Hi everyone,
I’m trying to improve my SNR.
I found this cheap LNA online.
someone already tried?
Any feedback?
thanks in advance!
Hi everyone,
Any feedback?
thanks in advance!
I have no experience with such wideband preamplifiers.
But in general, I would ask at least the following questions.
For 430 - 440 MHz I’m using the VV 435 VOX from SHF Elektronik.
And for 144 - 146 MHz the equivalent one.
to answer to you:
Good morning,
few questions:
I currently have 5 of them in use. Low noise, as advertised, but I use all 5 of them behind a bandpass filter for the wanted frequency. So, 403, 435, 1550 , 2250 MHz and one running with highpass filter 1400 MHz and up.
Answer your questions:
I think I can put the LNA between the RG174 and the extension 3m cable no?
the scheme inside… I’m not sure… I just bought it from here
Ah… so another filter? any suggestions or references?
I’m going to check your waterfalls ![]()
Are you happy with this setup?
I’m new sorry… Trying to learn!
Sorry, I remember, you have V antenna on balcony. OK, its a short cable.
In your situation, you shall have more success if you will use another antenna with some gain. As I remember the photo, I suppose you can use a 3 elements Yagi (but in this case you shall receive in good condition only the one band, VHF or UHF), or a double bi-quad (like I am using now). The bi-quad is wide band, you can use it from 400 - 440 Mhz, for receptions.
It depends what can you put on balcony, without metals in front of antenna.
Cristian - YO4DFT
station 3600
If you want, I can describe for you how you can build in 60 minutes a bi-quad antenna for UHF. You need 2 meters of Cu wire, 3-4 mm diameter, a piece of hard cardboard, possibly from a packaging box, 60 x 40 cm and a roll of self-adhesive aluminum foil, used in construction.
Cristian - YO4DFT
There are some nice DK7ZB designs, have a look this one for example.
Place at a 45 degree angle from your balcony.
“another filter” ?
At this moment it’s not completely clear to me for which frequency range you try to improve your SNR. Is it regular radio reception, or for use on a satnogs RX station. If the latest, which frequency range do you plan on for reception. A bandpass filter can be some 434 MHz SAW filter from Alie (I use 2 of those) but with that filter no reception outside the 430 - 440 MHz range is possible. With the antenna’s from the kit you linked to I would indeed suggest to improve the antenna side before adding any preamp.
