Hello,
My station is in test but I am improving it little by little.
As of yesterday, I now have a better quality RTL-SDR with an LNA and a QFH antenna.
I have a slight drift that I will adjust these days and maybe I will need to increase the gain a little (but from what I read, it would not always be good with an LNA)
So now the waterfall usually displays something
The question I ask myself: For the station to be useful, it must be able to display something but also produce quality data. (If I understood the principle of Satnogs correctly)
So how do you make sure this is the case?
If I compare with another nearby station (to have the same data frame), in case of difference it will be difficult for me to determine which of the data is correct.
I can possibly watch a CW beacon.
For Aalto-1, it is “AALTO1”
On my last observation (https://network.satnogs.org/observations/4061838/), I received “E ILTO E” …
So it’s not terrible …
(I will be increasing the gain over the next few days to see if I can improve this)
With this kind of problem is a station useful for the project?
In view of the current equipment, should I expect better or the “hunt for quality data” is only possible with a rotor and a Yaggi type antenna?
