Hello! This will mainly use X band, but sometimes UHF downlink.
Thanks Foxiks for all your gently info.
and for your software.
STRATOSAT TK-1 schedule of image transmissions:
16.01
Image 1: 17:20 - 17:22 - 17:24 - 17:26 - 17:28
Image 2: 18:56 - 18:58 - 19:00 - 19:02 - 19:04 - 19:06
17.01
Image 3: 06:24 - 06:26 - 06:28 - 06:30 - 06:32
Image 4: 07:58 - 08:00 - 08:02 - 08:04 - 08:06
Image 5: 09:33 - 09:35 - 09:37 - 09:39
Image 3: 17:14 - 17:16 - 17:18 - 17:20 - 17:22 - 17:24
Image 1: 18:50 - 18:52 - 18:54 - 18:56 - 18:58 - 19:00
UB1QBJ
Np! ![]()
2024-01-16 18:58utc - Image 2
2024-01-17 08:0xutc - Image 4
2024-01-17 18:5xutc - Image 1
I want to try to receive it.
But I found that I couldnât use the StratoSat TK-1 Decoder software normally.
I can open the GUI and stratosat.exe, but the soundmodem doesnât show up properly (I can see it in the task manager, however) and stratosat.exe keeps trying to connect.
Whatâs the problem?
Try to start the Soundmodem before starting the decoder GUI.
As an alternative to the Soundmodem use gr_satellites.
Hello! You need to try changing the settings in hs_soundmodem.ini and try again! Replace
[Window]
Top=515
Left=1030
on
[Window]
Top=0
Left=0
2024-01-25
18:01:48 18:03:09 18:04:10 18:05:10 18:05:35 UTC
offset = 0
Data I uploaded to SatNOGS DB
Why are there only picture transmissions over central/eastern Europe? People from Portugal and Spain want images too! ![]()
There will be image transmissions over western Europe. These were transmitted over control centre
StratoSat TK-1 Image
2024-02-14 18:59:49, 19:01:49 UTC
StratoSat TK-1 Thumbnails
2024-02-15
09:35:33, 09:37:41 UTC
09:35:57 UTC
09:36:23 UTC
09:36:50, 09:37:18 UTC
New image transmissions scheduled
Format: Number_of_picture. Place_below_when_imaging Time_of_imaging (time_of_image_transmissions)
2024-02-28
- California, USA 17:42 (18:51-18:53-18:55-18:57)
- South Pole 19:52 (20:25-20:27-20:29-20:31)
- Alaska 20:46:30 (22:19-22:21-22:23-22:25)
- Tasmania 22:49:35 (23:54-23:56-23:58)
2024-02-29
- Australia 00:23 (01:38-01:40-01:42-01:44)
- Afghanistan 04:51 (06:19-06:21-06:23)
- South Africa 06:43:30 (07:53-07:55-07:57-07:59)
- Gabon 08:12 (09:31-09:33-09:35)
- Ivory Coast 09:45 (10:47-10:49-10:51-12:20-12:22-12:24)
- Argentina 13:12 (17:11-17:13-17:15-17:17)
- South Pole 19:43 (22:10-22:12-22:14-22:16)
2024-03-01
- Pakistan 04:46 (06:11-06:13-06:15-06:17)
- UAE 06:25 (07:45-07:47-07:49-07:52)
- Namibia 08:08 (09:24-09:26-09:28)
- Brazil 11:17 (17:03-17:05-17:07-17:09)
- Canada 17:20 (18:37-18:39-18:41-18:43)
- New Zealand 20:58:35 (22:04-22:06-22:08)
2024-03-02
- Indonesia 01:37 (06:04-06:06-06:08)
- Caucasus 06:11 (07:37-07:39-07:41-07:43-07:45)
- Namibia 08:00 (09:16-09:18-09:20-09:22)
- Antarctica 13:00 (16:55-16:57-16:59-17:01)
- USA 17:17 (18:29-18:31-18:33-18:35)
- Alaska 18:50 (20:04-20:06-20:08-20:10-21:57-21:59)
2024-03-03
- China 01:16:30 (04:19-04:21-04:23-05:55-05:57-05:59
- Yemen 06:10:30 (07:30-07:32-07:34-07:36)
- Skeleton Coast (Namibia) 07:55 (08:52-08:54-09:05-09:07-09:09-09:11-09:13)
- Suriname 12:35 (16:50-16:52-16:54-18:22-18:24-18:26-18:28)
- South Pole 19:20 (19:57-19:59-20:01)
2024-03-04
- Korea 2024-03-03 23:29 (04:12-04:14-04:16-05:50-05:52-05:54)
- Mozambique 06:10 (07:23-07:25-07:27-07:29)
- South Africa 07:49 (08:58-09:00-09:02-09:04)
- Colombia 14:02 (16:42-16:44-16:46)
- USA 17:04 (18:15-18:17-18:19-18:21)
- South Pole 19:13 (19:49-19:51-19:53-19:55)
- Alaska 20:11 (21:24-21:26-21:28-21:42-21:44-21:46)
- it must be
2024-02-28 18:53 UTC
Yes! Test image:)
Image 7, captured 2024-02-29 07:53 UTC
Interestingly the signal level was high, but the end of the image is missing. I migh be able to get the whole image from the 3 transmissions if I combine the kss files somehow.
I found a bug in https://github.com/kng/geoscan-tools/blob/main/stratosat_simple.py
this is the image in its full glory:
Iâm super happy
