Here is my Satnogs client support output
“versions”: {
“satnogs-client”: “1.5”,
“satnogs-client-ansible”: “202105092144”,
“satnogs-flowgraphs”: “1.3.1-1”,
“gr-satnogs”: “2.2.1.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14satnogs2”,
“satnogs-config”: “0.12”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2021-05-14T12:29:26.508701+00:00”,
“distribution”: {
“DESCRIPTION”: “Debian GNU/Linux 10 (buster)”,
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Debian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “username”,
“release”: “4.19.0-16-amd64”,
“version”: “#1 SMP Debian 4.19.181-1 (2021-03-19)”,
“machine”: “x86_64”,
“processor”: “”
“memory”: {
“total”: 16498626560,
“available”: 15750418432,
“percent”: 4.5,
“used”: 412835840,
“free”: 15314952192,
“active”: 582295552,
“inactive”: 376504320,
“buffers”: 76914688,
“cached”: 693923840,
“shared”: 42930176,
“slab”: 127078400
“disk”: {
“total”: 231216836608,
“used”: 20399517696,
“free”: 199000760320,
“percent”: 9.3
“configuration”: {
“experimental”: true,
“hamlib_utils_rot_enabled”: true,
“hamlib_utils_rot_opts”: “-m 603 -r /dev/ttyACM0 -s 9600 -T 0.0.0.0”,
“iq_dump_filename”: “False”,
“satnogs_antenna”: "SoapySDRUtil --probe=“driver=airspy,serial=28852593"”,
“satnogs_gain_mode”: “Settings Field”,
“satnogs_other_settings”: "“LNA=12,MIX=8,VGA=11"”,
“satnogs_rf_gain”: “10”,
“satnogs_rot_model”: “ROT_MODEL 603”,
“satnogs_rot_port”: “/dev/ttyACM0”,
“satnogs_rx_samp_rate”: “2500000.000000”,
“satnogs_soapy_rx_device”: “RX”,
“satnogs_station_elev”: “120”,
“satnogs_station_id”: “1062”,
“satnogs_station_lat”: “48.807”,
“satnogs_station_lon”: “2.229”,
“satnogs_waterfall_min_value”: “-101”,
“sentry_enabled”: true
