Thanks for input Hans.
That sat is not listed in declined web page by IARU yet. I frequently use it to check the frequency coordination if a satellite is granted to use amateur bands.
73, Rafael
EA4BPN
73, Rafael
EA4BPN
IARU can only decline coordination if there is a coordination request. We never received such a request
73, Hans
Are you aware that when you want to use frequencies in the Ham radio bands you need to request coordination by the IARU
If you aren’t coordinated SatNOGS can’t support the mission.
IARU coordination request site.
Jan PE0SAT
One more delay, new timestamp 2023-04-14 06:47 UTC.
I’m interested to follow INSPIRE-SAT 7. Is it possible to get any prel. kepler?
@SM0TGU preliminary TLE will be available through celestrak in https://celestrak.org/NORAD/elements/supplemental/sup-gp.php?FILE=transporter-7&FORMAT=tle
Haven’t checked if the current there have been updated to the new launch date, so be careful.
For INSPIRE-SAT 7 check the one with the name ROSEYCUBESAT-1 AND INSPI.
Thank you very much for info!
Istanbul (HelloSpace.ist) seems not anymore part of the party: on twitter they announce a launch in June
https://twitter.com/hellospaceist/status/1646072259897876480
while on their website they write May now.
Thanks, I’ve updated the first post by removing Instanbul satellite and adding VCUB1.
Best of luck on the CIRBE mission, Scott.
Is there any value to us monitoring the S-Band downlink that I see mentioned on 2402 Mhz or will that only be transmitting when in communications directly with the UC-Boulder ground station?
List of preliminary TLE sets from Celestrak supplemental list changed with the temporary NORAD IDs we use in SatNOGS DB.
EDIT:
TLE removed due to launch postponement.
Based on the above TLE sets we have scheduled in Network for the first 12h:
Connecta T2.1: 33
Sateliot-0: 28
CIRBE: 54
RoseyCubesat-1: 51
TAIFA-1: 17
Vigoride-6: 18
INSPIRE-SAT 7: 52
ION SCV-010: 18
DEWASAT-2: 15
Pleiades Yearling: 39
BRO-9: 14
Pleiades - Sapling Giganteum: 39
SSS-2B: 17
KILICSAT: 17
Tomorrow-R1: 15
Total 427
To station owners, please make sure you don’t schedule too far in the future as the TLE sets may change a lot after the deployment.
Due to weather the launch is postponed.
Observations removed and Satellite get updated into future status.
EDIT: New launch timestamp 2023-04-15 06:47 UTC
@K4KDR, thanks! S-Band downlinks probably won’t be for several days after deployment but I’ll reach out to you when we get to that point on the commissioning checklist. You are correct, CIRBE will only tx in S-Band only when commanded to do so when in line of sight with LASP (-105.247, 40.009) – but your ground station has a fair amount of overlap with LASP so you should be able to observe in theory. I say in theory because CIRBE also rotates itself to point the S-Band antenna at LASP during an overpass. And, yes, that would be valuable feedback for us for those ground stations that are in range in central/west USA. Thanks again!
Scott G
Thanks very much for the info - I’ll be listening whenever it goes active!
List of preliminary TLE sets from Celestrak supplemental list changed with the temporary NORAD IDs we use in SatNOGS DB:
SAPLING
1 99236C 23054M 23105.32789375 -.00010704 00000+0 -47001-3 0 09
2 99236 97.4021 1.1305 0016156 214.1239 163.1619 15.21892186 16
PLEIADES YEARLING
1 99184C 23054R 23105.32849329 -.00008682 00000+0 -38495-3 0 06
2 99184 97.4123 1.1348 0015527 223.2429 157.3016 15.21569993 14
CIRBE
1 99401C 23054T 23105.32924444 -.00019056 00000+0 -88304-3 0 01
2 99401 97.4082 1.1343 0009411 232.8566 151.8060 15.20128600 11
KILICSAT
1 99193C 23054E 23105.32612870 -.00011060 00000+0 -51772-3 0 02
2 99193 97.4064 1.1297 0008854 241.5704 126.0497 15.19781846 11
ROSEYCUBESAT-1
1 99201C 23054Q 23105.32835324 -.00009750 00000+0 -43000-3 0 01
2 99201 97.4102 1.1338 0016070 220.5463 159.2369 15.21744239 12
SSS-2B
1 99190C 23054B 23105.32576759 -.00008615 00000+0 -39986-3 0 09
2 99190 97.4127 1.1299 0010565 239.8283 125.8038 15.20057582 17
INSPIRE-SAT 7
1 99245C 23054Q 23105.32835324 -.00009750 00000+0 -43000-3 0 09
2 99245 97.4102 1.1338 0016070 220.5463 159.2369 15.21744239 10
BRO-9
1 99185C 23054G 23105.32646319 -.00011794 00000+0 -55174-3 0 02
2 99185 97.4008 1.1291 0008072 236.0284 133.4329 15.19810555 14
CONNECTA T2.1
1 99195C 23054L 23105.32774676 -.00012426 00000+0 -54921-3 0 03
2 99195 97.4001 1.1298 0015148 213.5881 162.8977 15.21684038 13
ION SCV-010
1 99179C 23054AJ 23105.33672361 -.00029206 00000+0 -13343-2 0 00
2 99179 97.4044 1.1408 0010945 222.9102 202.6770 15.20607929 12
SATELIOT-0
1 99180C 23054U 23105.32984861 -.00011142 00000+0 -51775-3 0 04
2 99180 97.4010 1.1314 0008451 224.5395 163.4440 15.20039684 19
DEWASAT-2
1 99186C 23054D 23105.32600718 -.00011297 00000+0 -52651-3 0 01
2 99186 97.4099 1.1299 0009757 240.7199 126.2284 15.19926487 13
TOMORROW-R1
1 99257C 23054AE 23105.33513218 -.00011077 00000+0 -50036-3 0 00
2 99257 97.4050 1.1398 0012486 225.7129 191.1661 15.20971921 13
VIGORIDE-6
1 99178C 23054AL 23105.34025602 -.00032877 00000+0 -14895-2 0 01
2 99178 97.4039 1.1449 0011834 226.0931 218.8188 15.20886345 16
TAIFA-1
1 99283C 23054K 23105.32750023 -.00012855 00000+0 -57095-3 0 02
2 99283 97.3977 1.1290 0014333 212.6116 162.5299 15.21528767 10
INSPIRE-SAT 7: 63
CIRBE: 63
ION SCV-010: 17
BRO-9: 14
Tomorrow-R1: 16
Connecta T2.1: 27
Pleiades Yearling: 36
DEWASAT-2: 15
Pleiades - Sapling Giganteum: 28
TAIFA-1: 20
RoseyCubesat-1: 52
Sateliot-0: 26
KILICSAT: 17
Vigoride-6: 19
SSS-2B: 17
Total 430
Connecta T2.1 is alive and we have also the first decoded frames. First reception by " 3067 - HS-MOEP-1" and “1864 - SA2KNG Omni UHF/VHF” stations. Probably the first signal of the satellite, only ~8min after deployment.
The non-IARU coordinated SSS-2B seems also alive but not decoded, so we are not 100% sure yet. First reception by “1943 - VZLU-PRG” and “1888 - SA2KNG Experimental” stations.
Verify @PE0SAT observation, CIRBE is alive and decoded. First reception in Network by “1298 - primoz” station and decoded reception by “2561 - S51BW-2” station.
