Strongest satellite in UHF band
Anybody an idea which is the strongest or easiest satellite to track. I.e a satellite with constant signal, of course CW from there observations. I need a nice satelite to compare the GS with? We need some competition here to see who has the best GS :wink:
Maybe AOBA-VELOX 3!?
Ok thanks, will track that one!
LUSAT seems much stronger, or perhaps my receiver hears better :blush:
https://network.satnogs.org/observations/129727/
https://network.satnogs.org/observations/128537/
:smiling_imp:
https://network.satnogs.org/observations/109409/
It helps when you select a 89 degrees elevation path :joy:
In cinemas near you. Fight of the strongest :joy:
I wish I could receive satellites like that.
The initial suggestion was also at a high elevation so it was necessary for proper comparison.
How about this: 32 deg elevation, still ridiculously high SNR:
https://network.satnogs.org/observations/130442/
LUSAT is literally a flying signal generator :relaxed:
Then you will be able to hear it on a handheld!
https://network.satnogs.org/observations/130971/
Lusat is indeed a signal gen with a PA or very good antenna. Will use this to β€œgauge” a GS at UHF! If you cannot receive this there is something wrong with your GS.
