will it be updated for the existing scheduled observations? like: SatNOGS Network - Observation 7823754
Yes it does after some time.
It does not seem really matched, there is a slight difference now: SatNOGS Network - Observation 7823754
Currently this is the best match. I can think two scenarios:
- There are more TLE to come
- As the TLE is still not assigned it may describe more than one satellites, also it is ~1 day old, which could make it inaccurate. To be honest, 1 day old TLE at this altitude shouldnāt make a significant difference.
I suggest we wait for 1-2 days to see and at the same time we can generate/use a more accurate TLE if you have one.
For ISTANBUL we were observing object M 56943ā¦ Got signals with dopplerā¦
When matched those to other TLEs using IKHNOS looks like ISTANBUL is 56942
I know this belongs to another identified object but that is what it is ā¦ looks better than 56943
@fredy can I ask for one more change on ISTANBULās TLE on satnogs network
here are the IKHNOS outputs for 2 observations
73ās de
OH2UDS / TA7W
Baris
None of the signal in both waterfalls you posted belongs to this launch. Iāve re-vetted the observations as bad.
ISTANBUL is one of these OBJECTS:
0 OBJECT BR
1 56989U 23084BR 23188.41786933 .00017655 00000-0 10137-2 0 9995
2 56989 97.5070 304.6146 0018235 145.5028 214.7390 15.12444878 3716
0 OBJECT BS
1 56990U 23084BS 23188.74106830 .00012837 00000-0 72848-3 0 9990
2 56990 97.5116 304.9654 0015600 136.4964 223.7501 15.12978354 3767
0 OBJECT BT
1 56991U 23084BT 23188.40067440 .00011020 00000-0 60640-3 0 9997
2 56991 97.5113 304.6493 0014029 119.9045 240.3582 15.14138744 3715
0 OBJECT BK
1 56226U 23084BK 23188.72995128 .00007925 00000-0 43812-3 0 9997
2 56226 97.5135 304.9870 0012293 128.6309 231.6025 15.14089930 3765
0 OBJECT BL
1 56227U 23084BL 23189.07112612 .00015298 00000-0 85851-3 0 9997
2 56227 97.5150 305.3063 0013582 127.7234 232.5230 15.13362885 3817
0 OBJECT BM
1 56228U 23084BM 23188.41039393 .00009663 00000-0 54571-3 0 9993
2 56228 97.5151 304.6536 0013738 129.7571 230.4872 15.13249413 3714
0 OBJECT BN
1 56229U 23084BN 23188.74093898 .00007568 00000-0 42865-3 0 9995
2 56229 97.5149 304.9794 0013780 127.7055 232.5427 15.13219799 3761
0 OBJECT BP
1 56230U 23084BP 23188.61662199 .00034993 00000-0 19876-2 0 9996
2 56230 97.5137 304.8322 0017419 151.5329 208.6857 15.12696561 3742
0 OBJECT BQ
1 56231U 23084BQ 23188.61971878 .00010577 00000-0 61506-3 0 9994
2 56231 97.5133 304.8279 0018397 147.5038 212.7329 15.12106591 3747
It can not be 56942 as this object is tracked before its deployment from ION.
Iāve went through all the vetted as good observations of ISTANBUL, Iāve revetted all as bad, specifically:
SatNOGS Network - Observation 7822596 ā Signals donāt belong to this launch, also the one at the right is too off for ISTANBUL frequency
SatNOGS Network - Observation 7822590 ā Signal at the top doesnāt belong to this launch
SatNOGS Network - Observation 7822598 ā Signals donāt belong to this launch
SatNOGS Network - Observation 7808999 ā No signal at all
SatNOGS Network - Observation 7809003 ā Signals too off from expected ISTANBUL frequency, also donāt much the expected FSK 600
SatNOGS Network - Observation 7808994 ā Signal too off from expected ISTANBUL frequency, also doesnāt much the expected FSK 600
SatNOGS Network - Observation 7799662 ā Signal too off from expected ISTANBUL frequency
SatNOGS Network - Observation 7769809 ā Signal too off from expected ISTANBUL frequency
SatNOGS Network - Observation 7769053 ā Singal doesnāt much the expected FSK 600
Let me know if I miss something.
Latest Status Update:
Temporary NORAD ID | Satellite | NORAD ID to follow | Other NORAD IDs | Identified | Deployed | Last Update |
RECEIVED AND DEMODULATED | ||||||
ION SCV-011 | 56957 | - | YES | YES | Identified, here are the ikhnos results | |
99187 | ROM-2 | 56230 | 56226-56229,56231,56989-56991 | NO | YES | Randomly change to follow 56230, other possible 56226-56229,56231, 56989-56991 |
99182 | MRC-100 | 56231 | - | NO | YES | Changed to follow 56231, waiting for a couple more observations for identification |
99115 | FOSSASAT-FEROX 14 - PlatziSat-1 | - | all | NO | YES | Received according to tinygs |
99100 | SpeiSat | 56991 | - | NO | YES | Changed to follow 56991, waiting for a couple more observations for identification |
99114 | FOSSASAT-FEROX 15 | - | all | NO | YES | Received according to tinygs |
99112 | FOSSASAT-FEROX 17 | - | all | NO | YES | Received according to tinygs |
99097 | MDQSAT-1C | - | all | NO | YES | Received according to tinygs |
99096 | MDQSAT-1D | - | all | NO | YES | Received according to tinygs |
RECEIVED | ||||||
99258 | Tomorrow-R2 | 56959 | 56958, 56960(unlikely) | NO | YES | No update |
Otter Pup | 56933 | - | YES | YES | Identified, here are the ikhnos results | |
OBJECT 23084BH (Transporter 8 Satellite E) | 56987 | - | YES | YES | Identified, here are the ikhnos results | |
OBJECT 23084AJ (Transporter 8 Satellite D) | 56964 | - | YES | YES | Identified, here are the ikhnos results | |
OBJECT 23084AG (Transporter 8 Satellite B) | 56962 | - | YES | YES | Identified, here are the ikhnos results | |
OBJECT 23084C (Transporter 8 Satellite A) | 56934 | - | YES | YES | Received again and Identified, here are the ikhnos results | |
RECEPTION STOPPED | ||||||
99078 | Transporter 8 Satellite F | 56938 | 56932-56937, 56939-56944 | NO | YES | No reception since 2023-06-15 11:31, changed to follow 56938, other possible 56932-56937, 56939-56944 |
NOT RECEIVED | ||||||
99082 | Transporter 8 Satellite C | - | - | NO | YES | Not currently observing, trying to figure out if they are known or unknown satellites |
99192 | Istanbul | 56228 | 56226,56227,56229-56231,56989-56991 | NO | YES | Randomly change to follow 56228, other possible 56226,56227,56229-56231,56989-56991 |
99101 | Outpost Mission 0 | 56991 | 56226-56231,56989,56990 | NO | YES | Randomly change to follow 56991, other possible 56226-56231,56989,56990 |
99113 | FOSSASAT-FEROX 16 | - | - | NO | YES | |
99352 | URESAT-1 | 56989 | 56226-56231,56990,56991 | NO | YES | Randomly change to follow 56989, other possible 56226-56231,56990,56991 |
99095 | Pleiades-Squared | - | - | NO | YES | |
99104 | QPS-SAR-6 | - | - | NO | YES | |
99106 | GREGOIRE | - | - | NO | YES | |
99109 | XVI | - | - | NO | YES | |
99110 | Droid.001 | - | - | NO | YES | |
99107 | AFR-1 | - | - | NO | YES | |
99105 | Orbiter SN3 | - | - | NO | YES | |
99111 | EIVE | - | - | NO | YES | |
99102 | Winnebago-1 | - | - | NO | YES | |
99108 | MuSat-1 | - | - | NO | YES | |
99260 | Blackjack Aces-2 | - | - | NO | YES | |
99262 | Blackjack Aces-4 | - | - | NO | YES | |
99259 | Blackjack Aces-1 | - | - | NO | YES | |
99261 | Blackjack Aces-3 | - | - | NO | YES | |
99099 | SATLLA-2I | 56227 | 56226,56228-56231,56989-56991 | NO | YES | Randomly change to follow 56227, other possible 56226,56228-56231,56989-56991 |
NOT IN DB | ||||||
- | AII-DELTA | - | - | NO | YES | |
- | GEISAT | - | - | NO | YES | |
- | Ayris-1 | - | - | NO | YES | |
- | Ayris-2 | - | - | NO | YES | |
- | LEMUR 2 EMBRIONOVIS | - | - | NO | YES | |
- | MISR-A | - | - | NO | YES | |
- | LEMUR 2 NAZIYAH | - | - | NO | YES | |
- | LEMUR 2 AADAM-ALIYAH | - | - | NO | YES | |
- | Swarm Spacebees | - | - | NO | YES | |
- | MISR-B | - | - | NO | YES | |
- | Tiger-4 | - | - | NO | YES | |
- | NewSat 40 | - | - | NO | YES | |
- | NewSat 41 | - | - | NO | YES | |
- | NewSat 43 | - | - | NO | YES | |
- | NewSat 42 | - | - | NO | YES | |
- | 1st ICEYE satellite | - | - | NO | YES | |
- | 2nd ICEYE satellite | - | - | NO | YES | |
- | 3rd ICEYE satellite | - | - | NO | YES | |
- | HotSat-1 | - | - | NO | YES | |
- | 4th ICEYE satellite | - | - | NO | YES | |
- | Skykraft-3 | - | - | NO | YES | |
- | GHOSt-3 | - | - | NO | YES | |
- | Runner-1 | - | - | NO | YES | |
- | EpicHyper2/Dragonette 2 | - | - | NO | YES | Waiting deployment from ION SCV-011 |
[quote=āfredy, post:129, topic:10499ā]
99192 Istanbul 56228 56226,56227,56229-56231,56989-56991 NO YES
ISTANBUL observation with 56228 has some signals in the first 100 seconds without dopller.
Any comments ?
https://network.satnogs.org/observations/7835394/
Baris
OH2UDS / TA7W
Given that it isnāt visible in other observations at the same time, Iām not sure if this is ISTANBUL or other satellite or local noise. Also there isnāt any signal in observations after 1.5h. Letās keep observing though to verify it.
A few basic info on ISTANBUL;
- normal period of 401 MHz beacon is 180 seconds
- if it has some data to relay this information re-transmissions might be more frequent
- Baudrate is 600 bps but RF BW if 5 KHz
- The team figured out a bug in BEACON that may randomly stop/start beaconing (or the beacons might be 1 byte long or 255 bytes longā¦
We will be monitoring 56228 observationsā¦thanks
Baris
OH2UDS / TA7W
Latest Status Update, highlights, SpeiSat identification and reception of the unknown āTransporter 8 Satellite Fā which limited the possible objects to two:
SpeiSat | 56991 | - | YES | YES | Identified, here are the ikhnos results | |
RECEIVED | ||||||
99078 | Transporter 8 Satellite F | 56936 | 56935 | NO | YES | Received again, changed to follow 56936, removed other possible 56932-56934, 56937, 56939-56944, other possible 56935 |
NOT IN DB | ||||||
There are 3 new satellites in this batch: 2023-084BU, BV and BW (56992, 56993 and 56994). BV is a good candidate for MRC-100 since it is ~30-35 seconds behind BQ and this is in accordance with the slight +frequency offset in the waterfalls we received just recently in the last few days. I did a BQ ā BV correction on the waterfalls based on the I/Q recordings of 7848601 and 7848602 - and matches pretty well. BW is ahead of BQ.
Can someone reassign the TLEs for a quick test?
We worked on received signals (out of satnogs network) from ISTANBUL.
in SATNOGS, now we are following TLE 56228 (object BM)
These are some observations (signals captured on ground stations using Vertical antennas)
INFO : The RED dot with date time stamp is the ground station observing.
According the observations (except the last one) Object BQ looks like a better candidate.
Any commentsā¦
Baris
OH2UDS / TA7W
Unfortunately I can not check in detail, so Iāll change to follow BQ for ISTANBUL
I have been searching without success for any clear observation of the satellite,(Hello Space, Istanbul).
Can you point me some?
Thanks.
Hello Fredy!
I am a member of the AMSAT-EA association.
After conducting several analyses, we have come to the following conclusion: since satellite 56993 appears to be MRC-100, we believe that URESAT-1 could be object 56992. Both were deployed simultaneously, along with ROM-2, which could be object 56994. Based on the initial positions of these objects and their current positions, it seems that they are following the expected trajectory for satellites of these characteristics.
Would it be possible to update the Satnogs database accordingly?
Thank you!
Maria del Mar
@maria welcome in the community!
Thank you for the information!
Iāve changed accordingly in DB for ROM-2 and URESAT-1. MRC-100 is already following the right object and as soon as Iām back in a good internet connection (on Monday) Iāll move to identify it fully in DB. Unfortunately I need to do this as Iām currently the bottleneck on this process, hopefully this will change soon.
Iām not saying that this is the case but letās have in mind the deployment order, especially days after the deployment, can be changed drastically and we have seen this in many cases.
By the way if you can share any of the calculations you made or more details would be great! It is very useful for the community to understand how we analyze the data we have and also to verify and give feedback.
