The downlink frequency is 2.245 GHz
Thanks for that information, what mode is being used on S-band?
Thank you!!
And what bandwidth & modulation?
I see about the ITU but I’m talking about IARU coordination and in their site for TAUSAT it only refers to one satellite that will be deployed from ISS. If this needs an update please contact IARU and let us know about any updates.
New TLE sets for ION deployers:
ION SCV-007
1 99216U 23015.40000000 .00000000 00000-0 00000-0 0 05
2 99216 97.4044 77.1546 0009101 65.6934 87.2878 15.12556464 00
ION SCV-008
1 99217U 23015.40000000 .00000000 00000-0 00000-0 0 06
2 99217 97.3472 77.2726 0009101 62.8584 88.3360 15.11879028 07
ion-7-1.dat (1.7 KB)
ion-8-1.dat (1.8 KB)
sites.txt (2.0 KB)
Sharjahsat-1 satellite has been added in DB with the temporary NORAD ID 99204. It is expected to be deployed on 2023-01-16.
Thought I had the first TAUSAT decodes over the Eastern U.S. around 0236utc, but there turned out to be an absolute beehive of objects transmitting 9k6 BPSK around 436.400 along the track of that ION-8 estimated TLE!
The first ‘live’ decode was a T8GBS call sign & later more decodes from T5SNG. There were a LOT of other packets visible in the area as well, just too weak to decode. So, it will be tricky to find TAUSAT in that mix - at least until they spread out. Nothing seen on 2245 MHz S-Band.
Good morning Scott, those are Tevel satellites you received.
TLE set for SharjahSat-1 which has been deployed at 2023-01-16 10:03 UTC
1 99204U 14999A 23016.41888889 .00000000 00000-0 00000-0 0 05
2 99204 97.6296 78.0278 0013662 167.2056 131.2113 15.12764601 07
SharjahSat-1 is received: SatNOGS Network - Observations
However it seems that its interval is big enough to get several signals on one pass, this probably will make it difficult to identify.
Thanks very much! Was wondering who those packets were from.
Has anyone confirmed the ax.25 callsign is for this satellite? I am seeing A60UOS as source and A62UOS as destination for a single frame I received.
Same for several frames in the satnogs observations database. Does anyone know if correct or something else? Thanks.
Bob
N6RFM
Yes this is the callsign of SharjahSat-1
EDIT: you can say from this post when the satellite was under development: https://usttl.itu.edu.tr/en/2020/03/21/laboratuvarimiz-tarafindan-gelistirilme-asamasinda-olan-sharjahsat-1-den-ilk-sinyaller-alindi-🛰👽/ if you see the photo, there is the callsign.
Thank You @fredy . BTW, from a low SharajSat-1 pass, I observed a 5 minute interval between frames. Good hunting all.
Bob
N6RFM
Thank you for listening our satellite. We were requesting telemetry during passage. We appreciate if you could share the received data.
You could also find decoding information here:
https://ituedutr-my.sharepoint.com/:b:/g/personal/oztekinon_itu_edu_tr/EYTXRcrpbPlHmd4AUgvpU60BRJsSHThjoIJsSu3fzl77cA?e=4HEpMv
-SSDTL (USTTL) Team
You can download the network received frames via SatNOGS DB - Sharjahsat-1.
You do need to login to the network.
Newer TLE set for SharajSat-1 by @PE0SAT
SharajSat-1
1 99204U 23016.41888889 .00000000 00000-0 00000-0 0 03
2 99204 97.6296 78.0278 0013662 167.2056 129.6329 15.12764601 07
New TLE set for Sharjahsat-1:
Sharjahsat-1
1 99204U 23018.70000000 .00000000 00000-0 00000-0 0 08
2 99204 97.6296 80.1351 0000650 275.2593 190.7600 15.11924676 02
New TLE sets from spacetrack, some of them in TBA status. They are 95 in total, given that some satellites have been deployed from the deployers, probably we have some missing. We will still need to wait for any identification:
0 OBJECT A
1 55009U 23001A 23018.15873575 .00006307 00000-0 37173-3 0 9990
2 55009 97.5019 80.0133 0010393 174.9100 185.2238 15.11887126 2354
0 OBJECT B
1 55010U 23001B 23018.15787332 .00010611 00000-0 61965-3 0 9996
2 55010 97.5042 80.0191 0010847 176.3034 183.8279 15.12050135 2354
0 OBJECT C
1 55011U 23001C 23018.15754539 .00009993 00000-0 58341-3 0 9995
2 55011 97.5070 80.0246 0011245 178.0617 182.0659 15.12071510 2359
0 OBJECT D
1 55012U 23001D 23018.15649419 .00007690 00000-0 44890-3 0 9992
2 55012 97.5089 80.0301 0012032 176.8346 183.2963 15.12147323 2359
0 OBJECT E
1 55013U 23001E 23018.41990779 .00018789 00000-0 10827-2 0 9993
2 55013 97.5001 80.2731 0010627 164.5095 195.6463 15.12396084 2392
0 OBJECT F
1 55014U 23001F 23018.41962239 .00019639 00000-0 11302-2 0 9998
2 55014 97.5040 80.2829 0011481 171.7682 188.3739 15.12425492 2396
0 OBJECT G
1 55015U 23001G 23018.41971605 .00011093 00000-0 64241-3 0 9993
2 55015 97.5076 80.2899 0011985 172.2198 187.9221 15.12325971 2392
0 OBJECT H
1 55016U 23001H 23018.42009221 .00007838 00000-0 45640-3 0 9995
2 55016 97.5004 80.2753 0011743 169.7664 190.3808 15.12236309 2399
0 OBJECT J
1 55017U 23001J 23018.41888685 .00017587 00000-0 10112-2 0 9991
2 55017 97.4980 80.2727 0011157 167.0157 193.1363 15.12485677 2391
0 OBJECT K
1 55018U 23001K 23018.41889545 .00016868 00000-0 97054-3 0 9990
2 55018 97.5018 80.2800 0011451 166.8823 193.2708 15.12466268 2390
0 OBJECT L
1 55019U 23001L 23018.41883982 .00016716 00000-0 96166-3 0 9995
2 55019 97.5051 80.2865 0011742 169.2241 190.9244 15.12471338 2396
0 OBJECT M
1 55020U 23001M 23018.41859393 .00011262 00000-0 65007-3 0 9997
2 55020 97.5023 80.2801 0011777 164.4708 195.6886 15.12443657 2397
0 OBJECT N
1 55021U 23001N 23018.15409013 .00007358 00000-0 42689-3 0 9991
2 55021 97.5018 80.0187 0011829 161.4878 198.6785 15.12386387 2353
0 OBJECT P
1 55022U 23001P 23018.41793079 .00008075 00000-0 46643-3 0 9990
2 55022 97.5022 80.2802 0012113 158.3376 201.8369 15.12510990 2398
0 OBJECT Q
1 55023U 23001Q 23018.41854573 .00012008 00000-0 69306-3 0 9990
2 55023 97.5052 80.2883 0011879 162.1530 198.0120 15.12430566 2396
0 OBJECT R
1 55024U 23001R 23018.15325372 .00007145 00000-0 41317-3 0 9990
2 55024 97.5045 80.0262 0011902 168.1943 191.9569 15.12514127 2350
0 OBJECT S
1 55025U 23001S 23018.41755680 .00012100 00000-0 69583-3 0 9991
2 55025 97.5052 80.2896 0012158 164.8923 195.2674 15.12556429 2398
0 OBJECT T
1 55026U 23001T 23018.41778733 .00011586 00000-0 66710-3 0 9992
2 55026 97.5015 80.2779 0012648 157.4728 202.7061 15.12517609 2394
0 OBJECT U
1 55027U 23001U 23018.41764106 .00011478 00000-0 66090-3 0 9993
2 55027 97.5010 80.2786 0012129 163.2369 196.9265 15.12524176 2395
0 OBJECT V
1 55028U 23001V 23018.48330580 .00011786 00000-0 67701-3 0 9998
2 55028 97.5025 80.3457 0013020 156.5395 203.6433 15.12594882 2409
0 OBJECT W
1 55029U 23001W 23018.41749706 .00011808 00000-0 67936-3 0 9991
2 55029 97.5049 80.2908 0012326 161.2762 198.8925 15.12542112 2393
0 OBJECT X
1 55030U 23001X 23018.15263135 .00008408 00000-0 48470-3 0 9995
2 55030 97.5012 80.0184 0012483 161.1757 198.9938 15.12565994 2350
0 OBJECT Y
1 55031U 23001Y 23018.41721577 .00011161 00000-0 64191-3 0 9992
2 55031 97.5057 80.2918 0012353 163.7208 196.4422 15.12570545 2395
0 OBJECT Z
1 55032U 23001Z 23018.41664794 .00009171 00000-0 52717-3 0 9999
2 55032 97.5020 80.2800 0013421 157.1892 202.9938 15.12631004 2392
0 OBJECT AA
1 55033U 23001AA 23018.15214417 .00006925 00000-0 39955-3 0 9997
2 55033 97.5000 80.0175 0012550 162.7244 197.4416 15.12602058 2351
0 OBJECT AB
1 55034U 23001AB 23018.41694145 .00007556 00000-0 43618-3 0 9999
2 55034 97.5034 80.2879 0013027 159.9318 200.2428 15.12547753 2392
0 OBJECT AC
1 55035U 23001AC 23018.41000787 .00011683 00000-0 65699-3 0 9992
2 55035 97.5011 80.2870 0015853 163.3068 196.8688 15.13324834 2391
0 OBJECT AD
1 55036U 23001AD 23018.41080055 .00034448 00000-0 19170-2 0 9995
2 55036 97.5034 80.2919 0014673 165.6771 194.4879 15.13472337 2394
0 OBJECT AE
1 55037U 23001AE 23018.47239721 .00023202 00000-0 12807-2 0 9994
2 55037 97.5057 80.3693 0016464 159.7816 200.4071 15.13825679 2409
0 OBJECT AF
1 55038U 23001AF 23017.74367477 .00016238 00000-0 89437-3 0 9999
2 55038 97.5072 79.6580 0017447 164.6091 195.5675 15.13964798 2292
0 TBA - TO BE ASSIGNED
1 55039U 23001AG 23018.61464671 .00014653 00000-0 83712-3 0 9990
2 55039 97.5010 80.4731 0013365 157.7116 202.4698 15.12733257 2420
1 55040U 23001AH 23018.61459072 .00010996 00000-0 63028-3 0 9995
2 55040 97.5063 80.4906 0012736 164.5743 195.5879 15.12691301 2423
1 55041U 23001AJ 23018.61270808 .00008063 00000-0 46123-3 0 9993
2 55041 97.5031 80.4851 0013998 161.6625 198.5113 15.12841864 2421
1 55042U 23001AK 23018.61476062 .00007626 00000-0 43895-3 0 9991
2 55042 97.5004 80.4730 0013045 159.4134 200.7625 15.12647297 2429
1 55043U 23001AL 23018.61424194 .00008027 00000-0 46094-3 0 9991
2 55043 97.5054 80.4902 0012713 162.8212 197.3451 15.12719807 2427
1 55044U 23001AM 23018.61454003 .00008992 00000-0 51628-3 0 9994
2 55044 97.5074 80.4917 0013162 166.8478 193.3099 15.12681772 2426
1 55045U 23001AN 23018.61420726 .00010022 00000-0 57416-3 0 9998
2 55045 97.5033 80.4800 0013969 158.0902 202.0929 15.12720643 2424
1 55046U 23001AP 23018.68052962 .00005324 00000-0 30767-3 0 9998
2 55046 97.5040 80.5514 0013242 161.0598 199.1128 15.12646056 2438
1 55047U 23001AQ 23018.67986731 .00010049 00000-0 57485-3 0 9994
2 55047 97.5032 80.5438 0014225 158.3644 201.8191 15.12769503 2432
1 55048U 23001AR 23018.67967365 .00009587 00000-0 54855-3 0 9990
2 55048 97.5032 80.5501 0013654 160.3298 199.8462 15.12782537 2436
1 55049U 23001AS 23018.61286827 .00013053 00000-0 74290-3 0 9990
2 55049 97.5037 80.4819 0014266 160.1501 200.0288 15.12886711 2427
1 55050U 23001AT 23018.67788665 .00032317 00000-0 18129-2 0 9997
2 55050 97.5034 80.5532 0013411 162.8026 197.3663 15.13214743 2438
1 55051U 23001AU 23018.67922687 .00004789 00000-0 27605-3 0 9994
2 55051 97.5037 80.5479 0014607 160.8922 199.2860 15.12770546 2430
1 55052U 23001AV 23018.67851531 .00013921 00000-0 79072-3 0 9997
2 55052 97.5029 80.5506 0013953 161.5741 198.5998 15.12944981 2433
1 55053U 23001AW 23018.67876772 .00004504 00000-0 25962-3 0 9998
2 55053 97.5042 80.5498 0014725 161.8609 198.3150 15.12804158 2432
1 55054U 23001AX 23018.67848027 .00006150 00000-0 35263-3 0 9995
2 55054 97.5024 80.5504 0013997 162.4663 197.7053 15.12854856 2433
1 55055U 23001AY 23018.67781734 .00011567 00000-0 65653-3 0 9991
2 55055 97.5032 80.5453 0014922 160.2787 199.9024 15.13004224 2437
1 55056U 23001AZ 23018.67732062 .00011098 00000-0 62985-3 0 9996
2 55056 97.5029 80.5520 0014104 163.6475 196.5214 15.13031459 2436
1 55057U 23001BA 23018.67685862 .00011921 00000-0 67497-3 0 9990
2 55057 97.5043 80.5587 0013803 165.6241 194.5385 15.13100779 2433
1 55058U 23001BB 23018.67880455 .00011009 00000-0 62755-3 0 9995
2 55058 97.5029 80.5501 0014025 161.9317 198.2415 15.12876486 2433
1 55059U 23001BC 23018.67842103 .00017364 00000-0 98362-3 0 9997
2 55059 97.5026 80.5505 0013915 161.8414 198.3317 15.12992977 2435
1 55060U 23001BD 23018.74795811 .00004127 00000-0 24600-3 0 9997
2 55060 97.5021 80.6101 0018502 177.7820 182.3496 15.11584331 2441
1 55061U 23001BE 23018.01584650 .00003361 00000-0 19396-3 0 9990
2 55061 97.5031 79.9031 0013631 168.4381 191.7166 15.12949680 2332
1 55062U 23001BF 23018.74266253 .00013288 00000-0 75065-3 0 9991
2 55062 97.5041 80.6168 0014755 164.0825 196.0873 15.13144619 2442
1 55063U 23001BG 23018.74012453 .00008063 00000-0 45457-3 0 9990
2 55063 97.5059 80.6289 0015699 166.6115 193.5536 15.13343694 2446
1 55064U 23001BH 23018.74153336 .00011085 00000-0 62555-3 0 9993
2 55064 97.5040 80.6241 0014612 167.2224 192.9381 15.13229279 2440
1 55065U 23001BJ 23018.74116037 .00011681 00000-0 65787-3 0 9993
2 55065 97.5069 80.6288 0015329 165.4573 194.7102 15.13278040 2447
1 55066U 23001BK 23018.74066061 .00011965 00000-0 67290-3 0 9991
2 55066 97.5051 80.6271 0015255 167.0703 193.0922 15.13323133 2448
1 55067U 23001BL 23018.73814249 .00029599 00000-0 16335-2 0 9995
2 55067 97.5081 80.6355 0015841 165.5429 194.6259 15.13788970 2448
1 55068U 23001BM 23018.73936200 .00011987 00000-0 67140-3 0 9991
2 55068 97.5006 80.6142 0016279 161.7140 198.4680 15.13455081 2448
1 55069U 23001BN 23018.73943118 .00011295 00000-0 63343-3 0 9991
2 55069 97.5040 80.6263 0015363 169.3017 190.8544 15.13438712 2448
1 55070U 23001BP 23018.73939809 .00011855 00000-0 66366-3 0 9995
2 55070 97.5001 80.6138 0015990 159.6835 200.5036 15.13478890 2440
1 55071U 23001BQ 23018.73971342 .00011874 00000-0 66582-3 0 9995
2 55071 97.5016 80.6154 0016117 163.6384 196.5371 15.13419721 2445
1 55072U 23001BR 23018.73964828 .00016034 00000-0 89605-3 0 9991
2 55072 97.5063 80.6287 0015967 163.7209 196.4539 15.13470857 2446
1 55073U 23001BS 23018.74011891 .00014540 00000-0 79699-3 0 9998
2 55073 97.5036 80.6199 0017960 145.0095 215.2321 15.14153716 2442
1 55074U 23001BT 23018.73874198 .00011591 00000-0 64784-3 0 9997
2 55074 97.5047 80.6285 0015856 168.2165 191.9440 15.13545754 2446
1 55075U 23001BU 23018.73881828 .00012687 00000-0 70922-3 0 9994
2 55075 97.5025 80.6185 0016095 166.2037 193.9637 15.13513015 2449
1 55076U 23001BV 23018.74230798 .00006127 00000-0 34890-3 0 9996
2 55076 97.5029 80.6145 0015366 163.7295 196.4432 15.13088911 2441
1 55077U 23001BW 23018.73863410 .00011975 00000-0 66920-3 0 9995
2 55077 97.5052 80.6288 0016209 166.2206 193.9471 15.13536530 2443
1 55078U 23001BX 23018.73852139 .00011644 00000-0 65077-3 0 9997
2 55078 97.5010 80.6174 0016443 160.5345 199.6518 15.13538492 2447
1 55079U 23001BY 23018.73857662 .00011183 00000-0 62544-3 0 9998
2 55079 97.5043 80.6260 0016487 165.4063 194.7648 15.13521898 2441
1 55080U 23001BZ 23018.73828623 .00011569 00000-0 64607-3 0 9995
2 55080 97.5017 80.6188 0016694 162.9617 197.2178 15.13562515 2447
1 55081U 23001CA 23018.73859639 .00010017 00000-0 56087-3 0 9997
2 55081 97.5056 80.6286 0016696 162.5879 197.5928 15.13509567 2442
1 55082U 23001CB 23018.80443398 .00019064 00000-0 10610-2 0 9999
2 55082 97.5025 80.6864 0016553 161.3392 198.8449 15.13572008 2453
1 55083U 23001CC 23018.80436487 .00012184 00000-0 68012-3 0 9997
2 55083 97.5018 80.6843 0016750 162.9609 197.2188 15.13566118 2458
1 55084U 23001CD 23018.80386919 .00011543 00000-0 64383-3 0 9997
2 55084 97.5003 80.6830 0016401 156.0397 204.1601 15.13613152 2459
1 55085U 23001CE 23018.80326372 .00017485 00000-0 96877-3 0 9999
2 55085 97.5011 80.6848 0016697 159.1967 200.9947 15.13749201 2454
1 55086U 23001CF 23018.80308201 .00017721 00000-0 98117-3 0 9993
2 55086 97.5040 80.6919 0016708 158.7049 201.4881 15.13770402 2455
1 55087U 23001CG 23018.80269491 .00021298 00000-0 11755-2 0 9997
2 55087 97.5020 80.6881 0016610 158.1806 202.0137 15.13844458 2453
1 55088U 23001CH 23018.80269370 .00018001 00000-0 99517-3 0 9995
2 55088 97.5080 80.7001 0016946 159.3962 200.7956 15.13818116 2459
1 55089U 23001CJ 23018.80214441 .00019263 00000-0 10623-2 0 9996
2 55089 97.5017 80.6887 0016457 158.6467 201.5455 15.13898002 2455
1 55090U 23001CK 23018.80249837 .00015626 00000-0 86500-3 0 9992
2 55090 97.5043 80.6935 0017267 161.1157 199.0719 15.13797549 2453
1 55091U 23001CL 23018.80176381 .00022061 00000-0 12136-2 0 9990
2 55091 97.5018 80.6889 0016939 157.7452 202.4518 15.13951006 2454
1 55092U 23001CM 23018.80092508 .00025785 00000-0 14114-2 0 9993
2 55092 97.5021 80.6897 0018815 159.5295 200.6695 15.14065821 2456
1 55093U 23001CN 23018.80194120 .00013805 00000-0 76419-3 0 9994
2 55093 97.5018 80.6888 0017201 156.0635 204.1400 15.13827426 2450
1 55094U 23001CP 23018.80112306 .00025261 00000-0 13866-2 0 9996
2 55094 97.5014 80.6888 0015773 156.6920 203.5030 15.14016810 2452
1 55095U 23001CQ 23018.80110709 .00022074 00000-0 12119-2 0 9991
2 55095 97.5017 80.6896 0017175 157.3872 202.8120 15.14017523 2451
1 55096U 23001CR 23018.80098424 .00022022 00000-0 12086-2 0 9997
2 55096 97.5016 80.6899 0017216 157.3402 202.8593 15.14031718 2455
1 55097U 23001CS 23018.80080750 .00023779 00000-0 13035-2 0 9996
2 55097 97.5016 80.6900 0017325 157.3031 202.8971 15.14054857 2457
1 55098U 23001CT 23018.80131292 .00016483 00000-0 90868-3 0 9999
2 55098 97.5072 80.7004 0017528 157.3877 202.8131 15.13927741 2457
1 55099U 23001CU 23018.80073863 .00023639 00000-0 12957-2 0 9992
2 55099 97.5016 80.6900 0017319 157.3796 202.8202 15.14060192 2456
1 55100U 23001CV 23018.80074680 .00024868 00000-0 13622-2 0 9998
2 55100 97.5013 80.6894 0017699 157.7797 202.4205 15.14065043 2453
1 55101U 23001CW 23018.80015203 .00028252 00000-0 15413-2 0 9996
2 55101 97.5015 80.6905 0018069 156.5545 203.6515 15.14176784 2451
1 55102U 23001CX 23018.80035440 .00026223 00000-0 14339-2 0 9994
2 55102 97.5015 80.6904 0016773 160.3941 199.7939 15.14130772 2456
1 55103U 23001CY 23018.80117591 .00009792 00000-0 54279-3 0 9993
2 55103 97.5051 80.6964 0017803 155.6659 204.5417 15.13858383 2451
Until then here are the best fits on the satellites we have managed to receive:
| Satellite Identifier | Satellite Name | NORAD ID to Follow | Other Possible NORAD IDs | Notes |
| DELH-6722-1461-1897-7938 | Sharjahsat-1 | 55040 | 55039, 55042(unlikely), 55044 | Received and set to follow OBJECT AH(51040) fits |
| NJFB-9884-9643-7739-4519 | BDSAT-2 | 55098 | 55038(unlikely), 55094(unlikely), 55095(unlikely), 55103 | Received and changed to follow for now only OBJECT CT(51098) fits |
| NJEX-6170-8600-1975-0468 | ION SCV-007 | 55051 | - | Received and for now only OBJECT AU(55051) fits |
| VPUU-7194-1121-2414-5647 | ION SCV-008 | 55033 | - | Received and for now only OBJECT AA(55033) fits |
| RJCF-5779-9216-5641-4111 | BRO-8 | 55011 | - | Received and for now only OBJECT C(55011) fits |
| PDVW-9191-3063-9872-9368 | Vigoride-5 | 55036 | - | No update |
| KCKF-9169-8304-1813-6974 | Platform-2 | 55067 | 55077-55083 | Received and changed to follow OBJECT BL(55067) fits |
| TVZK-1463-5590-8994-0377 | Connecta T1.2 | 55012 | - | Received and for now only OBJECT D(55012) fits |
