from yesterday I’m trying to run again my station. Two month’s ego I changed the SD card in my RPi to try something else. Now I trying to go back to satNOGS but have problems after update. When I run my old SD img (satNOGS 0.9.1) it works.
After running
sudo apt update
and thensudo apt upgrade
- sudo satnogs-setup and update as in (https://wiki.satnogs.org/SatNOGS_Client_Setup)
- sudo satnogs-setup becouse not all old settings ware transferred to new version.
I get observations without waterfall (see http://network.satnogs.org/observations/3561693/)
I tried to make fresh SD with downloaded img but have the same symptoms. This needs to be something in settings and not the hardware because version 0.9.1 works.
systemctl status satnogs-client on the old, updated SD shows:
satnogs-client.service - SatNOGS client
Active: active (running) since Fri 2021-01-29 10:52:17 UTC; 19min ago
Main PID: 381 (satnogs-client)
Tasks: 22 (limit: 2063)
└─381 /var/lib/satnogs/bin/python3 /var/lib/satnogs/bin/satnogs-client
Jan 29 11:05:45 SatNOGS satnogs-client[381]: File “/usr/bin/satnogs_fm.py”, line 443, in
Jan 29 11:05:45 SatNOGS satnogs-client[381]: main()
Jan 29 11:05:45 SatNOGS satnogs-client[381]: File “/usr/bin/satnogs_fm.py”, line 426, in main
Jan 29 11:05:45 SatNOGS satnogs-client[381]: tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, dec
Jan 29 11:05:45 SatNOGS satnogs-client[381]: File “/usr/bin/satnogs_fm.py”, line 89, in init
Jan 29 11:05:45 SatNOGS satnogs-client[381]: tune_args, settings, samp_rate_rx, “fc32”)
Jan 29 11:05:45 SatNOGS satnogs-client[381]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 166, in make
Jan 29 11:05:45 SatNOGS satnogs-client[381]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Jan 29 11:05:45 SatNOGS satnogs-client[381]: RuntimeError: soapy::source: Unsupported sample rate. Rate must be in the range [8000.000000, 8000.000000] [16000.000000,
Jan 29 11:05:48 SatNOGS satnogs-client[381]: satnogsclient.observer.observer - ERROR - No waterfall data file found
I’m using RTL-SDR v3 and tried several values in SATNOGS_RX_SAMP_RATE: 2.048e6 (as in wiki), 2.048, 2048000
In /tmp/.satnogs/data/ I have only Incomplete and it is empty
What could be wrong?
For sure it is something easy and basic but my RPi skills are poor.
Please help
Adam SQ3XZ
