I’m looking for a commercial rotator and specifically the SPID variant from RFHamstore - for my 2m prime focus solid dish antenna (for now, as I’m planning to “upgrade” to a 1,9m mesh one or possibly the 2.4m mesh variant).
The question is – do I need the standard version with the 0.5 degrees resolution (and lower cost) or the High Resolution one with the 0.1 degrees increments? The setup will be for L and S-Band observations.
So, do I need the extra fine resolution of 0.1 degrees… I’m guessing that I don’t, especially with a homemade antenna feed that will not be perfectly made and ideally positioned! It will be better to have a smaller diameter dish or a non dish antenna with a bigger lobe - but the 2m solid dish one is the one that I have now…
Furthermore, the standard versions are available with the Rot2Prog controllers but they are going to release the newest MD-03 controllers soon. I’m guessing that the newest MD-03 controllers are the way to go…
