Started SatNOGS client
pi@pi:~$ journalctl -u satnogs-client.service
– Logs begin at Thu 2019-02-14 15:41:59 IST, end at Tue 2020-02-11 17:31:09 IST. –
Feb 11 17:30:21 pi systemmd[1]: Started SatNOGS client.
pi@pi:~$
This is the output that i am getting after running the installation verification command. This is different than given in the client setup. Is the installation done correctly?
Looks good to me. Same output I get right after startup.
No news… good news :slight_smile:
Just to be sure that everything went well, check the status of your station in Network. If it is online then you are fine!
