Hello Everyone,
My UHF station failed and I pulled it into my shop for a refresh this weekend. I loaded the current Satnogs distribution and configured it. I loaded the SoapyRemote Server and used CubicSDR on another machine to determine the correct gain. I can see signals using CubicSDR, but when I schedule a pass, the ground station isn’t uploading any data.
Here is the setup information
“versions”: {
“satnogs-client”: “1.4”,
“satnogs-client-ansible”: “202010161917”,
“satnogs-flowgraphs”: “1.2.2-1”,
“gr-satnogs”: “2.1.2.1-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.2.0-2”,
“satnogs-config”: “0.11”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2020-11-15T15:49:16.493672+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “KO2F-UHF-1”,
“release”: “5.4.72-v7+”,
“version”: “#1356 SMP Thu Oct 22 13:56:54 BST 2020”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 969760768,
“available”: 793661440,
“percent”: 18.2,
“used”: 114221056,
“free”: 470032384,
“active”: 213037056,
“inactive”: 232710144,
“buffers”: 24686592,
“cached”: 360820736,
“shared”: 6483968,
“slab”: 32509952
“disk”: {
“total”: 15346831360,
“used”: 3584303104,
“free”: 11085561856,
“percent”: 24.4
“configuration”: {
“satnogs_antenna”: “Eggbeater”,
“satnogs_rf_gain”: “29.0”,
“satnogs_station_elev”: “186”,
“satnogs_station_id”: “201”,
“satnogs_station_lat”: “38.555972”,
“satnogs_station_lon”: “-78.062523”
I also installed and configured the Satnogs-Monitor on this station. I verifies the scheduled passes and tracks them fine, but doesn’t display a waterfall when the bird is overhead.
I would appreciate any troubleshooting suggestions…
Bob
KO2F
