I want to use Gpredict on my Raspberry Pi 4B running Bookworm OS. However, I noticed that the version on the Raspberry Pi doesn’t recognize some satellites, whereas the Windows version has newer ones. The screenshot below displays the Raspberry Pi version (2.3-72-gc596101-3) on the left and the Windows version (win32-2.3.37) on the right:
This list is built from the TLE update process, adding satnogs list to the TLE sources will pull all those into that list https://db.satnogs.org/api/tle/?format=3le
There’s a lot of other sources out there as well.
The files that gpredict uses (for all versions) is in ~/.config/Gpredict so installing other versions will not affect the configuration (much).
In windows this is located in the user home under Gpredict, like C:\Users\username\Gpredict
