SpaceX F9 Transporter-5 - 2022-05-25 18:35UTC
Hello Everybody,
I would like to know if it’s possible to add tracking until the 25th of July?
We are still thinking that the TLE 5243 is our Satellite.
Also, do you know why one observation has a good status without any data in the waterfall?
https://network.satnogs.org/observations/6177351/
Thank you in advance for your answers
Have a nice day
Hi @arthurspin,
The good status was a mis-vetting, I’ve re-vetted as bad the observation because as you noted there isn’t any signal visible in waterfall.
I’ve also scheduled a couple of observations for SPiN-1 for the next 2 days and I’ll have it in mind until 25th. If you have certain passes and you can give me certain datetimes in UTC, I can focus scheduling around these datetimes.
The Veery FS-1 satellite would have been ejected from the Vigoride-3 platform days ago, the frequency is 60 KHZ wide , and ranges from 137.935-137.965 MHz. Probably active only over USA.
According to " Correspondence for File Number: 1838-EX-ST-2021" from fcc.gov:
https://apps.fcc.gov/els/GetAtt.html?id=293144&x=.
They have removed the VHF request. Also there isn’t any request on ITU too for VHF for this satellite.
Anyway I’ve added the satellite in DB.
Hello Everybody,
I would like to know if it’s possible to add tracking for until the EOD 11th of July?
We are still thinking that the TLE 52743 is our Satellite.
Thank you in advance,
Have a nice day,
Saish
I’ve scheduled a couple of observations for the next 48h. Good luck!
Hi All,
Thank you very much! After a discussion, we are planning to continue tracking the satellite until the end of this month with the same TLE (52743). There are some updated TMs that we want to send and see what happens.
I would like to request to add tracking for now until next Monday (22nd July).
Thank you once again for all the support.
Regards,
Saish
Hi All,
Will it be possible to add tracking until Monday (22nd July)?
Regards,
Saish
Is it possible to extend the tracking for SPiN-1 until 31/08? thank you!
Regards
SelfieSat is deployed and alive! We still follow the Vigoride TLE set and waiting for the space-track.org to publish the actual one.
By SelfieSat team, this is the TLE set we currently use:
SelfieSat
1 99392U          22242.85395300  .00000000  00000-0  00000-0 0    00
2 99392  97.5240 356.4817 0009446 161.0275 196.5862 15.12638315    02
Hi All,
We have stopped operations for SPiN-1 with the last command sent on the 31st of August. Unfortunately, we were not able to have contact with the satellite. I thank everyone for all the support provided during our mission. It has been really helpful to converge on the correct TLE for our satellite.
Until next time.
Regards,
Saish
New TLE set for SelfieSat generated with strf observations by @satcolintel5 and confirmed with ikhnos and converted to use the temporary NORAD ID by @PE0SAT:
SELFIESAT
1 99392U          22257.60342480  .00000000  00000-0  16542-3 0    01
2 99392  97.5243  11.0244 0011101 203.0023 146.0630 15.12839845    06
