The TLE for SOC-i (98887) is now the same as TechEdSat-11 (98884), but SOC-i (98887) has different situations, and most of its observers have failed.
Please check it.
Please check it.
Please suggest what ID should be used.
Based on the TLE available:
OBJECT A
1 60203U 24125A 25060.52483874 .00032953 00000+0 10763-2 0 9999
2 60203 97.2919 273.6127 0022230 131.4335 228.8821 15.31438662 36624
OBJECT B
1 60204U 24125B 25061.03882811 .00092456 00000+0 16886-2 0 9997
2 60204 97.2858 276.7562 0012600 106.2242 254.0396 15.48989946 36881
OBJECT C
1 60205U 24125C 25060.55951022 .00039540 00000+0 11492-2 0 9998
2 60205 97.2905 274.4303 0017653 120.4405 239.8585 15.35200868 36689
R5-S4
1 60206U 24125D 25060.55269213 .00019540 00000+0 70463-3 0 9995
2 60206 97.2933 273.2809 0023746 125.9221 234.4227 15.28296274 36609
R5-S2
1 60207U 24125E 25060.51816828 .00018992 00000+0 67469-3 0 9994
2 60207 97.2928 273.3105 0023776 127.2145 233.1270 15.28790545 36601
TECHEDSAT-11
1 60208U 24125F 25061.12512936 .00019562 00000+0 69076-3 0 9996
2 60208 97.2933 273.8731 0023745 126.1235 234.2208 15.28983020 36708
MESAT1
1 60209U 24125G 25060.56516205 .00030142 00000+0 99850-3 0 9997
2 60209 97.2922 273.5468 0021696 133.0995 227.2066 15.31013922 36628
FIREFLY ALPHA R/B
1 60210U 24125H 25060.57119200 .00025791 00000+0 68025-3 0 9998
2 60210 97.2828 277.0414 0042250 116.0395 244.5209 15.37537445 36784
CATSAT
1 60246U 24125J 25060.56777469 .00017223 00000+0 62123-3 0 9997
2 60246 97.2706 273.7601 0046739 90.0788 270.5807 15.27527684 34708
Thank you so much.
It might be OBJECT A, B, or C. Other satellites are clear and not SOC-i (98887). I need to track each one to confirm.
I’m tracking them and will send the results in the coming days.
For now based on the previous post I’ve randomly changed the NORAD ID we follow for SOC-i to 60204. @mohammadreza looking forward to your results to fix and identify the NORAD ID for SOC-i.
PS I’ve also changed a couple of NORAD IDs for the rest of the satellites of this launch based on space-track identifications.
Sorry for the late response. I had to analyze the data accurately.
I tracked and observed OBJECT A, B, and C, but unfortunately, none of them appear to be SOC-i (98887). I mean, no one transmitted on 437.1250 MHz during my tracking timeline. It seems SOC-i might not be operational anymore, or the frequency is different…
Other friends, please track it as well.
@mohammadreza do you know if SOC-i was ever operational? Maybe we can have some observations of that period that we can check and find out which object was.
