After awhile my station fails to upload any more data to satnogs. Sometimes after a few hours it starts working again, other times a restart of the satnogs client is required, and other times it fills up /tmp and needs a full reboot. Anyone got any ideas on how to troubleshoot this best. It’s really frustrating…
satnogs-client-ansible-202002272333, satnogs-client-1.1, gr-satnogs-2.0.1-1
Mar 25 22:22:16 70 systemd[1]: Started SatNOGS client.
Mar 25 22:24:31 70 satnogs-client[23125]: 2020-03-25 22:24:31,439 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 400
Mar 25 22:25:18 70 satnogs-client[23125]: 2020-03-25 22:25:18,087 - apscheduler.executors.default - ERROR - Job "post_data (trigger: interval[0:02:00], next run at: 2020-03-25 22:26:19 UTC)" raised an exception
Mar 25 22:25:18 70 satnogs-client[23125]: Traceback (most recent call last):
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
Mar 25 22:25:18 70 satnogs-client[23125]: chunked=chunked)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 354, in _make_request
Mar 25 22:25:18 70 satnogs-client[23125]: conn.request(method, url, **httplib_request_kw)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3.7/http/client.py", line 1244, in request
Mar 25 22:25:18 70 satnogs-client[23125]: self._send_request(method, url, body, headers, encode_chunked)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3.7/http/client.py", line 1290, in _send_request
Mar 25 22:25:18 70 satnogs-client[23125]: self.endheaders(body, encode_chunked=encode_chunked)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3.7/http/client.py", line 1239, in endheaders
Mar 25 22:25:18 70 satnogs-client[23125]: self._send_output(message_body, encode_chunked=encode_chunked)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3.7/http/client.py", line 1065, in _send_output
Mar 25 22:25:18 70 satnogs-client[23125]: self.send(chunk)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3.7/http/client.py", line 987, in send
Mar 25 22:25:18 70 satnogs-client[23125]: self.sock.sendall(data)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3.7/ssl.py", line 1015, in sendall
Mar 25 22:25:18 70 satnogs-client[23125]: v = self.send(byte_view[count:])
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3.7/ssl.py", line 984, in send
Mar 25 22:25:18 70 satnogs-client[23125]: return self._sslobj.write(data)
Mar 25 22:25:18 70 satnogs-client[23125]: socket.timeout: The write operation timed out
Mar 25 22:25:18 70 satnogs-client[23125]: During handling of the above exception, another exception occurred:
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
Mar 25 22:25:18 70 satnogs-client[23125]: timeout=timeout
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
Mar 25 22:25:18 70 satnogs-client[23125]: _stacktrace=sys.exc_info()[2])
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 367, in increment
Mar 25 22:25:18 70 satnogs-client[23125]: raise six.reraise(type(error), error, _stacktrace)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/six.py", line 692, in reraise
Mar 25 22:25:18 70 satnogs-client[23125]: raise value.with_traceback(tb)
Mar 25 22:25:18 70 satnogs-client[23125]: urllib3.exceptions.ProtocolError: ('Connection aborted.', timeout('The write operation timed out'))
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/apscheduler/executors/base.py", line 125, in run_job
Mar 25 22:25:18 70 satnogs-client[23125]: retval = job.func(*job.args, **job.kwargs)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py", line 126, in post_data
Mar 25 22:25:18 70 satnogs-client[23125]: timeout=45)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/requests/api.py", line 131, in put
Mar 25 22:25:18 70 satnogs-client[23125]: return request('put', url, data=data, **kwargs)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/requests/api.py", line 60, in request
Mar 25 22:25:18 70 satnogs-client[23125]: return session.request(method=method, url=url, **kwargs)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
Mar 25 22:25:18 70 satnogs-client[23125]: resp = self.send(prep, **send_kwargs)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
Mar 25 22:25:18 70 satnogs-client[23125]: r = adapter.send(request, **kwargs)
Mar 25 22:25:18 70 satnogs-client[23125]: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 498, in send
Mar 25 22:25:18 70 satnogs-client[23125]: raise ConnectionError(err, request=request)
Mar 25 22:25:18 70 satnogs-client[23125]: requests.exceptions.ConnectionError: ('Connection aborted.', timeout('The write operation timed out'))
