
We will keep posting updated TLEs for both satellites here every few days until the >99999 support is ready.
Thank you!
Thanks, I’ve added them too.
Please do, hopefully, I expect to have a release about it before the end of the month.
