SR-0/SSLV-D3 Mission
New Satellite Alert
Space Rickshaw-0 DemoSat Mission (SR-0), planned for launch onboard SSLV-D3 from SHAR, India. NET July 10.
IARU Coordination: IARU Sat Coordinator
Orbital Parameters: 480km circular, 37.2 degree Inclination.
Carrier Frequency: 437.4 Mhz Bandwidth: 125.0 kHz Spreading Factor: 9 Coding Rate: 7 Output Power: 22 dBm / 30 dBm Preamble Length: 8 Symbols Sync Word: 0x12 Gain: 0
LORA:
Spreading Factor: 9
Coding Rate: 7
Preamble Length: 8
AX.25/FSK
Frequency Shift: 425 Hz
Baud Rate: 1k2
Baud Stop Bits: 1
Predicted TLE and webpage will be available soon.
Looking forward to all your support in tracking. Thank you.
Co-passenger: IITMSAT - IARU Sat Coordinator
Thanks for the info, in the next days we will prepare for this launch.
@riftron is the 10th of July still valid for the launch?
I can not find any official reference online for that date.
The launch is delayed for a bit. Partial NOTAM is out starting on the 28th of July.
https://www.reddit.com/r/ISRO/comments/1dv88qv/sslvd3sr0_partial_notam_is_out_enforcement/
Thanks for the update, then I’ll let it a little behind to focus to Ariane 6 which is on July 9th.
