Study case when you’re unsure whether this is a signal or not: CSTP-4.3 (64882)
Regarding Observation 14742689 …
Compare it with the observation results using strf at another time, which reinforce the conclusion.
Two lines in one observation (around 60 seconds between signal); transmitter mode lora, generally, yes, this is a signal.
Nice catch ! The bandwidth in the observation should be a bit wider so you can actually see the left and right transmitter signal, to exclude the thought “nah, signal bursts, invalid obs”
